Runco Takes Home Theater to the Xtreme With New DLP Projection System
World Class Video Projector and Processor Package Hits Production Lines, Establishes the Next Level for Home Entertainment Realism
UNION CITY, CALIFORNIA — June 29, 2004 — Runco International, the world leader in high-end home theater video display technology, steps into the future once again with the introduction of the Video Xtreme VX-2c Projection System. This revolutionary high definition imaging technology, with forward-thinking engineering, is the first to deliver a native 16:9, 3-chip entertainment experience to a variety of home theater environments. Packaged with the new, Next Generation ViVix II DHD Digital Controller, which features advanced digital processing and expansive connectivity, the VX-2c package sets a higher standard for home video excellence. The Video Xtreme VX-2c Projection System is now shipping worldwide.
The VX-2c breaks new ground among DLP projectors by offering a 3-chip configuration with 16:9 (1280 x 720) native resolution for home theater applications. As the first consumer projector manufacturer licensed by Texas Instruments for DLP, Runco and its engineers built on an exclusive store of experience to implement the technology in the VX-2c. The team designed the projector’s optical light engine around 3 of TI’s HD-2 Digital Micromirror Devices, eliminating the need for a color wheel–reducing mechanical complexity–and achieving superior clarity, color saturation, and contrast.
“The Video Xtreme VX-2c Projection System is a thrilling achievement for the Runco team and is exciting news for discriminating home theater enthusiasts,” said Bob Hana, president of Runco International. “Our design approach continuously seeks to raise standards for video reproduction, and with the VX-2c System, we brought innovation to each aspect of its performance. Pairing our world-renowned projection and signal processing technology, this new video display package represents the next level in what can be expected for state-of-the-art home theater.”
Using Runco’s own industry-recognized Cinema Standards Measurement System (CSMS), the VX-2c achieves a light output of 1,199 Home Theater ANSI Lumens, 52.1 foot-Lamberts (2,500 ANSI Lumens), and a CSMS contrast ratio of 271:1 (3,100:1 ANSI). CSMS incorporates the respected Imaging Science Foundation’s (ISF) calibration standards and measures performance in a simulated home theater environment that has been adopted by independent video technology testers and custom installers seeking to provide the finest quality picture.
In designing the VX-2c, Runco has built a projector that not only reproduces superior images but offers a new level of installation flexibility. Using Runco’s smallest 3-chip chassis ever–measuring just 8-1/8″ high–it puts a captivating picture where many 3-chip projectors simply can’t be installed. Six lens options (five zoom lenses and one for rear screen projection) make the VX-2 highly adaptable within restrictive installations and fit for screens up to 250 inches wide. A vertical shift of 60% down and 24% up for ceiling-mounted configurations is available from all zoom lenses, and a horizontal shift from 10% to 16% depending on which lens is used.
The VX-2c is also the world’s first projector to include Runco’s exclusive new LiveLink technology. This technology, developed by Runco engineers, is the only existing solution today for transmitting DVI pure digital signals over long distances. Typically, high-definition digital video signals can only be transmitted through DVI cables for a few meters without losing quality, but the VX-2c allows 720P and 1080i digital signals to be sent along its DVI cable up to 75 feet without any degradation of signal quality or bandwidth.
The Video Xtreme VX-2c Projection System includes the all-new Digital High Definition (DHD) Digital Video Controller, which provides the industry’s leading image processing, scaling and aspect ratio control, plus expansive connectivity to guarantee future compatibility. It individually tailors signals reaching the VX-2c from each source and its VirtualWide feature converts 4:3 images to 16:9 screens without losing any image integrity—-yet requires only a single cable to connect to the VX-2c. The DHD Controller features eight inputs and field-upgradeable software that lets installers download new features on the job, guaranteeing performance always matches the most cutting-edge sources. It produces three 12V DC trigger signals to activate third party components like motorized screen lifts and drapes, features IR capability and an RS-232 interface for control via home automation systems.
Specifications for the Video Xtreme VX-2c Video Projector
Projector Type: Digital Light Processing, 3-chip HD-2 Digital Micromirror Device
Native Resolution: 1280 x 720 (16:9)
Scan Frequency: Horizontal: 15 — 100 KHz, Vertical: 28 — 78 Hz
Recommended Screen Size: Width: 72 — 120 in.; maximum width: 250 in.
Throw Distance: Lens Option 1: Zoom 1.20–1.40 x width
Lens Option 2: Zoom 1.40–1.77 x width
Lens Option 3: Zoom 1.77–2.35 x width
Lens Option 4: Zoom 2.35–3.60 x width
Lens Option 5: Zoom 3.60–5.70 x width
Lens Option 6: 0.95 x width (rear-screen applications)
Light Output: CSMS Specifications: 1,199 Home Theater ANSI Lumens;
52.1 Foot-Lamberts (fL); 2,500 ANSI Lumens
Contrast Ratio: CSMS Contrast Ratio: 271:1; 3100:1 ANSI
Lamp: 275W UHP
Lamp Life: 2000 hours @ 6500&#186 Kelvin
Controller Interface: (1) DVI Connector
Dimensions: 19-3/16″W x 26-7/16″D x 8-1/8″H w/out feet; 9-3/4″H w/ feet
Weight: 81 lbs. (without lens)
Specifications for the DHD Digital Controller (Included with the VX-2c)
Aspect Ratios: Anamorphic, Letterbox, VirtualWide, 4:3 (16:9 or 4:3 screens)
Input Standards: NTSC/PAL
Outputs: (1) HD – RGB, H, V; (1) DVI w/HDCP
Output Resolution: 720p
Inputs: (1) Composite, (2) S-Video, (1) Component (480i or 576i),
(2) RGBHV/Component HD, (2) DVI Digital w/HDCP
Control Options: Discrete infrared remote, (2) RS-232, (1) 9-pin connector,
(1) RJ-11, front panel controls
Trigger/Masking Outputs: (3) 12V DC, 1/8A
Bandwidth: 150 Mega Samples/Second (MSPS)
Dimensions (w/o feet): 17-1/2″W x 11-3/16″D x 3-3/4″H
Weight: 13 lbs.
Included Accessories: Rack mounting brackets
System MSRP: $39,995
Availability: Now Shipping
About Runco
Founded in 1987 and currently headquartered in Union City, California, Runco International is a market leader in state-of-the-art projection systems, flat-panel plasma monitors, video processors and other components for the consumer market. Runco’s innovations have won numerous awards and citations from the world press. Runco was the first company to introduce and market a line doubler with a multi-frequency projector in 1990 and also introduced the first multiple-aspect-ratio controller, the ARC-IV, to the Home Theater market. Recently, both of these features have become essential for the new digital high definition capable televisions. For more information on Runco International, visit www.runco.com.
Digital Images are available on request. Contact Marketing Matters at 954-925-1511 or veronica@marketingmatters.net.
Video Xtreme, ViVix II, Digital High Definition (DHD), Cinema Standards Measurement System (CSMS), VirtualWide and LiveLink are trademarks of Runco International. Digital Light Processing, DLP and DMD are trademarks of Texas Instruments.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
