Roksan’s Caspian 4G Series Unveiled: You Don’t Have to Put on Your Red Light
The new Roksan Caspian 4G Integrated Amplifier arrives at $3,750, while the Caspian 4G Streaming Amplifier will set you back $5,000.
Roksan Caspian 4G Integrated / Streaming Amplifiers
The ownership may have changed and their focus broadened to include a lot more than turntables, but it’s hard to think about the iconic British manufacturer and not reminisce about the original Roksan Xerxes. What an amazing deck and challenger to the Linn LP-12. Back to the present and we find that Roksan has announced its new Caspian Series 4G product line.
This new line starts with two entries: The Caspian 4G Integrated Amplifier and the Caspian 4G Streaming Amplifier. In addition, Roksan has also indicated a Caspian 4G Power Amplifier and Preamplifier are coming in 2025.
Roksan’s industrial design for the new Caspian 4G range is rather unique; Battlestar Galactica anyone?
The side panels of the integrated amplifier integrate the heatsinks and the internal layout of the amplifier makes it clear that Roksan runs a tight ship. Parts quality appears to be extremely high.
Roksan Caspian 4G Silver
Rapture DAC Technology
The Caspian Series 4G features Rapture DAC technology which is a differential current-conveyor topology.  This topology provides several advantages over traditional approaches to digital to analog reconstruction using op-amp ICs. The current conveyor has superior gain-bandwidth characteristics essential for accurate high-resolution audio reproduction.
Euphoria Amplification
The Caspian Series 4G builds on Class AB amplifier architecture, which is labeled Euphoria. Roksan has observed that there is more to great sound quality than low harmonic distortion and noise floor.
With the Series 4G, Euphoria prioritizes the intermodulation distortion of its designs – and ensures that the harmonic and intermodulation distortion is flat across frequency and load. This is designed to provide purer, cleaner, and more detailed sound reproduction.
Roksan Euphoria
Analog Pre-Amplifier and Phono Stage​
Caspian Series 4G utilizes a new analog pre-amplifier section designed to make sure audio signals are as clean as possible. Using a balanced design, the Caspian series delivers optimal noise rejection. With a ground-switching input design, cross-talk between connected devices is kept extremely low. This feature builds the technology used in Roksan’s Attessa range.​ Moving Magnet and Moving Coil cartridges are both accommodated.
Ultra-High Resolution Volume Control
With a running debate on whether a digital-based analog-based volume control is best, Roksan has decided to implement a hybrid design for Caspian Series 4G that incorporates elements of both types.
Caspian 4G Remote Control​
Roksan Caspian 4G Remote Control
The Caspian Integrated Amplifier and Streaming Amplifier ship with a Roksan remote control to help users to easily access and operate the basic features of the two amps. The ergonomic, aluminum extruded design is weighted to be comfortable in the user’s hand. The buttons are clear and intuitive.
MaestroUnite
Roksan MaestroUnite App
The app enables users to access advanced configurations such as input configuration, headphone sensitivity, analog input gain, balance and low power standby, and audio preferences.
The app also supports Over-The-Air (OTA) updates and integrates with the Monitor Audio Group products eco-system.
It also features Internal antennas to make placement of the Caspian 4G Series easier.
For those who prefer to use an Ethernet cable, Roksan has included a Gigabit Ethernet RJ45 jack in the 4G Network Amplifier.
Roksan Caspian 4G Integrated Amplifier Silver
Roksan Caspian 4G Integrated Amplifier Back Silver
The Caspian 4G Integrated Amplifier is a two-channel stereo amplifier that provides 105 watts per channel via Euphoria amplifier technologies.
Both analog and digital wired inputs are provided, including a phono connection supported by a phono preamp that supports both MM and MC cartridges.
For digital sources, the amplifier also provides Rapture DAC technology to provide the best possible digital-to-analog conversion needed to supply the speakers with the best possible audio reproduction from those sources.
Roksan Caspian 4G Streaming Amplifier Front Silver
Roksan Caspian 4G Streaming Amplifier Black Rear
The Caspian 4G Streaming Amplifier incorporates the same Euphoria amplifier technology and power output of the integrated amplifier and provides the same analog and digital connectivity, along with Rapture DAC support.
Pro Tip: The Caspian 4G Streaming Amplifier also includes HDMI-ARC/eARC for easy connection to a compatible TV or project for improved audio listening to TV/Movie/Game content. However, since it is a streaming amplifier there are some additional content access and playback features.
