The Rocketfish RF-WHD200 4-Port WirelessHD Kit is now available exclusively at Best Buy. The HD kit sends full HDMI quality signals from up to 4 source components to an HDTV or projector and operates on a 60GHz frequency range for crystal-clear reception.
Available for $299.99, the Rocketfish 4-Port WirelessHD Kit sends full HD 1080p HDMI signals (including 3D) up to 32 feet without wires, presenting a simple, affordable solution for installing HD video where cables are not possible–such as over a fireplace or with ceiling-mounted HD projectors. The Rocketfish WirelessHD kit can also help reduce clutter by enabling easy wall mounting of an HDTV while “hiding” source components out of sight.
The 4-port WirelessHD kit operates in the 60GHz frequency range for crystal-clear, interference free wireless audio/video transmission without any type of signal compression or “bit-dropping” — just as if the components were connected with a high-speed HDMI cable. With four HDMI inputs on the auto-switching transmitter and latency of less than 4 milliseconds, the kit is perfect for all HDMI connections, including fast-action gaming systems, and is easy to set up and operate.
Features
- Connects up to 4 HDMI source components to transmitter
- Compatible with 1080p/60 and 3D video
- Supports HDMI CEC remote control functionality, also includes IR remote for port switching on components that do not support CEC
- Receiver can be mounted to wall or ceiling (bracket included)
- Includes two 4ft Rocketfish HDMI cables (model RF-G1160a)
