Car Amplifiers
Rockford Fosgate PBR300X2 and PBR500X1 Car Amplifiers
Boosted Rail Technology (BRT) Design Allows for the Ultra Compact, Ultra Efficient Amps to Provide Big Power for Audio Systems that Require Little Space
Rockford Fosgate announced the 300-Watt PBR300X2 2-channel and the 500-Watt PBR500X1 mono block car amplifiers to their Punch BRT amplifier line.
“The PBR300X2 and the PBR500X1 Punch amplifiers have been designed for systems that require little space,” explained Theresa Hephner, Rockford senior director, products and marketing. “Our patented BRT (Boosted Rail Technology) is an ultra efficient design that doesn’t use a switching power supply to generate its rated power, which allows for a smaller chassis. The BRT also has a variable hi-level DC offset turn-on circuit for easy installation into any OEM system. It’s great for smaller stealth installations, as well as for motorcycles and recreational vehicles.”
Rockford Fosgate PBR500X1 Car Amplifier
Price and Availability
The Rockford Fosgate PBR300X2 and PBR500X1 will be available March 2012. They join the PBR300X4 and PBR300X1.
Model Channel 4 Ohm 2 Ohm 1 Ohm Dimensions (inches) MAP
PBR300X2 stereo (watts) 100×2 150×2 N/A 6.75 x 4.25x 1.53 $269.99
PBR300X2 mono (watts) 300×1 N/A N/A 6.75 x 4.25x 1.53 $269.99
PBR500X1 mono (watts) 175×1 300×1 500×1 8.25 x 4.25 x 1.53 $399.99
Rockford Fosgate PBR300X2 Car Amplifier
PBR300X2
PBR500X1
Additional specs for the PBR300X2 and the PBR500X1 include:
  • BRT Technology Indicator LED
  • Balanced Differential Low Level Inputs
  • Variable 4 – 6 Volt Hi Level DC Offset Voltage Input Turn On Control
  • Variable 12 dB/oct Butterworth Crossovers
  • Compact Design for Stealth Installations
  • Extruded Aluminum Heat Sink
  • Real Time Thermal Sensing with DTM Rollback Technology
  • Muted Turn On
  • Short Circuit Protection
  • Discrete Surface Mount Technology
  • CEA-2006 Compliant
  • CE Compliant
Marantz AV 30 and AMP 30 Promo Shot
Marantz brings the cost of A/V separates down to a more affordable price point with the AV 30 preamp/processor and AMP 30 multi-channel power...
Eversolo SE100 Passive Bookshelf Speakers Lifestyle Eversolo SE100 Passive Bookshelf Speakers Lifestyle
Eversolo’s SE100 passive bookshelf speakers promise big sound from a compact cabinet for $399 a pair, designed for real rooms and modern hi-fi systems.
Edifier M90 Wireless Speakers Lifestyle Gaming in White Edifier M90 Wireless Speakers Lifestyle Gaming in White
Edifier’s M90 is a "cross-scenario, multi-purpose" active speaker, performing equally well in TV and home entertainment setups as well as in PC, desktop, and...
Sylvox Cinema Pro 110-inch Helio QLED Outdoor TV by pool Sylvox Cinema Pro 110-inch Helio QLED Outdoor TV by pool
Sylvox debuts the world’s first frameless outdoor TV at CES 2026, plus a 110-inch 4K QLED model built to survive sun, rain, sports nights,...
Brane Party Pro Portable Speaker at CES 2026 Brane Party Pro Portable Speaker at CES 2026
Brane Audio debuts RAD2 at CES 2026, previewing the Party Pro prototype and a radical new approach to deep bass that could reshape portable...
Audio-Technica AT-LP7X Turntable Audio-Technica AT-LP7X Turntable
Audio-Technica’s AT-LP7X is a $999 fully manual belt-drive turntable with precise speed control, adjustable tonearm geometry, and built-in MM/MC phono support.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
