Laptops
Samsung Notebook 7 spin Flips All Around
Samsung today announced the Notebook 7 spin Windows 10 laptop in 13.3-inch or 15.6-inch screen sizes. Priced from $800 to $1200,  all models feature a 1920×1080 touchscreen display with Video HDR mode, expandable storage options, and fast charging capabilities.
The Notebook 7 spin has a 360 degree touch display that offers users incredible viewing angles. Utilizing Continuum, the PC can be transformed into three adaptive modes: use it as a notebook to touch and type as you connect with friends, stand it up to enjoy the latest movie in tent mode, or switch to tablet mode to surf the web.
The Full HD touch screen with Video HDR mode makes the content sharper, colors more vivid and textures truly pop. Video HDR mode instantly optimizes the video experience, so that every little detail comes to life, drawing users in to all the action.
Samsung Notebook 7 spin open
With a 6th generation Intel Core i5 or i7 processor, 1 TB hard drive, and upgradeable RAM and SSD options, users can seamlessly handle everything they need to accomplish while cutting down on load times so they can do more at once.
Fast charging functionality provides 2 hours of battery life from just 20 minutes of charging. In just 90 minutes, the 15.6-inch notebook will be fully powered, while the 13.3-inch reaches a full charge in 100 minutes.
Additionally, Samsung architected an auto backlit keyboard, allowing for comfortable typing in low light conditions. The UL approved keyboard is ergonomic and convenient, with useful hotkeys that give instant access to functions most often used.
Price and Availability
The Samsung Notebook 7 spin will be available beginning June 26, 2016 at Best Buy and BestBuy.com, as well as Samsung.com, starting at $799.99.
Specification Comparison
13.3-inch 15.6-inch 15.6-inch
Operating System Windows 10 Windows 10 Windows 10
Processor/Chipset 6th Gen Intel Core i5
Processor 6200U (2.30
GHz
up to 2.80GHz 3
MB L3 Cache)
6th Gen Intel Core i7
Processor 6500U (2.50
GHz
up to 3.1GHz 4 MB
L3 Cache)
Processor 6500U (2.50 GHz
up
to 3.1GHz 4 MB
L3 Cache)
Graphic Intel HD Graphics 520 NVIDIA GeForce
940MX Graphics with
2GB DDR3L Graphic
Memory
NVIDIA GeForce
940MX Graphics with
2GB DDR3L Graphic
Memory
Display 13.3″ FHD LED Display
(1920 x 1080) with
Touch
Screen Panel
15.6″ FHD LED Display
(1920 x 1080) with
Touch
Screen Panel
(1920 x 1080) with
Touch
Screen Panel
Memory 8GB DDR4 Memory at
2133MHz (4GB x 2)
12GB DDR4 Memory at
2133MHz (8GB x 1 +
4GB x 1)
16GB DDR4 Memory at
2133MHz (8GB x 2)
Hard Drive 1TB 1TB 1TB with 128GB SSD
Color Platinum Silver Platinum Silver Platinum Silver
Multimedia Internal Dual Array
Digital Mic
Stereo Speakers (1.5 W x
2 )
SoundAlive
Web camera
Internal Dual Array
Digital Mic
2 )
SoundAlive
Web camera
Internal Dual Array
Digital Mic
2 )
SoundAlive
Web camera
Ports 1 Headphone out/Mic-in Combo
1 DC-in
1 HDMI
1 USB3.0
2
USB2.0
1 USB-C [up to
5Gbps, Charging, 4K
display
out with optional
adapter]MicroSD Multi-media
Card Reader
1 DC-in
1 HDMI
1 RJ45
(LAN)
1 USB3.0
2 USB2.0
1 USB-C [up to
5Gbps,
Charging, 4K
display out with optional
adapter]
3-in-1
(SD, SDHC,
SDXC) Multi-media
Card Reader
1 DC-in
1 HDMI
1 RJ45
(LAN)
1 USB3.0
2 USB2.0
1 USB-C [up to
5Gbps,
Charging, 4K
adapter]3-in-1 (SD, SDHC,
SDXC) Multi-media
Card Reader
Input Clickpad
Touch screen
Island-type Backlit keyboard
Clickpad
Touch screen
Island-type Backlit
keyboard
with numeric key
Clickpad
Touch screen
Island-type Backlit
keyboard
with numeric key
Power 40 W AC Adapter
45Wh Battery
60 W AC Adapter
45Wh Battery
60 W AC Adapter
45Wh Battery
Dimension 323.4 x 227.7 x 19.8mm
(12.75” x 8.98” x 0.78”)
374.5 x 256.9 x 19.8mm
(14.74″ x 10.11″ x 0.78″)
Weight 3.90lbs 5.00lbs 5.00lbs
Price/Availability $799.99
June 26, 2016
$999.99
June 26, 2016
$1,199.99
June 26, 2016
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
