Rotel RDD-1580 USB DAC
Rotel just announced the RDD-1580 USB Digital-to-Analog Converter that offers the finest audio reproduction possible from any digital source whether it be legacy PC sources or the latest digital file formats.
At its heart, the RDD-1580 makes use of Wolfson’s WM8740 stereo digital-to-analog converter. But where competitive products use only one of these converters to handle two channels, the RDD-1580 uses dual WM8740s in a complementary configuration which reduces noise and distortion well beyond what a single converter can provide.
Another RDD-1580 advantage lies in its input flexibility. A front panel USB input that supports Apple iPod, iPhone, and iPad as well as streaming via Bluetooth with the included adapter. The rear panel PC-USB input will support files up to 24 bit/192kHz in asynchronous mode. Two sets of rear panel RCA-style coaxial and TOSlink optical digital inputs are optimized for LPCM data streams. This includes CD’s 16-bit/44.1 kHz standard to high definition sources with 24-bit/192 kHz audio data.
As you might expect, a Rotel designed and manufactured toroidal transformer sits at the foundation of the RDD-1580’s well-regulated power supply in a full size 1U chassis. Advanced custom designed Slit-Foil capacitors provide electrical storage capabilities that ensure substantial and stable operating voltages and current to feed the critical circuit stages.
The carefully tuned analog section is another example of Rotel’s award-winning Balanced Design approach in which specifications alone do not dictate which electronic parts are selected. Rather, extensive listening tests are carried out under controlled conditions to determine the optimal choices. During this time the entire circuit is carefully tuned to provide musically true signal reproduction. After this, the entire circuit is tuned to extract the most sonically accurate signal possible.
The RDD-1580 provides both single-ended and balanced outputs with RCA and XLR connections respectively.
Recognizing today’s changing tastes in audio sources, the RDD-1580 even provides high-current charging capability (2.1 amperes) for an iPad or similar device to reduce clutter and increase needed desk space even while expanding your audio source options.
Built for stunning sound quality and designed for today’s increasingly complex digital world, the RDD-1580 offers a first rate combination of superior sonics and convenience.
Price and Availability
The Rotel RDD-1580 USB DAC will be available November 2013 in Matte Black or Brushed Silver finish for $799.
1 Comment
1 Comment
  1. Geoff Hughes
    January 21, 2014 at 4:18 pm
    Does anyone know wen this DAC will be in stores?
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
With support for 32-bit/384kHz PCM, DSD and aptX HD, the Rotel DX-3 cuts down on the number of components you need for headphone listening...
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
The Best Audiophile CD Players of 2024 include Hegel, Luxman, Marantz, Rotel and more for the ultimate in compact disc playback.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
CD Players
At $6,999, the Rotel Michi Q5 is a high-end CD player with additional functionality as a transport and DAC.
With analog only inputs, the Rotel A8 is an entry-level Class AB integrated amplifier with bass and treble controls.
Does the brand new Rotel A12MKII Integrated Amplifier deliver the sonic goods for $1,100? Indeed it does.
