Roku SoundBridge 2.7 Software Released
Roku is excited to announce the availability of a new version of software for your SoundBridge. This 2.7 firmware update is free, has some great new additions, and is easy to get.
A simple way to update your SoundBridge is to unplug it, wait 5 seconds, and then plug it back in. After it “boots up” it will automatically check for and offer you a software update. If this does not work for you, use the Software Update menu which you’ll find in “Change Server and System Configuration”. Here’s what’s new in 2.7:
Major new features in 2.7:
  • Streaming from iTunes 7 is now supported on all Roku-branded SoundBridge models.
  • The newer WPA network security standard is now supported on SoundBridge M1001, SoundBridge Radio, and Pinnacle SoundBridge HomeMusic models.
  • The new Daylight Saving Time dates in North America and other parts of the world are now included.
  • Apple Lossless (ALAC) files may now be played natively, without transcoding on the server. [Please note that some ALAC encoders don’t write file information in the expected way, and these files may not play. Files encoded by iTunes should work fine.]
  • Dutch and Italian translations have been added.
Other improvements in 2.7:
  • The audio output level on M1001 has been improved for better matching with other components.
  • The Now Playing screen has been improved with better scrolling of long information. Also, more space is available for song information, thanks to automatic hiding of elapsed time and progress displays when using the largest font, or when playing Internet radio content.
  • Alarms can now be dismissed or snoozed from the remote control. Press pause when the alarm is sounding to snooze, or press Play to dismiss the alarm and leave the music playing.
  • Pressing the snooze bar while a SoundBridge Radio is in standby with the display off will turn on the time display momentarily.
  • The built-in Internet radio station listing has been updated.
  • Playback of music from SD cards on SoundBridge Radio and Pinnacle SoundBridge HomeMusic has been improved. Mac-specific files starting with “._” are automatically skipped, and cards with multiple folders are handled properly.
  • M500 models now display a proper “…” character when text is truncated. M500 models also display additional accented characters for song information, and will display a “box” character instead of a question mark in place of characters that can’t be displayed on the LCD screen.
  • Support has been added for proper detection and automatic skipping of protected WMA content when using the Firefly server.
  • Support has been added for new remote control keys on Pinnacle SoundBridge HomeMusic players.
  • Support for the Nepal Time time zone is now included.
  • Fixed a problem that could cause audio to stop playing from the outputs, even when the content was still streaming normally.
  • Greatly enhanced error reporting and diagnostics code to aid in ongoing stability and performance improvements.
  • Improvements in WMA Internet Radio compatibility.
  • Improved AAC and MP3 codecs for enhanced stability.
  • Various other stability improvements and bug fixes.
  • Improvements in the RCP control protocol.
Updating Your SoundBridge or SoundBridge Radio’s Software
To update SoundBridge software, follow these instructions using your SoundBridge remote control:
  1. Make sure your SoundBridge or SoundBridge Radio is connected to a network with Internet access and powered on.
  2. Press the Menu button on the remote control.
  3. Navigate down to “Change Library or Configuration” and press Select.
  4. Navigate down to “System Configuration” and press Select.
  5. Select “Software Version and Updates”.
  6. You will be shown your current software version and be given the option to check for a software upgrade.
  7. Choose “Yes” to check for software upgrades for your SoundBridge or SoundBridge Radio.
  8. You should see a screen with the progress bar and the message: “Contacting Server…”
  9. You will then see one of the following two screens:
    • “Your Software is Up to Date”. Select ‘OK’ to return to the System Configuration menu.
    • “New Software 2.7 is available. Perform Upgrade?”. Choose “yes” to download and install the upgrade. Once the upgrade completes, you will be prompted to reboot the unit. Once it reboots, it will be running the new software.
Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Hisense S5 DecoTV Front Lifestyle Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
I stream, you stream, here are our choices for the best video streaming devices of 2025.
Dan Mackta of Qobuz answers questions on Reddit on AI, Linux support, app features, and future platform growth.
Roku's budget-friendly 4K streaming stick may not have Dolby Vision or an ethernet port, but for the price, it's hard to beat.
Cyber Monday 2025 delivers huge savings on Audioengine, Denon, SVS, Samsung and more. The best home audio and TV discounts of the year are...
NBC Universal's flagship streaming service is promising live football broadcasts in 4K/HDR with Dolby Atmos surround sound, but will it work on your gear?
A recent study suggests Walmart's CastOS TV operating system may dominate the TV device market by 2029. Here's why that matters.
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
Roku’s OS 14 update adds more features you didn’t know you needed. It’s practical, sleek, and keeps your streaming life just a little more...
