CD Players
Rotel RCD-1570 CD Player
Rotel RCD-1570
Rotel just announced a thousand dollar CD player, model RCD-1570, for audiophiles, which offers careful refinements to reveal even the most subtle nuances buried in a CD’s pit spiral. One of its most important features is the Wolfson WM8740 digital filter/stereo digital-to-analog converter. Originally developed for high-resolution sources, it is the product of extensive research and real-world testing and processes digital signals up to 24-bits in length at sampling rates from 8kHz to 192kHz.
While word lengths and sampling rates may seem excessive for CDs delivering data at far lower rates, this high-speed facility adds reserve capability to ensure proper reproduction under all circumstances. As the most crucial link between a CD’s digital data and the analog world in which we listen, this converter boasts significant attributes in addition to its superb high-resolution capabilities. Two digital filter modes allow choice of roll-off characteristics while flexible connections permit adding additional filter modes calculated to bring CDs to life in ways not easily appreciated until they’re auditioned.
Another advance is the RCD-1570s slot-loading disc transport. In addition to mechanical simplicity and improved reliability, this design isolates the CD itself from potentially destructive vibration modes that may affect musical definition. And from a purely aesthetic viewpoint, it adds elegance by simplifying the front panels appearance.
The post-converter analog circuitry benefits from Rotel’s decades-long experience in crafting the finest sounding pathway from the D/A’s internal output to single- and double-ended rear panel connectors that bridge the gap between the RCD-1570 and down-stream components. All circuit components—resistors, capacitors, inductors—are chosen only after their positive contribution to sound quality were quantified and verified qualitatively by extensive listening sessions.
All of these circuits draw on a power supply based on an oversized custom Rotel designed and precision-manufactured toroidal power transformer that, in turn, feeds precise rectifiers, tight-tolerance voltage regulators, and advanced Slit-Foil low-ESR storage capacitors, all globally-sourced to ensure musically accurate operation under even the most demanding conditions.
XRL connectors provide balanced outputs, long recognized for their superior noise-rejecting characteristics while high quality RCA connectors provide an easy pathway to the myriad of components with single-ended inputs.
Price and Availability
The Rotel RCD-1570 CD Player will be available May 2013 for $999.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
With support for 32-bit/384kHz PCM, DSD and aptX HD, the Rotel DX-3 cuts down on the number of components you need for headphone listening...
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
The Best Audiophile CD Players of 2024 include Hegel, Luxman, Marantz, Rotel and more for the ultimate in compact disc playback.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
CD Players
At $6,999, the Rotel Michi Q5 is a high-end CD player with additional functionality as a transport and DAC.
With analog only inputs, the Rotel A8 is an entry-level Class AB integrated amplifier with bass and treble controls.
Does the brand new Rotel A12MKII Integrated Amplifier deliver the sonic goods for $1,100? Indeed it does.
