Car Speakers
Rockford Fosgate PPS4-6 and PPS4-8 Punch Pro Car Speakers
Rockford Fosgate introduced the highly efficient, 100-Watt (RMS), 6-inch PPS4-6 and 125-Watt (RMS), 8-inch PPS4-8 midwoofers designed to provide high dB levels with little to no distortion.
These Punch Pro Series midrange speakers have been engineered for high SPL (Sound Pressure Level) conditions. The oversized motor structure and high temperature voice coil, combined with a fiber reinforced paper cone and corrugated treated cloth surround create the foundation for a highly sensitive speaker that can handle plenty of power. Protective grilles included.
Price and Availability
PPS4-6 → $89.99 (available April 2012)
PPS4-8 → $99.99 (available April 2012)
Rockford Fostgate PPS4-6 and PPS4-8 Punch Pro Car Speakers
100-Watt PPS4-6 and 125-Watt (RMS) PPS4-8 system specs include:
  • Corrugated treated cloth surround
  • Fiber reinforced high strength paper cone with treated W style surround
  • Billet stock machined aluminum phase plug
  • High temp aluminum voice coil
  • Fatigue and tear resistant poly cotton spider
  • periodic-stitched fatigue resistant lead wire
  • Stamp-cast steel frame
  • All metal input spring terminal connection
  • Grilles and mounting hardware included
  • Impedance: Single 4-Ohm and 8-Ohm versions
  • Sensitivity 92.4 dB (PPS4-6)
  • Frequency Response 85Hz – 5Khz (PPS4-6)
  • Sensitivity 94.4 dB (PPS4-8)
  • Frequency Response 80Hz – 5Khz (PPS4-8)
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
