Powerful RKM-1 and MRP-64 Duo Debut
EDEN PRAIRIE, MN–September 20, 2007–Remote Technologies Inc, the leading control systems manufacturer, announced today the release of the new RKM-1 Multi-Room Audio Keypad and MRP-64 Multi-Room Control Processor. The RKM-1 and MRP-64 merge advanced technologies to create a revolutionary new way to distribute audio. These products collectively have the ability to take full advantage of the multi-zone capabilities built into most of today’s sophisticated surround receivers.
“We are very excited about the introduction of the MRP-64 as a great example of our clear focus to develop revolutionary new control solutions for the Professional Integrator” said Pete Baker, Vice President of Sales and Marketing for RTI. “With the RKM-1 and MRP-64, consumers benefit from the flexibility of being able to bi-directionally control almost any multi-zone receiver or distributed audio system. Together these products provide users with a superior control system and a great solution for distributing audio at a terrific value.”
The MRP-64 acts as an interface between multi-zone audio/video receivers and RTI in-wall or handheld controllers, giving consumers the ability to create a dynamic audio distribution system at an affordable price. With the MRP-64 all of the audio/video sources from the media room can now be easily distributed and accessed anywhere in the home. This compact unit features six keypad ports for RTI in-wall controllers, four independent IR output ports, three voltage trigger outputs, three voltage sense inputs and an IR signal input. Additionally the unit is equipped with an Ethernet port for control and programming, two-way RS-232 communication, support for Zigbee wireless communication, and other expansion capabilities. This unit is compatible with all RTI in-wall and handheld controllers and industry standard IR repeater systems and requires no special programming. The MRP-64 will be available 1st Quarter of 2008 with an expected price of $699.00.
Key Features:
Expands virtually any home theater/multi-zone receiver into a distributed audio system
Six keypad inputs to provide power and communication
Two RS-232 ports for bi-directional communication
Compatible with RTI Zigbee Transceiver Module for two-way communication
Programmed RS-232 drivers for popular multi-zone receivers
Three programmable 12VDC trigger outputs.
Three assignable voltage sense inputs
IR input for IR pass-through or control
Four addressable IR emitter ports are compatible with industry standard IR emitters and repeater systems
One addressable high IR output for connecting additional IR connecting block/emitters
All output ports incorporate both short-circuit and overload protection
Variable power on all IR output ports
Programmed using TheaterTouch Designer software
Non-volatile Flash memory stores your system configuration even when power is not present.
USB and Ethernet programming
RTI’s new RKM-1 has a clean, elegant style and is perfect for multi-room audio control. The intuitive keypad was designed for flush-mount installations in walls or cabinets. Its open architecture and TheaterTouch Designer software make the RKM-1 an easy to program device. Sized for a single gang electrical box, the product incorporates eight fully-programmable hard buttons and a customizable LED film which provides feedback of power status, selected source, and volume control. The RKM-1 control port connects to one of the six keypad ports on the MRP-64 to control devices from up to 1000 feet away. When used with the RTI automation devices, it is capable of infrared routing, relay control, power sensing and RS-232 communications for advanced control. The RKM-1 will be available 1st quarter of 2008, with an expected price of $149.00.
Key Features:
Provides feedback for multi-zone receivers via the MRP-64 Control Processor
Use any standard Decora type faceplate
Fits in single gang electrical box
Eight selectable sources
Backlit volume level indicator
Open architecture allows control of virtually any audio/video component
Non-volatile Flash memory stores our system configuration even when power is lost
IR output can transmit signals up to 1,000 feet away over standard CAT-5 cable for standalone control
Optional modules for voltage and video sensing
Field upgradeable firmware
USB programming
Talking Points
RTI releases the RKM-1 Multi-Room Audio Keypad and MRP-64 Multi-Room Control Processor.
RKM-1 provides feedback from multi-zone receivers via the MRP-64 Control Processor
MRP-64 expands a home theater/multi-zone receiver into a distributed audio system.
RKM-1 and MRP-64 will be available in the 1st quarter of 2008.
About Remote Technologies Inc.
Remote Technologies Incorporated (RTI), headquartered in Eden Prairie, Minnesota, is the leading manufacturer of innovative, sophisticated, yet user friendly control systems. RTI’s wide array of elegant hardware and software solutions are marketed exclusively through the custom installation channel.
RTI was founded in 1992 with a committed focus on the custom installation market. This unwavering commitment was expanded and formalized in March 2007 with RTI’s C2C (Committed to Custom) initiative which includes expanded tech support hours, enhanced training through both its Advanced Control University (ACU) and in the field, and the C2C orientation will inform and shape every aspect of RTI’s continued evolution. C2C highlights RTI’s dedication to the custom installation market, making it the leader in creating wireless hardware and software control solutions that effectively address the challenges facing electronic systems installers and integrators.
RTI’s belief in offering its products exclusively through custom dealers and trained professional integrators is a guiding passion, centered on the customization of any size home theater or other electronic system. The company’s design philosophy emphasizes an intuitive and enjoyable experience in using its award-winning products, from its universal system controllers, to signal storage and processing devices, and PC programming software.
For additional information on RTI and all its innovative products please visit www.rticorp.com.
