Runco Lifestyle LS-100d LED DLP Projector
Runco announced the LightStyle LS-100d with NEAR (Next generation Extreme Aligned Reflection) ultra-short throw (UST) lens projection system. Delivering 92-inch diagonal image that fits any setting, the LS-100d combines unsurpassed performance and clever industrial design with an attractive price point. At a depth of only 18-inches, the projector can be mounted above or below for installation flexibility. Now homeowners have an affordable option for amazing in-home entertainment that offers a bigger and more compelling viewing experience over a flat panel TV. The result is an unsurpassed visual experience that must be seen to be understood.
LS-100d maximizes the benefits of Runco's critically-acclaimed InfiniLight lampless LED illumination technology, resulting in 70 percent power savings and a lampless system with no maintenance. The InfiniLight system is calibrated at every start-up and the perceived brightness advantage of this architecture, an effect called “Q-lumens”, is even more pronounced after 1,000-2,000 hours of ordinary use. It's much quieter than large format displays that often have industrial-strength fans to maintain operating temperature.
And, the LS-100d includes Runco's upgraded, award-winning Digital High-Definition (DHD4) external video processor, whose Digital Compass capability makes perfect geometry possible. The DHD4 offers the most advanced alignment in Runco history, allowing for ultra-precise installation geometries and more extreme installation scenarios, ensuring that the whole solution works as an integrated system.
Runco Lifestyle LS-100d LED DLP Projector - front
The LightStyle product line as a whole offers the greatest range of brightness and image performance for different rooms and viewing styles. Its small form factor makes transportation and installation easy, an ideal solution for efficient, high-rise living. For eco-conscious customers who are concerned with the power draw of a projector, studies have shown that an 85 or 103-inch plasma display can use up to eight times the power consumption of a LED projector.
Runco's advanced Vivix digital video processing is included to enhance picture quality from standard video sources, as well as provide artifact-free scaling. Also included are discrete input source, aspect ratio, power on/off, HDMI input and an RS-232 interface for seamless integration with automation control systems.
Features
  • Runco's revolutionary lampless InfiniLight LED projector
  • Fixed NEAR lens delivers the industry's shortest throw distance
  • Offering the largest color gamut and Runco's Personal Color Equalizer proprietary color management for stunning realism
  • Stylish design with Runco performance, the LightStyle series are designed for both performance and esthetics, that makes transportation and installation easy
  • Integrated and external DHD video processor and scaler with Runco's Vivix processing
Price and Availability
The Runco Lifestyle Series LS-100d will be available December 2011 for $19,995.
See more about: Projectors, DLP Projectors, LED Projectors, Runco Projectors
Specifications
Model (Family) LS-100d (LightStyle Projectors)
Projector Type Digital Light Processing (DLP), Single-Chip, 16:9 SuperOnyx DMD with InfiniLight Illumination
Native Resolution Full HD, 1920 x 1080
Aspect Ratios 16:9, 4:3, Letterbox, Virtual Cinema as enabled by included DHD4 processor
Video Standards HDMI and DVI with HDCP for digital video, Component and RGB HDTV (1080p, 1080i, 720p), Component and RGB EDTV (576p, 480p), Component, Composite and S-Video SDTV (576i, 480i), RGB SCART with adaptor, NTSC (M, 4.43), PAL (B, G, H, I, N, M), SECAM (M) as enabled by included DHD processor
DTV Compatibility 480i, 480p, 576i, 576p, 720p, 1080i 50/60, 1080p, 24/50/60
Throw Distance Factor x Screen Width Standard Lens:
0.18-1 (to mirror)
Projector housing sits 22-62mm from screen
Horizontal & Vertical Offset Vertical: Up to 83% of screen height down/up fixed
Horizontal: 0% measured on a 1.0 gain, 84″ 16:9 screen
Light Output CSMS Specifications: Home Theater Calibration: 350 ANSI Lumens; 12.7 Foot-Lamberts (fL); 600 ANSI Lumens; Light output will drop less than 10% over the life of the product.
Contrast Ratio CSMS Contrast Ratio 330:1; 3 settings: Infinity:1; 20,000:1 (sequential) ColorContrast.
Colors have up to 50% higher contrast than Mercury or Xenon lamp systems.
Illumination System RGB InfiniLight LEDs for 135% NTSC color gamut with Personal Color Equalizer
Maintenance Zero maintenance, solid state optical path
Inputs (2) HDMI; (2) Component (RCA, BNC); (1) RGB (HD15); (1) S-video; (1) Composite; (1) RS-232; (1) IR Repeater
Power Requirements 100V – 240V AC, 50-60Hz, 320W variable (240W typical use), standby power <1W
Operating Environments Temperature: 41-104°F (5-40°C)
Humidity: 10-85% humidity (non-condensing)
sea level to 10,000 feet at 77°F (25°C)
Regulatory Approvals FCC Part 15 Class B, CE Class B, UL, cUL, CB, RoHS, WEEE, CCC local conformances as required
12V Output 2 programmable
Picture Size (16:9 Screens) Recommended Width: 77 – 86 in.
Maximum Width: 86 in. Lambertain screen (1.0 gain, white) required
Dimensions Width: 17.12 in. (435mm)
Length: 15.94 in. (405mm)
Height: 6.18 in. (157mm)
Weight 27.5 lbs (12.5 kgs)
Limited Warranty Projector: (2) Two years parts and labor from the date of shipment from Runco. Extended RuncoCare, Red Carpet, and PremierCare also available.
QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
WiiM Sound Lite Smart Speaker in white WiiM Sound Lite Smart Speaker in white
WiiM's original smart speaker sheds features to hit a lower price point ($229) for those who can live without a touch display and voice...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
