Samsung HMX-P300 and HMX-P100 Pocket HD Camcorders
Samsung today announced the Full HD HMX-P300 and HMX-P100 pocket camcorders designed for those who love sharing videos with friends and family, and enjoy capturing film spontaneously and uploading just as quickly. Stylish, pocket-sized and affordable, the HMX-P300 and HMX-P100 have been created to be carried anywhere, and make uploading and sharing special moments both easy and fun.
The HMX-P300 and HMX-P100 follow the Samsung HMX-E10 model, bringing with them the latest developments in Samsung imaging technology, ultimately comprising some of the best value point-and-share camcorders on the market. Key developments including a 5M BSI (Back Side Illuminated) CMOS sensor, which dramatically improves low-light recording and HD movie recording, are available in the P100. The HMX-P300 and HMX-P100 are also the ultimate point-and-share camcorders for those who want to upload their videos quickly and easily. Through the new One Touch Sharing feature, users can select which website they want to upload files to directly from the LCD screen. Both point-and-share camcorders come with advanced Intelli-Studio 2.0 software pre-installed so it's easy to connect to a PC and start sharing straight away.
The HMX-P300 is also specially adapted to make video capture easy from any angle, by including a 3x Optical Zoom and Pivot Recording Mode, enabling you to capture greater detail at any occasion, such as concerts or sporting events, in horizontal or vertical frames. The 3x Optical Zoom allows you to record in clear and brilliant detail while on-the-go, without sacrificing video quality. The 3″ 230K pixel Touch LCD screen can also rotate to give multiple shooting angles that allow the user a full, clear view of their subject without sacrificing the shot through portrait or landscape orientation. To make sure that you don't miss any of the action, the Samsung HMX-P100 is also built with an LCD screen that has an 80-degree viewing angle, so no matter how you're holding your point-and-share camcorder, you'll enjoy a clear view every time. Both point-and-share camcorders can also function as cameras, with 8M Pixel (HMX-P300) and 5M Pixel (HMX-P100) still image capture.
New experiences in quality and usability
Samsung HMX-P300 Pocket HD Camcorder
The HMX-P100 and P300 are built to make sharing movies easier than ever through the One Touch Sharing feature. Once the point-and-share camcorder is connected to a PC via the built-in USB arm, videos will upload automatically, saving time with file transfers and making sure you never forget to share special memories with friends and family. In addition, the HMX-P300 and HMX-P100 can also capture great still photographs, eliminating the need to carry around a separate camera.
Both the HMX-P100 and HMX-P300 are built with mobility in mind. Using Micro SD technology, the camcorders are much smaller and more compact than conventional point-and-share camcorders. The slim bodies of the point-and-share camcorders can easily fit into a jacket pocket or handbag, while the built-in USB arms and USB charging features enable users to charge batteries and share images simultaneously without needing an additional cable.
The point-and-share camcorders include features to create the best possible image quality out of every situation. The innovative 5M BSI (Back Side Illuminated) CMOS sensor featured on the HMX-P100 records with twice the sensitivity of regular CMOS sensors to reduce image noise and distortion and dramatically enhance recording quality in low-light situations. The AF lens of the HMX-P100 also makes it easy to capture bright and clear movies anytime and anywhere.
In addition, the HMX-P300 and HMX-P100 include a number of smart features that make recording simple. The Auto Focus and Smart Auto functions on both models automatically adjust focus and shooting modes according to factors such as color, subject and brightness. Both point-and-share camcorders also feature new Record Pause technology, allowing users to take a brief pause in filming before re-starting recording within the same file. This feature makes is much easier to edit and share footage, and ensure that users have the best video capturing experience.
Specifications
HMX-P300 HMX-P100
Storage Media Micro SDHC/SD Card Micro SDHC/SD Card
Image Stabilization DIS image stabilization DIS image stabilization
Sensor 1/3.2″ 8M CMOS 1/3.2″ 5M BSI CMOS
Lens 3x optical zoom Samsung lens
  • F 2.8
  • f=4.4~13.2
1x zoom Samsung lens
  • F 2.2
  • f=4.3
Size 58 x 18 x 110 mm 57.5 x 112.5 x 14.5 mm
Additional features
  • Auto Focus
  • Face detection
  • 8 lux @1/15sec minimum illumination
  • Smart Auto
  • Record Pause
  • USB charging
  • Intelli-Studio 2.0
  • One-Touch sharing feature
  • Tripod screw
  • Auto Focus
  • Face detection
  • 5 lux @1/30sec minimum illumination
  • Smart Auto
  • Record Pause
  • USB charging
  • Tripod screw
Display 3.0″ Touch LCD
230K resolution
2.3″ LCD
230K resolution
Video recording H.264 resolution
HD resolution:
  • 1920×1080 30p
  • 1280×720 60p
  • 1280×720 30p
H.264 resolution
HD resolution:
  • 1920×1080 30p
  • 1280×720 60p
  • 1280×720 30p
Device Connectivity USB PC interface via USB arm
HDMI interface
Composite interface
HDMI interface
Battery type BP-11A (1050mAh) BP90A (900mAh)
Colors Titan black, silver, white and pink black, sliver, blue, pink
Price $199 $149
Aa Availability March February
Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
