Samsung Galaxy Note 4 Smartphone
If the new iPhone 6 Plus is not big enough for you, Samsung will be releasing the even larger 5.7-inch smartphone called Galaxy Note 4 in the U.S. beginning October 17th, with pre-orders September 19th.  The phablet has a Quad HD (2560 x 1440) Super AMOLED display that tops iPhone, along with 16-megapixel rear-facing camera with an Optical Image Stabilizer. In addition, the device includes a 3.7-megapixel front-facing camera. Both cameras have improved sensors for better, brighter photos in low light.
With Adaptive Fast Charging, the Galaxy Note 4 can go from no battery to 50 percent in about 30 minutes. The device is also equipped with Ultra Power Saving Mode, which offers standby time up to 24 hours on only 10 percent of battery life, allowing access to select applications, so that users have power when they need it most.
https://www.youtube.com/watch?v=dAr_m7GQhpE
Samsung continues to refine the S Pen experience with easier interactions through shortcuts to make everyday tasks faster and easier. With the evolved S Pen, writing is more natural, allowing users to easily handwrite e-mails and texts, capture and edit meeting notes and post handwritten notes to their homescreen. The S Pen also offers the ease and precision of a computer mouse, making it simpler to select and move content, resize windows, and drag and drop between apps.
https://www.youtube.com/watch?v=3P4UNcTS6Bg
With the Galaxy Note 4’s 5.7-inch screen, the Multi Window feature has evolved for easier multi-tasking. Users can choose how to access applications with full, split or pop-up screens, and can easily change the size and positioning of apps on the screen with an intuitive swipe.
The Galaxy Note 4 features a new sleek design with a premium metal frame and Samsung’s signature removable back cover for easy access to the removable battery and microSD card slot.
https://www.youtube.com/watch?v=Tv7C4e8thv0
Price and Availability
The Galaxy Note 4 will be available October 17, 2014 in Charcoal Black and Frost White from AT&T, Sprint, T-Mobile, Verizon and U.S. Cellular for $299 with 2-year contract or $749 without contract depending on carrier.
Pre-order the Samsung Galaxy Note 4 between September 19th and October 16th and get a guaranteed total trade-in of $200 on any working smartphone. For more information, visit www.SamsungGalaxyPromotions.com/Note4.
https://www.youtube.com/watch?v=j0lvuDAgvi4
Specifications:
Processor 2.7 GHz Quad-Core Processor
Display 5.7 inch (143.9mm) Quad HD Super AMOLED (2560 x 1440)
OS Android 4.4.4 (KitKat)
Camera Rear Facing: 16 Mega pixel Auto Focus camera with Smart OIS
Front Facing: 3.7 Mega pixel camera with f1.9
Rear Facing Camera: HDR (Rich tone), Selective Focus, Rear-cam Selfie, Beauty face, Virtual Tour Shot, Shot & More, Dual Camera
Front Facing Camera: Selfie, Wide Selfie
Video Codec: H.264, MPEG-4, H.263, VC-1, WMV7, WMV8, Sorenson Spark, MP43, VP8
Recording & Playback: up to UHD
Audio Codec: MP3, AAC/AAC+/eAAC+, WMA, AMR-NB/WB, Vorbis, FLAC
Ultra High Quality Audio (~192KHz, 24 bit) support
S Pen Optimized Features Air Command (Action Memo, Smart Select, Image Clip, Screen Write)
S Note, Snap Note, Direct Pen Input
Additional Features Multi Window
Voice Recorder (Normal Mode, Interview Mode, Meeting Mode, Voice Memo)
S Health 4 3.5
Dynamic Lock Screen
Built in Heart Rate Monitor
Google Mobile Services Chrome, Drive, Photos, Gmail, Google, Google+, Google Settings, Hangouts, Maps, Play Books, Play Games, Play Newsstand, Play Movie & TV, Play Music, Play Store, Voice Search, YouTube
Connectivity WiFi 802.11 a/b/g/n/ac (HT80) MIMO PCIe
GPS / GLONASS / Baidu
NFC, Bluetooth v 4.1 (BLE,ANT+)
IR LED (Remote Control), USB2.0, MHL 3.0
Sensor Gesture, Accelerometer, Geo-magnetic, Gyroscope, RGB,IR-LED
Proximity, Barometer, Hall Sensor, Finger Scanner, UV, Heart Rate Monitoring, SpO2 (Dependent on market)
Memory 32 GB Internal5 memory + micro SD slot (up to 128GB)
3GB RAM
Dimension 153.5 x 78.6 x 8.5mm, 176g
Battery Standard battery, Li-ion 3,220mAh, Adaptive Fast Charging
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
