Car Subwoofers
Rockford Fosgate P3SD4-8 Punch Shallow Car Subwoofer
Rockford Fosgate announced the P3SD4-8 8-inch, 150-Watt RMS, 2-Ohm and dual 4-Ohm car subwoofers to their Punch P3 Shallow subwoofer series specifically designed for spaces where a traditional woofer cannot be used.
“The entire Punch P3 Shallow line has gone through a performance makeover, which includes adding an 8-inch, dual 4-Ohm and dual 2-Ohm option for tight space constraints,” explained Jake Braaten, Rockford Director of Product development. “Shallow woofers are designed for challenging spaces where a traditional woofer cannot be used. Now, consumers who are looking for Rockford’s famed Punch performance in a shallow, 8-inch package have found the answer.”
The Rockford Fosgate P3 Shallow Mount subwoofer series delivers the Punch, even in depth limited mounting situations. All vehicles are not the same… some can accommodate deep subwoofers and some can’t. In the past, that meant no bass. Not anymore. Now even depth challenged vehicles can have real bass and the dual voice coil allows configurations for every application.
The P3 line also offers two 300-Watt RMS 10-inch models (2-Ohm DVC, and 4-Ohm DVC) and two 400-Watt RMS 12-inch (2-Ohm DVC, and 4-Ohm DVC) models.
New models to ship April 2012
P3SD2-8 8″ Punch P3S Shallow 2-Ohm DVC Subwoofer $189.99
P3SD4-8 8″ Punch P3S Shallow 4-Ohm DVC Subwoofer $189.99
P3SD2-10 10″ Punch P3S Shallow 2-Ohm DVC Subwoofer $209.99
P3SD4-10 10″ Punch P3S Shallow 4-Ohm DVC Subwoofer $209.99
P3SD2-12 12″ Punch P3S Shallow 2-Ohm DVC Subwoofer $219.99
P3SD4-12 12″ Punch P3S Shallow 4-Ohm DVC Subwoofer $219.99
Features of the P3 Shallow subwoofer line include:
  • Custom 10-AWG nickel plated push terminals
  • Extended pole piece and bumped vented backplate
  • High excursion Poly-Ether-Ester surround
  • High-temp voice coil with spun-laced Nomex re-inforcement collar
  • Kevlar Fiber reinforced semi-pressed paper cone and ABS/Acrylic dustcap
  • Linear spider with embedded 16 AWG tinsel leads
  • Protective PVC textured magnet cover
  • Reversible diamond cut cast aluminum trim ring
  • Rigid die-cast aluminum low profile basket
  • Vented spider cavity
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
