Roth Audio Sub Zero Soundbar Announced
Roth Audio introduced the Sub Zero sound bar, which aims to transform disappointing TV sound, but without breaking the bank, keeping ease-of-use in mind. Designed to fit with 32-inch to 42-inch screens, the Sub Zero use a ClassHD amplifier to power a pair of built-in ultra bass drivers. The speaker driver array numbers eight in total, two of which are vector firing side drivers, delivering enhanced stereo as well as dramatic, wide-firing FX (Fractal Expansion) sound effects.
The Sub Zero accepts digital audio from an optical input, or analog audio using RCA stereo inputs. A 3.5mm mini jack is also available for connecting older style TVs as well as the latest smartphones.
The Sub Zero comes bundled with a remote control, which enables sound adjustments directly from your listening position. A table stand and wall brackets are included. As an added touch, the front panel LED display is dimmable.
Price and Availability
The Roth AV Sub Zero is available in the UK now £149.00, including VAT. Roth also makes the BAR 1 sound bar which comes bundled with a wireless subwoofer.
Roth Sub Zero Soundbar
Specification
  • Product Type: TV Soundbar
  • Drivers: 6 x 40mm long throw full range, 2 x 19mm aluminum dome tweeters
  • Power, 64 watts peak (32W x 2), 32 watts RMS (16W x 2) High Power Class HD amplification
  • Connectivity: 1 x optical, 1 x twin RCA, 1 x 3.5 stereo jack
  • Dimensions: 790x105x89mm (WHD)
  • Weight: 3.1Kg
  • Finish: Satin black
  • Frequency Response: 35-20,000Hz
  • Included: Table stands, Wall brackets, Remote control
See more soundbars.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
