HDTV 4K & 8K TV
Samsung Expands Its 2024 OLED TV Line-up
The 2024 Samsung OLED 4K TV lineup ranges in size from 42 to 83-inches, priced from $1,399 to $5,399.
2024 Samsung S95 OLED 4K TV
Following up on our report in March 2024 where we outlined Samsung’s 2024 TV line-up known at the time (including pricing), the world’s largest TV maker has followed up with an announcement that it is expanding its 4K QD-OLED and OLED TV offerings with a new model series and several new screen sizes.
Editorial Comment: When confronted as to which TV models are incorporating WOLED panels Samsung provided the following non-response:
Samsung OLED TVs consistently offer a premium experience while delivering excellent viewing performance powered by our NQ4 AI Gen2AI processor, regardless of the specific panels that are integrated into the product.
Apparently, Samsung wants to conceal which OLED technology is used, but we’re not sure how that helps buyers. As a result, I have provided my determinations as to which models use which panel technology based on my experience how Samsung acquires OLED panels from LG Display (QD-OLED panels are made by Samsung Display).
Tip: Currently QD-OLED TVs rank the best in terms of picture quality, but are also the most expensive.
S85D Series (New)
Samsung S85D OLED TV Front Angle View
To start, Samsung has announced a new-entry-level OLED TV series, the S85D. This series utilizes WOLED panels and not the QD-OLED panels used in the S95 and most of the S90 series TVs.
The new S85D series comes in 55, 65, and 75-inch screen sizes and incorporates the same advanced NQ4 AI Gen2 Processor, 4K AI Upscaling capabilities, and Pantone Validated Colors found across the Samsung OLED TV lineup.
Samsung NQ4 AI Gen2 Processor
The S85D models also provide the full suite of Samsung’s features such as Dolby Atmos Sound for immersive audio, Samsung TV Plus with access to hundreds of channels, Samsung Gaming Hub for streaming games without a console, and more.
The S85D also features Motion Xcelerator Technology (120Hz) along with a bold look and feel, with a unique contour design.
Tech Note: The S85D TV models incorporate WOLED panels.
S90D Series (New 42 and 48-inch Screen Sizes Added)
Samsung S90D QD-OLED TV Front Angle View
The S90D expanded sizes are ideal for gamers with their Motion Xcelerator Turbo+ (144Hz) to help eliminate lag alongside OLED HDR+ that delivers powerful brightness and rich contrast.
Tech Note: The S90D 55, 65, and 77-inch models use QD-OLED panels, while the 42, 48, and 83-inches use WOLED Panels.
S95D Series (Top-of-the line)
Samsung S95D QD-OLED TV Front View
Announced earlier this year at CES 2024, the S95D series are Samsung’s top-of-the-line models. Combining Quantum dot and OLED technology, the S95D 4K TVs use individually self-lit pixels to eliminate the need for LED backlighting and an LCD Display layer, increasing brightness and color accuracy
This TV line provides wide contrast, vibrant color, and high-brightness display output.
The S95D is the first OLED (QD-OLED) TV with OLED Glare Free technology. This provides the best possible viewing experience across both bright and dark rooms. It has no negative effects on your viewing angle or contrast, and no color distortion.
Tech Note: To support an optimally smooth gaming experience, the S95D incorporates a 4K 144Hz panel.
At under 11mm, the S95D is also extremely thin. It features a flat-back design with an attachable One Connect Box that complements any space, making high-end architectural installations easy.
The S95D series is also designed to deliver great sound. Object Tracking Sound leverages the TV’s built-in multi-channel speakers to provide a fully immersive soundstage. With enhancements to its built-in speaker distribution on the side, bottom, and top of the TV, viewers can experience Dolby Atmos.
For a more detailed rundown on Samsung’s entire TV line including more information on features included in most  Samsung TVs, refer to our previous article: 2024 Samsung 4K & 8K TVs: Updated With Pricing.
Related Reading
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Netflix expands its viewing flexibility by embracing HDR10+, but there are a couple of catches.
HDTV 4K & 8K TV
At 85 or 98-inches, the top-of-the-line 2025 TCL X11K 4K TVs boast 6,500 nits, 14,000 dimming zones and HALO Control Technology.
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
HDTV 4K & 8K TV
Would you buy a 55-inch Sharp 4K TV with built-in TiVo for $299.99? Let's take a look at what it offers.
Sony just unveiled two new entry-level Dolby Atmos-compatible soundbars for those who want to beef up their TV sound without breaking the bank.
Owners of Samsung's 2024 HW-Q990D, HW-Q800D, and HW-S801D models have a big and annoying problem... Here's what to do if your soundbar is affected.
