Rotel’s DX-5 is a Compact Audiophile Integrated Amp with a High-Performance DAC
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle
Following the recent release of the DX-3 DAC/Headphone Amp, Rotel has added a new entry into its product line, the DX-5 Stereo Integrated Amplifier.
It has a similar exterior look as the DX-3, but the DX-5’s sleek cabinet houses a class A/B amplifier that can deliver 33 Watts/channel into 4 ohms or 25 Watts/channel at 8 ohms. Powered by a custom-built toroidal transformer and high-current transistors, it delivers pristine highs, a detailed midrange, and deep bass. The onboard ESS ES9039Q2M Sabre DAC supports ultra-low noise (100 dB SNR) and an extended frequency response of 10Hz to 100kHz (±0.19 dB), ensuring exceptional clarity and resolution.
The DX-5 provides flexible wired connectivity that includes Coaxial/Optical (24-bit/192kHz), RCA analog, and HDMI ARC (great for TV audio) inputs as well as a subwoofer output and a headphone jack for private listening.
The DX-5 offers PC-USB connectivity with support for 32-bit/384kHz PCM and DSD audio formats. In addition to its wired inputs, it features Bluetooth with aptX HD and AAC codec support for high-quality wireless streaming. The DX-5 is also Roon Tested certified, ensuring seamless integration with Roon’s music management platform.
The DX-5 provides precision volume control (0.5dB steps, 680 mV sensitivity) and features a full-color TFT display and an aluminum remote, blending style with intuitive operation.
Specifications
Rotel DX-5 Integrated Amplifer Front View
Rotel Model DX-5
Product TypeIntegrated Amplifier
Price (US)$1,499
Number of Channels2
Analog Inputs1 (pr) x RCA
Analog Output1 x Subwoofer
Power Output (FTC)2 x 25 W
Maximum Power Output (Non-FTC)33 W / ch, (1k Hz, 4 Ω)
Continuous Power Output (Non FTC)25 W / ch (1k Hz, 8 Ω)
Total Harmonic Distortion< 0.03%
Intermodulation Distortion< 0.03%  (60 Hz : 7k Hz, 4:1)
Frequency Response 10 Hz – 100k Hz (0 ± 0.19 dB)
Damping Factor140 (20 Hz – 20k Hz, 8 Ω)
Input Sensitivity / Impedance680 mV / 100k Ω
Input Overload  4.2 V
Signal-to-Noise Ratio> 100 dB  (IHF “A” weighted)
Digital Inputs 2 x SPDIF (coax, optical) LPCM (up to 24-bit / 192k Hz )
1 x HDMI-ARC
1 x PC-USB  USB Audio Class 2.0 (up to 32-bit / 384k Hz ) Driver installation required
Frequency Response 10 Hz – 80k Hz   (0 ± 2 dB, Max)
Input Sensitivity / Impedance -10.3 dBFS / 75 Ω
DSD/DoP SupportDSD (up to 4X, 11.2M Hz)
DoP (up to 2X, 5.6M Hz)
Bluetooth Yes
Roon TestedYes
Wireless Remote ControlYes
Power Requirements 120 V, 60 Hz (USA)
230 V, 50 Hz (Europe)
Power Consumption 80 W
Standby Power Consumption < 0.5 W BTU (4 Ω, 1/8 power)  241 BTU / h
Dimensions (WxHxD)  215 x 76 x 251 mm
8 1/2” x 3″ x 10”
Front Panel Height70 mm / 2 3/4”
Weight (net)4.1 kg (9.1 lbs)
Finish Black, Silver
Rotel DX-5 Integrated Amplifier Top Inside
Rotel DX-5 Integrated Amplifier Rear Connections
The Bottom line
While nearly identical in appearance to the DX-3, the Rotel DX-5 upgrades the amplification to support loudspeaker connections and adds HDMI ARC and a dedicated subwoofer output. However, with just 25 watts per channel into 8 ohms, it may require pairing with efficient speakers to achieve higher listening volumes.
Price & Availability
The Rotel DX-5 will be available through authorized dealers and online retailers in North America, Europe, and the UK in April 202,5, with the rest of the world to follow soon after. Suggested Retail Pricing for the US is $1,499.
4 Comments
4 Comments
  1. Anton the Unimpressed
    April 8, 2025 at 6:55 pm
    Did Rotel give up? How does one go from the Michi series to that?
    • Ian White
      April 8, 2025 at 7:14 pm
      Different price pont. But I’m not a fan of the industrial design either.
      IW
  2. Nate
    April 9, 2025 at 1:18 pm
    Just wondering with all the choices out there now from other companies like WiiM, Technics, and NAD for the same price point .. with streaming apps included why should I pickup the DX5? Does the A/B amp really sound better than a D? Currently rocking an older Onkyo 775D with Q Acoustic speakers and it seems fine …at less than 1/2 the price of this DX5, any thoughts ?
    • Ian White
      April 9, 2025 at 2:20 pm
      Nate,
      Class D has come a long way and it is certainly more efficient. Personally, I’m a Class A/B person and still don’t hear the resolution and texture from a comparable Class D amplifier at the same price points. I’m really not sold on this Rotel — I’ve reviewed 5 of their amplifiers in recent years (all very positive) and this is the one I’m least likely to consider. I have WiiM and NAD in my personal systems and the control apps are very good. That matters now.
      I also own 5 different pairs of Q Acoustics loudspeakers and nothing has been better with them than Cambridge Audio, Naim, NAD or Unison Research. All Class A/B amplifiers.
      The NAD C 316BEE V2 with the WiiM Ultra is not even $800 and would take that over the Rotel without question.
      Best,
      IW
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
With support for 32-bit/384kHz PCM, DSD and aptX HD, the Rotel DX-3 cuts down on the number of components you need for headphone listening...
Advance Paris brings its range of affordable hifi components to the U.S. market, which feature blue VU meters and tube amplification.
Our favorite integrated amplifiers in 2024 include models from Cambridge Audio, Naim, NAD, Unison Research and more.
The Best Audiophile CD Players of 2024 include Hegel, Luxman, Marantz, Rotel and more for the ultimate in compact disc playback.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
Depending on your budget, the $499 NAD C 316BEE V2 might be the ideal stereo integrated amplifier to build a hi-fi system around.
We've been listening to a lot of integrated amplifiers over the past 12 months, and these 4 are some of the best below $3,000.
