Russound’s AVA2.1 and AVA3.1 Mini AVRs Offer A lot of Power for Unique Installations: CEDIA 2023
If you are looking for a compact and thermally designed and optimized AVR for outdoor spaces, bathrooms, or guest bedrooms, the Russound AVA2.1 and AVA3.1 might be very good options.
Russound AVA2.1 Mini AVR Front Angle
You are probably wondering what a “Mini AVR” actually is and why anyone would require one. Russound has announced the AVA2.1 and AVA3.1 Mini AVRs and we think there is a definite need for them in the CI market.
While the majority of current AVRs on the market offer the ability to power multiple zones, very few consumers actually use that feature for something other than a pair of loudspeakers in an adjacent room.
More sophisticated multi-room audio installations often include multiple multi-channel amplifiers, a rack of sources and a central controller that is connected to keypads in every designated room. While that can create a very satisfying integration of audio, video, lighting, security, and HVAC control in your home — it also comes with a rather hefty price tag.
Russound AVA2.1 Mini AVR with mounting bracket
Not everyone has the budget for that or requires that level of integration.
But what about consumers who want a separate audio system outside on the deck or in a Four Seasons Sunroom that includes in-ceiling loudspeakers and an Outdoor TV?
How about consumers that want to integrate in-ceiling or in-wall loudspeakers in a moist environment like a bathroom? Products like the Russound AVA2.1 or AVA3.1 take up very little space and can be hidden inside a bathroom vanity or even behind the wall; consumers can stream audio from a smartphone to either model and not have to worry about moisture affecting the amplifier.
Russound AVA3.1 Mini AVR Front Angle
Russound AVA3.1
Custom integrators can also connect external digital sources to the AVRs using the included digital inputs; cable boxes, streamers, and Smart TVs with optical or HDMI ARC outputs.
The two models are sized the same measuring only 7.7” x 5.5” x 1.7”. They differ in their number of audio channels, either offering 2.1- and 3.1-channels of audio output. These highly flexible receivers can be placed in nearly any imaginable space, including outdoors when used with a weatherproof box.
“These are the AVRs our customers asked for,” says Charlie Porritt, CEO, Russound. “The AVA2.1 and AVA3.1 are ultra-compact, high-performance AVRs designed to fit nearly anywhere, including behind the wall. They’re a boon for custom specialists who need flexible, reliable audio solutions that are easy to install and hide out of sight.”
Russound AVA2.1 Rear
Russound AVA2.1
Russound AVA3.1 Rear
Russound AVA3.1
Both the AVA2.1 and AVA3.1 include a fully integrated, highly efficient class-D amplifier with digital inputs and power output up to 150 watts, 110-240V 50/60Hz universal power supply, built-in Bluetooth 5.0, ARC HDMI, a dedicated subwoofer output with gain control, bass and treble adjustments, a 3.5mm analog output for connection to an outboard amplifier, and an IR remote control with an external receiver.
Russound Remote Control for AVA2.1 and AVA3.1
In addition, the thermally designed and optimized enclosure is designed for use in reduced ventilation spaces such as behind the TV boxes, and the HDMI input allows for immediate use with any TV via HDMI’s CEC functionality, eliminating the need to teach IR commands for volume control, thereby simplifying and speeding up installations.
Adds Mr. Porritt: “The AVA2.1 and AVA3.1 are important products for Russound and our dealers, and they are indicative of the direction we’re taking in our 57th year. The market will continue to see us introduce new and innovative high-performance audio products through next year, most of which are designed with direct input from our customers.”
For further information about Russound, visit: russound.com.
Related: See more coverage from CEDIA Expo 2023
2026 Jamo HYG 5 WiFi Speaker Dark Grey Lifestyle
Jamo's $399 HYG 5 WiFi speaker offers Qobuz Connect, TIDAL Connect, AirPlay 2, Google Cast and three active drivers in a Scandinavian design.
2026 Triangle Borea BR05 Stand-mount Loudspeakers 2026 Triangle Borea BR05 Stand-mount Loudspeakers
Triangle’s Borea BR05 combines retro styling, an 8-inch woofer, and serious cabinet engineering. Who decided bookshelf speakers had to be so small?
Moon 341 Integrated Amplifier Black Angle Moon 341 Integrated Amplifier Black Angle
2026 Audiolab PPA7 Phono Preamp Black LIfestyle 2026 Audiolab PPA7 Phono Preamp Black LIfestyle
Audiolab's $699 PPA7 phono preamp adds MM/MC support, Bluetooth, USB recording and a headphone amp. Is this the ultimate vinyl hub for modern listeners?
2026 T+A Solitaire T Pro Wireless Headphones 2026 T+A Solitaire T Pro Wireless Headphones
T+A Solitaire T Pro adds Dolby Atmos, aptX Lossless and premium DAC technology, but are luxury wireless headphones becoming too expensive?
2026 Vinnie Rossi Canta Integrated Amplifier Angle 2026 Vinnie Rossi Canta Integrated Amplifier Angle
Vinnie Rossi’s $23,995 CANTA Integrated challenges high-end amplifier conventions with 6SN7 tubes, MOSFET power, and an unconventional design.
JBL Synthesis rolls out 4 new in-wall speakers, 4 in-room speakers, 2 AV preamps, 1 AVR and 1 subwoofer. Is this the cleanest system-level...
Editors’ Choice 2025: The best in-wall and in-ceiling speakers for home theater and whole-home audio—reference-level performance, properly installed.
In-Wall Speakers
KEF expands its Extreme Home Theater line with the THX-Certified Ci5120QLM-THX and Ci3120QLM-THX in-wall speakers, priced at $1,699.99 and $1,299.99 each.
Denon's latest A/V Receiver offers 11.4 channels of amplification and 13.4 channels of audio processing as an AV preamp. Coming early 2024.
In-Wall Speakers
Theory Audio Design shows that you can put together a fine-sounding home theater system - or whole home music system - for a whole...
At Audio Advice Live 2025, hear Focal's $150K+ home theater, $69K wireless speakers and its full line of headphones. Prepare to drool.
In-Wall Speakers
The Focal Utopia CINEMA LCR and Subwoofer are designed for luxury home theater set-ups in large spaces.
Ask an Expert
A professional installer reveals everything you need to know about installing in-ceiling speakers for Dolby Atmos height effects or music.
