Samsung today announced NX11 interchangeable lens digital camera system. The NX11 contains a feature set similar to Samsung's first mirrorless interchangeable lens camera, the NX10, however the NX11 is also compatible with the new i-Function lens that was introduced for the NX100. The NX11 will come complete with an 18-55mm i-Function lens, as well as two new i-Function lenses, a 20mm pancake and a 20-50mm zoom silver color lens.
The i-Function lens puts the perfect picture at the fingertips of all photographers by providing an exceptionally easy way of controlling the camera. Since a typical camera user wraps their hand around the lens when holding the camera, the new i-Function system allows photographers to naturally use their left hand to change the camera's advanced settings via a button built into the i-Function lens, without needing to take the camera off the target. Users can toggle between shutter speed, aperture, EV, WB, and ISO quickly and easily by simply using the i-Function button or ring on the lens, meaning easier and quicker configurations while shooting.
The NX11 also focuses on usability, with a change in the grip design to make shooting easier and more comfortable for users. Additionally, the NX11 has a lens priority mode dial, simplifying the search for the best mode for each lens. The camera also includes a convenient, one-touch i-Function button that activates common shooting controls like aperture, shutter speed, ISO and white balance, meaning easier and quicker configuration while shooting. The camera makes taking great landscape scenes or pictures of large groups simple by featuring a panorama mode, which allows the user to take panoramic pictures in one press-and-sweep motion. As with the NX10, the NX11 uses the best-in-class APS-C sensor for better image quality. The APS-C sensor is larger than Micro 4/3 and delivers high quality images with ease.
Alongside the built-in flash and built-in electronic VGA (640×480) viewfinder, the NX11 has a 3.0″ AMOLED LCD screen. The AMOLED screen reduces the glare from sunlight so that consumers can see their images under any lighting conditions. The user can also get a more vivid, clearer image through enhanced color reproduction. The NX11 provides high quality video with 720p HD recording, and its large APS-C sensor allows the videos to be recorded with shallow depth of field, providing effects similar to those in motion picture movies.
NX11 Specifications Sheet
Image Sensor | 23.4×15.6mm CMOS Approx. 14.6 Megapixels |
Lens | Samsung NX Mount Samsung Lenses for Samsung NX Mount |
Image Stabilization | Lens Shift (depends on Lens) | ||
Dimensions and weight | 123 x 87 x 39.8mm (excluding the projecting part) 353g (without battery and card) |
Additional features |
Price | $649 (with bundle zoom lens) | ||
Availability | February |
Lenses
Lens Name | SAMSUNG 20-50mm F3.5-5.6 ED Black/Silver | ||
Focal Length | 20 – 50mm (equivalent to 30.8-77mm in 35mm format) | ||
Elements in Groups | 9 elements in 8 groups (1 Aspherical lens, 1 Extra-low Dispersion lens) | ||
Angle of View | 70.2°- 31.4° | ||
Aperture | F3.5 – 5.6 (Min. F22), (Number of Blades : 7 , Circular Aperture Diaphragm) | ||
Mount Type | Samsung NX Mount | ||
Optical Image Stabilizer | No | ||
Minimum Focus Distance | 0.28m | ||
Maximum Magnification | Approx.0.22X | ||
i Scene | Beauty, Portrait, Children, Backlight, Landscape, Sunset, Dawn, Beach&Snow, Night | ||
Lens Hood | No | ||
Filter Size | 40.5mm | ||
Max. Diameter x Length | 64 x 39.8mm | ||
Weight | Approx. 119g (without hood) | ||
Operating Temperature | 0 ~ 40°C | ||
Operating Humidity | 5 ~ 85% | ||
Special features | i-Function, World's first under 40mm length | ||
Lens Name | SAMSUNG 20mm F2.8 Black/Silver | ||
Focal Length | 30mm (equivalent to 30.8mm in 35mm format) | ||
Elements in Groups | 6 elements in 4 groups (1 Aspherical lens | ||
Angle of View | 70.2° | ||
Aperture | F2.8 (Min. F22), (Number of Blades : 7 , Circular Aperture Diaphragm) | ||
Minimum Focus Distance | 0.17m | ||
Maximum Magnification | Approx. 0.18X | ||
i Scene | Night, Landscape, Sunset, Dawn, Backlight, Beach&Snow | ||
Lens Hood | No | ||
Filter Size | 43mm | ||
Max. Diameter x Length | 62.2 x 24.5mm | ||
Weight | Approx. 89g (without hood) | ||
Special features | i-Function, Minimum focus distance (0.17m) | ||
Lens Name | SAMSUNG 18-55mm F3.5-5.6 OIS i-Function | ||
Focal Length | 18 – 55mm (equivalent to 27.7-84.7mm in 35mm format) | ||
Elements in Groups | 12 elements in 9 groups (1 Aspherical lens) | ||
Angle of View | 75.9°- 28.7° | ||
Optical Image Stabilizer | Yes | ||
Maximum Magnification | Approx. 0.22X | ||
Lens Hood | Included | ||
Filter Size | 58mm | ||
Max. Diameter x Length | 63 x 65.1mm | ||
Weight | Approx. 198g (without hood) | ||
“The NX11, while offering the best features of the NX10, has an upgraded design and the additional i-Function capability with more lenses. The launch of our next offering in the NX range also demonstrates our commitment to our customers, by producing user driven innovation in the form of easy-to-use functions and upgraded customization.”
— Mr. Hyunho Chung, Executive Vice President and Head of the Digital Imaging Business, Samsung Electronics.
