In-Wall Speakers
RSL Speakers W25E Angled In-Wall/Ceiling Speakers are Perfect for Dolby Atmos
At just $199 each, the RSL W25E are making it super affordable to get an in-wall/ceiling Dolby Atmos home theater speaker system. Angled drivers provide installation flexibility.
RSL Speakers W25E Reference In-Wall/Ceiling Speakers with and without grille
One of the problems with traditional front-facing in-wall speakers is they project sound straight-out that is often off-axis from the listener; which can impact sound quality. For example, your center channel speaker could be mounted too low or too high, while your left/right speakers could be too far apart.
Getting in-wall speakers pointed at the listening area is generally ideal, but not often easy without a custom build-out. RSL Speakers is solving this problem by introducing a new in-wall/ceiling speaker that’s angled 15-degrees inside the housing so it can still mount flat just like a regular in-wall.
RSL Speakers W25E Reference In-Wall Speakers Angled View
RSL Speaker Systems today has just started shipping its new W25E Reference In-Wall loudspeaker for $199 each. However, you would be wrong to confuse its low price with low quality.
Based out of Southern California, RSL only sell factory-direct and keep their costs low by manufacturing overseas.
The RSL W25E Reference in-wall speakers can be used as any speaker within a home theater speaker system. Use them wherever as left, center, right, surround, or even overhead as Dolby Atmos height speakers. However, RSL does also offer a dedicated in-ceiling speaker for $50 less called the C34E MKII. It’s angled as well for installation flexibility. Both RSL architectural models also feature the same tweeter and matching mesh grilles.
RSL Speakers W25E Reference In-Wall Speakers Mounting Height
W25E Key Features
  • Universal L/C/R/Surround channel optimization
  • Laterally-aligned asymmetrical mirrored baffling
  • Adjustable tweeter swivel alignment and attenuation
  • Mineral-filled woven textured poly-cone with butyl-rubber surround
  • Audiophile-grade crossover components
  • Edgeless magnetically attached grille design
  • Cut-out template and paint shield included
  • Design allows for both Horizontal or Vertical mounting within standard 2×4 construction
W25E Specifications
  • Woofer: Dual 5 ¼” Woofers with High-Energy Ferrite Magnets, Woven textured Mineral-Filled Poly-Cones, Butyl Rubber Surrounds, and High-Strength Cold-Rolled Stamped Steel Frames.
  • Tweeter: 22mm (7/8”) Treated-Fabric Exposed Dome Swivel Tweeter with Neodymium Magnet
  • Frequency Response: 48Hz-20,000 Hz ± 3dB
  • Recommended Impedance setting for amplifiers: 6 or 8 ohms
  • Sensitivity: 91dB SPL
  • Recommended Power: 35–175 Watts
  • Crossover Frequency: 3,200Hz
  • Crossover Slope: Asymmetric 12/6dB per octave
  • Crossover Parts: Proprietary, Low Insertion-Loss Lami-Core and Air-Core Inductors, RSL Poly Capacitors, Non-Inductive Resistors, Gold-Plated Spring-Loaded Binding Posts, FR-2 PCB
  • Tuning Method: Infinite Baffle
  • System Resonance: Application Dependent
  • Weight: 7.6 lbs.
  • Shipping Weight: 9.2 lbs.
  • Dimensions: (Overall): Depth  4”, Width  9⅞”, Height 14”.
  • Dimensions: (Mounting): Depth 3¾” , Width 8⅞”, Height 13”
In addition, RSL has recently been going after the budget home audio category hard. They are most famous for their best selling, budget-priced Speedwoofer 10S subwoofer. But they also just introduced new bookshelf and center speakers for $105 / $149 each called the RSL CG3M and CG23M speakers.
RSL Speakers W25E Reference In-Wall Speakers without grille
Price & Availability
The RSL Speaker W25E Reference In-Wall Loudspeaker is available now for just $199 at rslspeakers.com.
Tip: Use code W25EBFCM to get $20 off the W25E before Cyber Monday (November 28, 2022).
About RSL Speaker Systems
RSL Speaker Systems, also known as Rogersound Labs, started manufacturing and selling specialty loudspeakers in the early 1970s through its numerous Southern California retail locations. As the industry’s original “Factory-Direct” speaker company, RSL continues this tradition today via its direct-to-consumer model, where its speakers are now available exclusively through their website, rslspeakers.com. This factory-direct tradition offers an unmatched value proposition that includes free shipping and a free trial period without the expense of a “middle-man” associated with products sold through conventional retail distribution.
1 Comment
1 Comment
  1. Ryan West
    June 23, 2023 at 8:13 pm
    Would these be powerful enough to act as solid L/Rs in a 20×30 room?, where they’re mounted on the 20 foot side?
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
In-Wall Speakers
The Focal Utopia CINEMA LCR and Subwoofer are designed for luxury home theater set-ups in large spaces.
In-Wall Speakers
DALI expands its architectural product line with the Phantom M80 A In-Ceiling Speaker and CI AMP-4750 4-Channel DSP Amplifier.
Our favorite in-ceiling and in-wall speakers and subwoofers for distributed audio and home theater will be heard, but not seen.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
Ask an Expert
A professional installer reveals everything you need to know about installing in-ceiling speakers for Dolby Atmos height effects or music.
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
Looking for the best bookshelf or stand-mounted speakers below $1,000? We've awarded 10 loudspeakers that have impressed us enormously.
