Salamander Designs Ships Premium Mounts, Accessories for Flat-Panel TVs
New Dyno, PilotMotion, Flexo, Plano, Luna Ceiling and Zoom Desk Mounts Plus Synchro Accessories Deliver Stylish, Maneuverable A/V System Support
BLOOMFIELD, CT, June 24, 2008 — Salamander Designs, Ltd., a leading designer and manufacturer of modern furniture, seating and mounting products for Home Theater and A/V entertainment systems, announces the availability of more than 20 new premium high-performance TV mounting systems and accessories.
The new TV mounts shipping this month to dealers include models from all categories of Salamander Designs’ broad new line. They include two new highly articulated Dyno Mounts plus a Universal TV Mounting Adapter, two new remote-controlled PilotMotion Wall Mounts plus a Tabletop model, four new Flexo Mounts, three new Plano Mounts, two new Luna Ceiling Mounts, two new Zoom Desk Mounts, and four new Synchro accessories — two glass wall shelves, and two cable managers.
The new mounts deliver advanced, flexible solutions that make it easy to integrate display components with Salamander Designs’ acclaimed modular A/V furniture systems. Or suspend components from the ceiling with Luna Series models. Or atop a desk with the Zoom Desk models. Or at eye-level on a table or sideboard with its Tabletop option. Effortlessly maneuverable, the mounts and accessories provide elegant, sturdy, reliable, space-saving support for all varieties and sizes of plasma and LCD flat-panel displays.
Designed to perfectly marry form and function, the TV mounts are as easy on the eye as they are to tilt, rotate or otherwise adjust. They combine high performance with precision engineering, dedication to detail, and innovative support solutions that reduce complexity without sacrificing quality. The TV mounts use premium materials, multiple castings, and extruded aluminum. Models in all the series are available in small, medium and large sizes, with some also available for extra-large displays.
Dynamic Designs
Salamander Designs’ Dyno Series consists of three dynamic, articulating wall mounts. Multiple arms, a hinge and ball joints assure maximum flexibility, allowing screens to be simultaneously rotated, tilted and pivoted, eliminating the issue of on-screen light reflections. Weightless ZeroForce Tilt mechanisms ensure effortless maneuverability. Additional features include a clip for cable management, and extensive wings for mounting flexibility. The Dyno 102 Small’s single-stud assembly allows it to be installed in corners.
The Dyno 102 Medium supports up to 100 pounds, making it ideal for 23-42 inch flat-panel screens. It swivels 30 degrees left and right, 15 degrees up and down, and integrates well with Salamander’s Synchro Wall Cover to create a distinctive home cinema environment with all cables hidden. The Synchro Wall Shelf can be added for a finishing touch and to store A/V equipment.
The PilotMotion Series consists of two motorized wall mounts and one tabletop mount that respond to instructions from supplied remote controls. All feature a quiet, smooth rotator mechanism employing an innovative, patented design. Weightless ZeroForce Tilt mechanisms on the two wall mounts allow effortless maneuverability as the mounts respond to remote-control instructions to rotate the screen up to 25-30 degrees to the left or right.
The PilotMotion 100 TableTop also features a black glass base with a black steel support column for cable storage. It provides maximum screen flexibility for tabletop use with flat-panel TVs from 32 to 52 inches with a maximum weight of 110 lbs. The remote-controlled mount rotates up to 30 degrees left and right, offers three height adjustments, and includes a universal mounting-hole pattern. The programmable remote can be pre-set to a favorite screen position.
Flexible Solutions
The Flexo Series consists of five sleek, low-profile wall mounts capable of tilting as needed using weightless ZeroForce Tilt mechanisms. An advanced click system makes it safe and easy to install TVs, and a pull-cord release makes removing TVs equally easy. Additional features include an anti-theft lock, extensive wings for maximum mounting flexibility and, in some models, the ability to accommodate speakers.
The Flexo A/V 200 XL, for example, is a universal wall-mount system with fully integrated A/V capability. It can support most large flat-panel TVs from 42 to 65 inches, up to 175 lbs., as well as most on-wall left, right and center-channel speakers. A Lift-n-Load feature simplifies installation and angle adjustment.
