HDTV 4K & 8K TV
Samsung’s S95C 77-inch QD-OLED TV Is Available For Pre-Order
The Samsung QN77S95C 4K QD-OLED TV made quite an impression at CES 2023 and this 77-inch panel is finally available for pre-order.
Samsung QN77S95C QD-OLED 77-inch 4K TV Front
Following their TV announcements at CES 2023, Samsung has revealed the pricing and availability of the the 77-inch QN77S95C 4K QD-OLED TV.
What QN77S95C Offers in a Nutshell
With 4K UHD display resolution, the S95C series builds on the foundation of 2022’s S95B models. The feature and specification list for the 77S95C is quite extensive, but the major points are discussed below.
QD-OLED Display Technology
QD OLED TV Diagram
QD OLED TV Diagram
QD-OLED TVs combine Quantum Dot and OLED technology. An OLED layer is placed on the back of the TV that emits blue light. The blue light strikes a layer of quantum dots that convert the blue light to green and red light, while a portion of the blue light from the OLED layer passes through untouched to the screen. With QD-OLED, the need for LED backlighting and LCD display layers is eliminated.
Tip: Although Samsung Marketing labels QD-OLED TVs as OLED TVs, traditional OLED TVs do not include Quantum Dots. Check out all the details on OLED TV technology.
Video Processing/HDR
2023 Samsung HDR10+
The custom-designed Neural Quantum Processor is designed to deliver extended brightness, vivid color mapping (Quantum HDR OLED+), and smart 4K upscaling with AI detail restoration. The HDR10,10+ and HLG formats are supported
Tip: Samsung TVs do not support Dolby Vision
Gaming Support
Samsung Gaming Hub TV
The S95C incorporates a 0.1-millisecond response time and up to 144Hz refresh rate. Cloud gaming support via the Gaming Hub for NVIDIA GeForce NOW, Microsoft Xbox, Utomik, and Amazon Luna is included.
Smart Features
Samsung Tizen Smart Hub TV
On the smart side of things, the QN77S95C incorporates Samsung’s Tizen-powered Smart Hub which provides access to all major streaming services as well as additional streaming apps that can be installed via the Samsung App Store. In addition, Samsung TV Plus is also included, providing direct access to almost 250 add-supported channels of news, sports, and entertainment content.
Samsung TV Plus Free TV Channel Guide
The QN77S95C also includes a built-in Samsung SmartThings Hub. The Hub automatically synchs compatible devices (Samsung and approved third-party products) for easy control.
The SmartThings Hub includes 3D Map View, which displays a bird’s eye view of the home and all connected devices at a glance. SmartThings can even help monitor the home’s energy use  screen or a mobile device via the SmartThings app.
Thin Design
The 77-inch S95C is also extremely thin (less than 0.5 inches thick).
Samsung QD-OLED TV Side
The QN77S95C’s Infinity One Design features an attachable Slim One Connect Box. Instead of connecting everything to the TV, you connect all your sources to the One Connect Box and then use a single thin connection to the TV. This means that are only two cables connected to the TV, the one from the external box and a power cord.
Samsung S95C One-Connect Box
Audio
Despite being so thin, Samsung states that this set still has built-in a 70W 4.2.2 channel sound system with upfiring speakers for Dolby Atmos.
2023 Samsung Dolby Atmos
Another audio feature provided is Q-Symphony (ver 3.0). This allows the built-in TV speakers to be paired with Samsung Q-Series and S-Series soundbars so that they are combined for a fuller TV audio listening experience.
2023 Samsung Q-Symphony
SolarCell Remote
Samsung Solar Cell Remote Control
The S95C even comes with a SolarCell remote that can be charged via light or via a USB-C connection.
Pricing and Availability
The Samsung 77” OLED S95C TV is priced at $4,499.99 at Samsung.com with free professional installation ($120 value).
It is also available at authorized retailers including Amazon, Best Buy, Crutchfield, and others nationwide beginning February 27, 2023.
Samsung QN77S95C QD-OLED 77-inch 4K TV Angle
Tip: In addition to the 77-inch QN77S95C, 55 and 65-inch S95C versions are also forthcoming. There will also be two additional sets (55 and 65 inches) with the S90C designation which are a rebrand of the 2022’s S95B QD-OLED TVs
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Ask an Expert
If you can't get picture or sound from your TV or projector don't despair. Here are some debugging tips from our resident home theater...
Netflix expands its viewing flexibility by embracing HDR10+, but there are a couple of catches.
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HDTV 4K & 8K TV
At 85 or 98-inches, the top-of-the-line 2025 TCL X11K 4K TVs boast 6,500 nits, 14,000 dimming zones and HALO Control Technology.
HDTV 4K & 8K TV
There's a new OLED TV in town and it's sure to be a top contender for best TV of 2025.
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
