Runco QuantumColor Q-650i LED Home Theater Projector
Runco announced the new QuantumColor Q-650i lampless LED home theater projector, claiming 70 percent power savings and no maintenance. In addition, the Q-650i pairs QuantumColor's technological advancements, like Runco SmartColor and InstantOn, to create an energy-efficient system without using mercury or lead that delivers must-see projection performance. This combination makes the Q-650i the perfect solution for dedicated theaters with a 72-92-inch screen.
The Q-650i maximizes LED performance and offers the same award-winning color gamut from their more expensive projectors. When paired with Runco's proprietary technologies that harness the impressive color gamut, the Q-650i creates stunning images while offering an environmentally friendly theater experience for less than the cost of a large, flat panel display.
Price and Availability
The Runco QuantumColor Series Q-650i projector features integrated video processing and will begin shipping August 30, 2011 for $9,995.
Specifications
Model (Family) Q-650i (QuantumColor Projectors)
Projector Type Digital Light Processing (DLP), Single-Chip, 16:9 SuperOnyx DMD with InfiniLight Illumination
Native Resolution Full HD, 1920 x 1080
Aspect Ratios 16:9, 4:3, Letterbox, Virtual Cinema
Video Standards HDMI and DVI with HDCP for digital video, Component and RGB HDTV (1080p, 1080i, 720p), Component and RGB EDTV (576p, 480p), Component, Composite and S-Video SDTV (576i, 480i), RGB SCART with adaptor, NTSC (M, 4.43), PAL (B, G, H, I, N, M), SECAM (M)
Picture Size (16:9 Screens) Recommended Width: 72 – 92 in.
Maximum Width: 108 in.
Throw Distance Factor x Screen Width Lens Options with Standard Lens: 1.85 – 2.40:1
Short Throw options: 1.56 – 1.86:1
Horizontal & Vertical Offset Vertical: Up to 60% of screen height down/up
Horizontal: Up to 12.5% of screen width left/right
Light Output CSMS Specifications: Home Theater Calibration: 450 ANSI Lumens; 16.3 Foot-Lamberts (fL); 540 ANSI Lumens; Light output will drop less than 10% over the life of the product.
Contrast Ratio CSMS Contrast Ratio 330:1; 3 settings: Infinity:1; 20,000:1; 10,000:1 (sequential) ColorContrast. Colors have up to 50% higher contrast than Mercury or Xenon lamp systems.
Illumionation System RGB InfiniLight LEDs for 135% NTSC color gamut with Runco Smart Color and Personal Color Equalizer
Maintenance Zero maintenance, solid state optical path
Inputs (2) HDMI; (2) Component (RCA, BNC); (1) RGB (HD15); (1) S-video; (1) Composite; (1) RS-232; (1) IR Repeater
12V Output 2 programmable
Power Requirements 100V – 240V AC, 50/60 Hz, 90-250W variable (140W typical use)
Operating Environments Temperature: 50-104 °F (10-40 °C)
Humidity: 0-85% relative humidity (non-condensing)
Regulatory Approvals FCC Part 15 Class B, CE Class B, UL, cUL, CB, RoHS, WEEE, local conformances as required
Limited Warranty Projector: (2) Two years parts and labor from the date of shipment from Runco. Extended RuncoCare, Red Carpet, and PremierCare also available.
Video Compatibility 480i, 480p, 576i, 576p, 720p, 1080i 50/60, 1080p 24/50/60
Dimensions Width: 20.8 in. (529mm)
Length: 22.5 in. (572mm)
Height: 9.1 in. (231mm) (excluding feet)
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