The Plano Series consists of four low-profile wall mounts. An advanced click system makes it safe and easy to install TVs on the mounts, and a pull-cord release makes removing a TV equally simple. Additional features include an anti-theft lock, and extensive wings for maximum mounting flexibility.
The Luna Ceiling Series consists of five dynamic, articulating flat-panel mounts ideal for any room in which a ceiling-mounted display is needed. They are capable of 360-degree screen rotation, offered in single and dual arrangements, and provide solid support with heavy-duty aluminum posts. Double arms and an extra hinge point maximize flexibility, and eliminate light reflections for optimal viewing comfort. The mounts’ heights are easily adjusted, and a clip is included for easy cable management
The Luna Ceiling 100 Small is a single-pole model ideal for bedrooms. It accommodates 13 to 26-inch flat-panel TVs weighing up to 40 lbs. An extra hinge-point allows screen placement in a variety of positions, a rotary assembly allows screen height to be easily adjusted, and VESA Extension Wings allow a mounting range up to 200 by 200 millimeters.
The Luna Ceiling 200 is available in medium and large versions as both a single- and dual-screen mount. Its aluminum post features brushes along the edge for clean and simple cable management. The Luna Ceiling Projector 200 supports up to 30 lbs. and features three and four-hole mounting.
Form + Function
The Zoom Desk Series consists of one single-screen and one dual-screen desk mount, each capable of 360-degree screen rotation. Double arms and an extra hinge-point offer maximum flexibility, eliminating the problem of on-screen light reflections for optimal comfort. The screens’ heights are easily adjusted. Additional features include a secure desk clamp, and a clip for cable management.
Synchro Series accessories include the Synchro 100 Wall Cover and the Synchro 100 Wall Shelf. The Wall Cover is a cable manager that guides and conceals cables extending from any Salamander Designs mount. It is constructed of extruded, highly finished aluminum, and easy to install. The Wall Shelf is designed to support the peripherals that are a part of any Home Theater. Constructed of tempered glass with an aluminum assembly plate, it works with any Salamander Designs mount and the Wall Cover to create a distinctive entertainment environment.
Dealer Advantages
The new support systems offer important advantages to dealers, custom installers and consumers. The designs are simple, yet innovatively engineered with great attention to detail. Their innovative engineering, refined design and attention to detail comprise a family of refined, aesthetically pleasing products. More sculptural than structural in appearance, the mounts’ smooth, curvilinear forms conceal the sharp edges characteristic of competing mounts, and enhance the visual elegance of high-performance displays.
The line-up of styles and sizes has been carefully drawn to accommodate the greatest number of TVs without presenting so many SKUs to stock as to become confusing and unwieldy. On the sales floor, they provide all-in-one solutions to dealers who also offer A/V cabinetry, such as the 600-plus that carry Salamander Designs’ Chameleon, Synergy and Archetype furniture systems. Since mounting systems are necessary accessories in the sale of most flat-panel displays, they present similar advantages to dealers carrying plasma and LCD TVs. And they allow both dealers and custom installers to conduct more business with their established vendors.
Salamander Designs’ TV mounting systems and accessories are available now from authorized dealers at suggested prices ranging from $59 for a Plano 100 Small Mount to $599 for the PilotMotion 100 TableTop Mount.
About Salamander Designs
Salamander Designs, Ltd. is a leading developer, manufacturer and marketer of modern furniture, storage, seating and mounting systems for contemporary Home Theater and A/V entertainment systems. Its versatile, advanced products bridge the gap between home furnishings and home electronics with an unstinting dedication to quality, and a broad range of solutions employing the simple, refined lines of modern design. Salamander’s A/V furniture lines — the Chameleon Collection, the Synergy System and the Archetype System –accommodate virtually any design preference and A/V requirement. Its handsome Home Theater seating can be similarly customized with a variety of materials, styling options and accessories, and its new mounting systems for plasma and other flat-panel displays make them easier than ever to integrate with A/V furniture or independently mount onto a wall or ceiling. Salamander Designs was founded in 1992 in Hartford, Connecticut, and is now based in Bloomfield. For further technical information, visit Salamander’s Web site at www.salamanderdesigns.com
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
