Rockport Technologies Announces LYNX Loudspeaker: High End Munich 2024
At $78,000/pair, Rockport LYNX implements trickle down technology from the company’s flagship LYRA loudspeaker for about half the price.
Rockport Technologies Lynx Loudspeaker Front and Rear Angle
Following two years of development, Rockport Technologies has announced its latest entry into the ultra high-end loudspeaker category called the LYNX loudspeaker.
The Lynx is an example of Rockport’s emphasis on full-range loudspeakers that deliver extraordinary musical scale while maintaining a domestically friendly proportion, the LYNX is unrivaled in its ability to convey music’s grandeur from such a surprisingly compact enclosure.
With a ‘form follows function’ design emphasis approach, which incorporates distinctive and functional enclosure designs, the Rockport LYNX features a new DAMSTIF3 enclosure which is formed from a single, massive aluminum casting.
Rockport Technologies Lynx Loudspeaker Front Angle No Grille
Rockport LYNX
From Andrew Payor, Rockport’s founder and Director of Technology: “The LYNX is the first time we’ve been able to trickle down technology from our flagship LYRA to a loudspeaker that will fit comfortably in any home. As with the LYRA, the fundamental absence of enclosure induced noise has a profound effect on the LYNX’s musical presentation, yielding an incredibly low noise floor, unmatched dynamic contrasts, and astonishing low-level information retrieval…Like the LYRA, the LYNX’s new DAMSTIF3 enclosure has no joinery, no fasteners, and simultaneously achieves the multiple goals of maximum damping, stiffness, and mass.
Rockport Technologies LYNX Carbon Fiber Sandwich Composite  Woofer Construction
As a successor to Rockport LYRA, the drive units incorporated in the LYNX include a custom 10 inch, carbon fiber sandwich cone woofer, a 6-inch carbon fiber sandwich cone midrange, and a 1-inch waveguide-loaded beryllium tweeter.
Rockport Technologies LYNX 1-inch Beryllium Tweeter
The Lynx’s driver array is designed to deliver an authoritative, first-octave bass response with abundant headroom and agility, a transparent midrange, which brings out densely saturated tonal colors and texture, with a crystalline pure, dynamically realistic high-frequency register.
Tech Note: The Lynx also incorporates a rear-mounted port to provide additional bass support.
The LYNX’s visual impact is the result of its tailored design. Delivering quality sound across all musical genres, the LYNX opens the door to the wide world of recorded music.
Rockport Lynx vs Lyra Loudspeakers
Rockport LYNX (left) vs LYRA (right) Loudspeakers
Comparison
LynxLyra
MSRP$78,000/pair$190,000/pair
Type3-Way Bass Reflex3 ½ way Bass Reflex
Woofer(1) 10” carbon fiber sandwich composite(2) 10” carbon fiber sandwich composite
Midrange(1) 6” carbon fiber sandwich composite(2) 6” carbon fiber sandwich composite
TweeterWaveguide mounted 1” beryllium domeWaveguide mounted 1” beryllium dome
Height48”53.50”
Width12.40”14.10”
Depth23.40”26.50”
Weight (each)305 lbs560 lbs
Frequency Response?20 Hz – 30 KHz
Nominal Impedance?4 ohms
Sensitivity?90 dB SPL/2.83 v
Minimum Amplifier Power?30 watts
Tech Note: Full specifications (Frequency response, etc…) have not been provided.
Rockport Technologies LYNX Loudspeaker Rear Connections
Rockport LYNX
Price & Availability
The LYNX was on display at High End Munich 2024 along with a sample of the one-piece raw aluminum casting used to make the cabinet. It is available from Authorized Rockport dealers in Europe, Asia, South America, the USA, and Canada. The US price is $78,000/pair.
Continue reading more stories from HIGH END Munich 2024
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Hi-Fi Components
Goer Dynamics will expand the distribution of Gryphon Audio Designs into Asia and open up opportunities in the luxury car audio sector.
Audiophiles owe themselves a listen to Craft Recordings Original Jazz Classics Series of new Miles Davis vinyl reissues.
Ready to dive into the dark, twisted world of film noir? Check out the 20 best films, plus where to grab the sharpest Blu-ray,...
While Record Store Day (RSD) is over for now, Mark Smotroff reports on his scores, some of which you still may be able to...
