Car Amplifiers
Rockford Fosgate Prime R250-1D, R500-1D, R125-2, R250-4 Car Amplifiers
Two New Class D and Two New Class A/B Amps Designed for High Power with a Small Footprint for Installs that Require Big Output From Little Space
Rockford Fosgate announced four new affordable Prime Series car amplifiers, which include R250-1D and R500-1D mono block amps and the new R125-2 2-channel and R250-4 4-channel Class A/B amplifiers.
“We’re pleased to be able to offer better efficiency in our Prime mono-block amps through the implementation of Class-D circuitry,” explained Theresa Hephner, Rockford senior director, products and marketing. “The new R250-1D and R500-1D mono block amps provide the same high power as their predecessors with greater thermal longevity, built into a smaller chassis that will fit wherever the customer desires.”
Rockford Fosgate R250-4 Car Amplifier
Also new for 2012 are the R125-2 2-channel and R250-4 4-channel Class A/B amplifiers. “Based upon Prime’s affordable yet reliable reputation, the R125-2 and R500-4 take the multi-channel, small footprint amplifier to a new level,” Hephner continued. “These full range amps are perfect for those installs with little room to spare, such as under a seat.”
Model Channel 4 Ohm 2 Ohm 1 Ohm Frequency Response MAP
R125-2 stereo
mono
42.5 x 2
125 x 1
62.5 x 2
N/A
N/A 20Hz – 20kHz +/- 1 dB $99.99
R250-4 stereo
mono
40 x 4
125 X 2
62.5 x 4
N/A
N/A 20Hz – 20kHz +/- 1dB $159.99
R250-1D mono 125 x 1 250 x 1 750 x 1 20Hz – 250Hz +/-1dB $149.99
R500-1D mono 250 x 1 500 x 1 1200 x 1 20Hz – 250Hz +/-1dB $229.99
Additional specs for the R125-2, R250-4, R250-1D, and R500-1D Class D amps include:
  • 12 dB/oct Butterworth Crossovers
  • R125-2; R250-1D; and R500-1D dimensions (L x W x H): 7.64in x 7.67in x 2.4in
  • R250-4 dimensions (L x W x H): 12.01in x 7.67in x 2.4in
  • Remote Punch level control included (R250-1D and R500-1D only)
  • 180 degree phase switch (R250-1D and R500-1D only)
  • Continuously Variable On Board Punch EQ Control
  • RCA Pass Through Outputs
  • Real Time Output and Power Supply Thermal Sensing
  • Extruded Aluminum Heat Sink
  • On Board ATC Fusing
  • 4 AWG Power/Ground Connectors
  • MOSFET Power Supply
  • Muted Turn On
  • Short Circuit Protection
  • CEA-2006 Compliant
  • CE Compliant
R125-2
R125-2
R250-4
R250-4
R250-1D
R250-1D
R500-1D
R500-1D
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