The Caspian 4G Streaming Amplifier incorporates BluOS premium multi-room audio streaming. This platform provides users with access to music and the ability to wirelessly stream music with no lag and zero loss in sound quality. ​​With the Caspian Streaming Amplifier, users can enjoy a full whole-home enhanced listening experience. ​
Comparison
Caspian Integrated AmplifierCaspian Streaming Amplifier
Price$3,750$5,000
Power Amplifier TechnologyDual Mono Euphoria AmplifierDual Mono Euphoria Amplifier
Amplifier ClassABAB
Output Power, 8 0hms (235VAC @ 1% THD, both channels driven)2 x 105W2 x 105W
Output Power, 4 0hms (235VAC @ 1% THD, both channels driven)2 x 200W2 x 200W
THD+N (1W @ 1kHz Both Channels driven)<0.007%<0.007%
Gain29dB29dB
Signal to Noise (1W/8R 2Vrms A1, both channels driven)>85dB>85dB
Analog Inputs2x RCA Stereo (A1, A2)
1x Balanced XLR (A3)
Digital Inputs2x Coax (D1, D2)
2x Optical (D3, D4)
Bluetooth Audio
2x Coax (D1, D2)
2x Optical (D3, D4)
Bluetooth Audio
BluOS
HDMI eARC
Analog Outputs1x Balanced XLR (Pre1)
1x RCA Stereo (Pre2)
1x RCA Stereo (Pre3)
1 x Subwoofer
1 x Subwoofer
Speaker Connections1x Pair of Speaker binding posts (L&R)1x Pair of Speaker binding posts (L&R)
Other Inputs / OutputsWi-Fi 4
BLE
12V Trigger
Wired IR
W-Fi 5
Wi-Fi 4
BLE
12V Trigger
 Wired IR
Intelligent DSPYes Yes
Primary Interface (on the unit)Dynamic Control Dial (with haptic feedback) to control volume, inputs & powerDynamic Control Dial (with haptic feedback) to control volume, inputs & power
Secondary Interface (on the unit)N/ABackward, Play/Pause, Forward
Remote ControlBlack, 15-button IR remote. Bead blasted & anodized aluminum extruded case with laser etched logoBlack, 15-button IR remote. Bead blasted & anodized aluminum extruded case with laser etched logo
Power Supply600VA / 36,400uF per Rail600VA / 36,400uF per Rail
Phono InputsMM/MCMM/MC
Gain MM53dB53dB
Gain Adjustment MMLow (-6dB), Mid (0dB default), High (+6dB)Low (-6dB), Mid (0dB default), High (+6dB)
Input Impedance MM47k ohms/100pF47k ohms/100pF
Gain MC73dB73dB
Gain Adjustment MCLow (-6dB), Mid (0dB default), High (+6dB)Low (-6dB), Mid (0dB default), High (+6dB)
Input Impedance MC100 ohms/470pF100 ohms/470pF
RIAA response accuracy MM/MC+-0.3dB 20Hz – 20kHz+-0.3dB 20Hz – 20kHz
DAC TechnologyRapture DAC, Dual Mono BalancedRapture DAC, Dual Mono Balanced
DAC Format SupportPCMPCM
DAC Sampling Rateup to 24bit / 192kHzup to 24bit / 192kHz
Volume Control TechnologyHybrid Digital AnalogueHybrid Digital Analogue
Volume Control Matching<0.25dB<0.25dB
Bluetooth ProtocolsA2DP Audio ProfileA2DP Audio Profile
Bluetooth CodecsSBC, aptX & AACSBC, aptX & AAC
Bluetooth Range>15m>15m
Coax Inputs (D1, D2)up to 24bit / 192kHz (Stereo)up to 24bit / 192kHz (Stereo)
Optical Inputs (D3, D4)up to 24bit / 192kHz (Stereoup to 24bit / 192kHz (Stereo
HDMI ARC & eARCNoYes (HDMI ver 2.0)
Maximum Input Level6.7Vrms6.7Vrms
Music SenseA2 InputA2 Input
AV ModeA2 InputA2 Input
BluOS Streaming SupportedNoYes
Audio FormatsN/AMP3, AAC, WMA, OGG, WMA-L ALAC, OPUS
Hi-Resolution Audio FormatsN/AMQA, FLAC, WAV AIFF, Supports converted DSD playback via the desktop app only
Sampling RateN/Aup to 192kHz
Bit DepthN/A16 – 24 Bits
USBN/A1x Type-A port for connection to USB memory stick (FAT32 or NTFS formatted) and supported peripherals
Supported Operating SystemsN/AMusic playback from network shares on the following desktop operating systems: Microsoft Windows XP, 2000, Vista, 7, 8 to current Windows Operating Systems and macOS versions**
Mobile ApplicationN/AFree BluOS Controller App available for download from the respective App stores of Apple iOS devices (iPad, iPhone, and iPod), Android devices, Kindle Fire, and Windows or macOS desktops
Supported music services and partnersN/AOver 20 natively integrated streaming services. For more information go to https://bluos.io/
