Headphones
Rocketfish Rocketboost Wireless Stereo Headphones
The Rocketfish Rocketboost Wireless Stereo Headphones (RF-RBWHP01) are now exclusively available at Best Buy for $119.99. These headphones feature an over-the-ear design for comfortable wearability and up to a 115' wireless range for freedom to listen to your music without wires. The included docking station recharges the headphones for reliable use.
The Rocketboost Headphones provide uncompressed digital CD-quality sound that can be streamed from any audio component in the house, including an HDTV, disc or portable music player. Included with the headphones is a docking station that, when connected to other devices, lets consumers listen to music around the home wirelessly with an over-the-ear design that fits comfortably for hours of enjoyment.
Features
  • Compatible with all Rocketboost Wireless products
  • Headphones receive audio from other Rocketboost products
  • Docking station sends audio to headphones and other Rocketboost products
  • Works with all other audio components (TV, CD/DVD player, mp3 player)
  • High-performance audio – uncompressed digital CD-quality sound, adjustable volume control
  • Easy to Use – Easy setup, rechargeable batteries with convenient base docking station
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
