Rotel RA-1592 Stereo Integrated Amplifier Announced
Rotel just introduced the RA-1592 stereo integrated amplifier, which combines elements of the RC-1590 preamplifier and RB-1582mk2 power amplifier into a sleek, single chassis design. The company says they have not cut corners. The RA-1592 implements a classic Class AB design with 200 watts per channel into 8 ohms, and features a rugged power supply with a massive toroidal transformer, coupled to select T-network, slit-foil capacitors. The result is a power supply that won’t sag and distort under complex speaker loads or dynamic signal transients.
The high performance preamplifier section incorporates a superb 32bit 768KHz AKM digital-to-analog converter and analog stages of the highest quality. The DAC and surrounding circuitry supports a vast array of source inputs including DSD capable PC-USB (24bit/192k), 3 coaxial, 3 optical, integrated aptX Bluetooth and a front mounted USB iPod input. For analog music lovers, there is a phono stage input (MM), XLR balanced input and 3 analog RCA source inputs.
Rotel RA-1592 Stereo Integrated Amplifier - Back View
User selectable A-B speaker outputs with 5-way binding posts, RCA pre-output and dual subwoofer outputs provide the ultimate flexibility in installation. The amplifier protection circuits monitor DC offset, overcurrent, short circuit and temperature to protect both the electronics and attached speakers.
Custom integration features include RS232 and Ethernet IP control, 2 trigger outputs, remote IR input and automated digital signal sense power control for easy integration with streaming sources and control systems.
Rotel says the new RA-1592 stereo integrated amplifier provides an optimal solution for hearing a musical performance the way the artist intended, whether its from modern digital sources or classic analog vinyl recordings.
Price and Availability
The Rotel RA-1592 Integrated Amplifier is available now for $2,499.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
With support for 32-bit/384kHz PCM, DSD and aptX HD, the Rotel DX-3 cuts down on the number of components you need for headphone listening...
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
The Best Audiophile CD Players of 2024 include Hegel, Luxman, Marantz, Rotel and more for the ultimate in compact disc playback.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
CD Players
At $6,999, the Rotel Michi Q5 is a high-end CD player with additional functionality as a transport and DAC.
With analog only inputs, the Rotel A8 is an entry-level Class AB integrated amplifier with bass and treble controls.
Does the brand new Rotel A12MKII Integrated Amplifier deliver the sonic goods for $1,100? Indeed it does.