Third-Party Certified ServicesN/AApple Airplay, Spotify Connect, Tidal Connect
ROON ReadyN/ATBC (To Be Confirmed)
Control IntegrationsN/ACreston, Control4 (OS3), Control4 (OS2), RTI, URC, BluOS URC Driver, URC, Lutron, NICE, GIRA, BluOS Integration Utility, BluOS Cusomt Integration API
Maestrounite SupportedYesYes
Network ConnectivityBluetooth LE Wi-Fi 4 (Only connects for Over-the-Air Updates)Bluetooth LE Wi-Fi 4 (Only connects for Over-the-Air Updates)
Mobile ApplicationiOS, AndroidiOS, Android
Over-the-Air UpdatesFirmware Updates are available via the Maestrounite-configured Wi-Fi connection. This can be set up to connect & update on user requests or during periods of inactivity.Firmware Updates are available via the Maestrounite-configured Wi-Fi connection. This can be set up to connect & update on user requests or during periods of inactivity.
Wired IR Input5 – 14V, Mono 3.5mm jack plug, any polarity5 – 14V, Mono 3.5mm jack plug, any polarity
12V Trigger Input5 – 14V, 3.5mm jack dual polarity (On / Standby)5 – 14V, 3.5mm jack dual polarity (On / Standby)
12V Trigger Passthrough3.5mm jack Pass-through from input only3.5mm jack Pass-through from input only
Nominal Mains VoltageAuto-Selecting Power Supply, 100-120VAC & 220-240 VACAuto-Selecting Power Supply, 100-120VAC & 220-240 VAC
Power ConsumptionMax 610VA, Standby 0.5W, Network Standby 2W (Standby Plus, allows fast boot)Max 610VA, Standby 0.5W, Network Standby 2W (Standby Plus, allows fast boot)
Available FinishesSilver, BlackSilver, Black
ConstructionExtruded and machined aluminum front & top cover with extruded aluminum heatsinks.Extruded and machined aluminum front & top cover with extruded aluminum heatsinks.
External Dimensions with all accessories fitted (HWD) 93 x 432 x 378 mm
(3 11/16 x 17 x 14 7/8”)
93 x 432 x 378 mm
Weight 15.2 kg
(33 lbs 8 oz)
15.2 kg
(33 lbs 8 oz)
Roksan Caspian 4G Black
Bottom Line
At double the price of Roksan’s Attessa Integrated and Streaming Amplifiers, the new Roksan Caspian 4G series will need to offer a substantial sonic upgrade. However, its unique design along with the simplicity of a single control dial could be enough to interest buyers that may be considering the Cambridge Audio EXN100 Streamer and EXA100 Integrated Amp combo, or the Rotel RAS-5000 or Hegel H400 streaming amps.
Price & Availability
Roksan products are available via Authorized Dealers at the following prices:
  • Caspian Series 4G Integrated Amplifier – $3750 / £3000
  • Caspian Series 4G Streaming Amplifier – $5000 / £4000
For more information: roksan.com
Related Reading
1 Comment
1 Comment
  1. Johnni
    October 12, 2024 at 7:40 pm
    They stopped making the Xerxes 20+. Company has been going downhill since Touraj left and Monitor Audio took over.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
At only $1,499 USD, the Naim CI-Uniti 102 feels like a streamlined Uniti Atom in a pair of skinny jeans.
Our favorite streaming amplifiers of 2024 include models from Cambridge Audio, NAD, Naim, Marantz and WiiM.
Digital Music Systems
At $8,000, the McIntosh MSA5500 streaming integrated amplifier isn't for everybody, but it's hard not to be impressed with its styling and audio technology.
Fell Audio aims to attract British hi-fi buyers seeking retro aesthetics with value driven audio performance from its inaugural £1000 stack.
The Cyrus Audio 40 series hi-fi components includes matching Integrated Amplifier, Streamer, CD Player and Power Supply for $16,480.
Cambridge Audio introduces the EXA100 stereo integrated amplifier for $2,199 and the EXN100 Network Music Streamer for $1,799.
At $1,500, the Marantz 60n is a 60-watt per channel integrated amp that connects to a TV, CD Player, turntable, and streams music.
