HDTV 4K & 8K TV
Runco Takes Plasma Displays To New Heights–Literally
UNION CITY, CALIFORNIA — May 18, 2004 — Runco International, the world leader in high-end home theater video display technology, announced the introduction of two new plasma display monitors that are going places plasma is only starting to venture–high altitudes.
“We are excited to offer people living at altitudes of up to 9,000 feet above sea level the state-of-the-art home theater experience they ought to have,” said Bob Hana, president of Runco. “Our plasmas produce lifelike, high definition images that make watching movies truly immersive–and they’re beautiful to look at in and of themselves. Our high-altitude models offer unparalleled signal processing power, broad source connectivity options, and refined designs that simplify the challenges of custom installation. The Runco team is proud to put those benefits in the high up homes of theater enthusiasts who don’t want to compromise the quality of their viewing experience.”
Runco’s two newest plasma displays will enhance the existing line of available models that address the needs of high altitude applications. Joining Runco’s CinemaWall CW-42i and CW-61, and the PlasmaWall PL-61cx, the new high altitude models are among the few plasma display products capable of high altitude performance.
The PlasmaWall PL-50XA and CinemaWall CW-50XA, have been specifically designed for use in high altitudes and mountainous regions that have traditionally been off-limits to plasma technology. With 50-inch widescreen viewing areas and depths of less than 4 inches thin, these plasmas offer the engineering benchmarks found in every Runco plasma display. Perfect for wall mounting or used with stylish tabletop stands, each model makes an ideal centerpiece for an elegant custom home theater.
Both the PL-50XA and CW-50XA boast a high definition resolution of 1365 x 786, and a comprehensive selection of inputs including a DVI digital input with HDCP, which enables a pure digital signal path for optimum image quality from a variety of sources. These plasmas employ Runco’s VirtualWide mode for converting 4:3 images to fill the 16:9 screen without losing any image integrity. The PL-50XA also takes advantage of Runco’s advanced Vivix video processing technology and the signature PFP controller. Simplified installation is attained with all inputs connecting to the rack-mountable controller and only one basic connection between the controller and display. The CW-50XA uses internal Runco video processing including 3:2 film detection circuitry to reproduce real cinema quality. Additionally, each plasma provides an IR and RS-232 interface for simple integration with home automation control systems.
Specifications for the PL-50XA 50-inch High Altitude Plasma Display Monitor:
Native Resolution:1365 x 768
Screen Size: 50″ diagonal
Screen Aspect Ratio: 16:9
Available Aspect Ratios: 4:3, Letterbox, 16:9 Anamorphic, VirtualWide
Image Area (W x H): 43-1/3″ x 24-1/2″ (1106mm x 622.30mm)
DTV Compatibility: 480p, 720p, 1080i
Inputs: (2) Composite Video (1-BNC, 1-RCA); (2) Component Video (1-BNC, 1-RCA); (1) S-Video, (1) RGB (15-pin mini D-sub); (1) RGB via BNC, (1) DVI w/HDCP; (1) RS-232C, (3) Stereo jacks
Power Requirements: 100-120VAC, 50/60 Hz
Power Consumption: 480W
Operating Environments: 32&#186-95&#186F (0&#186-35&#186C), 20-80% Humidity (non-condensing)
Dimensions: 49-1/4″W x 3-15/16″D x 30-1/8″H / (1251mm x 100mm x 765.20mm)
Weight: 96 lbs. (44 kg)
Safety Regulations: FCC15B class B
Limited Warranty: (3) years parts and labor from the date of delivery to the end user, (1) year parts and labor on the plasma glass panel from the date of delivery to the end user
MSRP: $15,995
Availability: Now Shipping!
Specifications for the Vivix PFP Controller (Included with the PL-50XA):
Video Standards:NTSC/PAL
Outputs: Native Resolution of 768p, HD pass-through up to 1080p
Inputs: (1) composite, (1) S-Video; (1) Component, and (1) Pass-through
Control Options: Infrared (with discrete on/off, aspect ratio and source selection), RS-232 and Front Panel
Screen Trigger/Masking Outputs: (2) 12V DC, 1/8A
Bandwidth: Video Inputs: 5.5 MHz, Pass-through: 100 MHz
Power Requirements: 100-240V AC (auto sensing), 50/60 Hz, 15W
Operating Environment: 41&#186-95&#186F (5&#186-35&#186C), 0-90% humidity, non-condensing
Dimensions (w/out feet): 17-1/2″W x 16″D x 3-1/2″H / (444.5mm x 406.4 mm x 88.9mm)
Weight: 16 lbs
Included Accessories: Rack mounting brackets
Regulatory Approvals:Complies with FCC Class B, CE, C-Tick
Limited Warranty: (2) year parts and labor warranty from date of delivery to the end user
Specifications for the CW-50XA 50-inch High Altitude Plasma Display Monitor:
Native Resolution: 1365 x 768
Image Area (W x H):43-1/3″ x 24-1/2″ (1106mm x 622.30mm)
Inputs: (2) Composite Video (1-BNC, 1-RCA);(2) Component Video (1-BNC, 1-RCA); (1) S-Video, (1) RGB (15-pin mini D-sub); (1) RGB via BNC, (1) DVI w/HDCP; (1) RS-232C, (3) Stereo RCA jacks
Operating Environments:32&#186-95&#186F (0&#186-35&#186C), 20-80% Humidity (non-condensing)
Dimensions: 49-1/4″W x 3-15/16″D x 30-1/8″H (1251mm x 100mm x 765.20mm)
MSRP: $12,995
* Specifications are subject to change without notice.
About Runco
Founded in 1987 and currently headquartered in Union City, California, Runco International is a market leader in state-of-the-art projection systems, flat-panel plasma monitors, video processors and other components for the consumer market. Runco’s innovations have won numerous awards and citations from the world press. Runco was the first company to introduce and market a line doubler with a multi-frequency projector in 1990 and also introduced the first multiple-aspect-ratio controller, the ARC-IV, to the Home Theater market. Recently, both of these features have become essential for the new digital high definition capable televisions.
Digital Images are available on request. Contact Marketing Matters at 954-925-1511 or veronica@marketingmatters.net.
CinemaWall, PlasmaWall, VirtualWide, Vivix PFP are registered trademarks of Runco International.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
