Compact Cameras
Ricoh GR II Digital Camera
Ricoh today announced a $800 premium compact digital camera with a large APS-C sensor, similar to many DSLR cameras. The second-generation GR II replaces the Ricoh GR camera by mainly adding Wi-Fi and Near Field Communication (NFC) functionality. A GR Remote web-based application allows users to control camera settings virtually via any browser, as well as view and share images wirelessly. Image Sync, available on PENTAX DSLR models, is also supported on the new GR II. It enables GR users to easily browse and transfer images to accompanying mobile devices.
Ricoh claims the GR II is the smallest premium compact with DSLR image quality, making it ideal for advanced photographers who want the quality of an SLR camera but the portability of a smartphone, along with high resolution, a wide angle lens, and quick shoot time.
Ricoh GR II Digital Camera Front Back
Features
  • High-quality, high-resolution: The GR 18.3mm F2.8 lens is a compact, high-performance GR lens with a focal length of 28mm (in the 35mm format). The GR II also boasts a large, APS-C-size CMOS image sensor with approximately 16.2 effective megapixels. Equal in imaging area to the type used for most PENTAX digital SLR models, the sensor combined with the GR lens assures exceptional image quality.
  • High-speed: The GR II’s high-speed AF system can focus in a mere 0.2 seconds, thanks to the optimization of its lens drive mechanism and AF algorithm, and it also has a one second start up and shut down time. Further, with the GR II users can go instantly from the play back mode to shooting by half pressing on the shutter release button.
  • Pocket-sized: Even though it incorporates a host of Wi-Fi functions, the GR II comes in the same size as the previous GR model. Its exterior housing is made of lightweight, high-rigidity magnesium alloy, while its grip is shaped for easy, comfortable hold, and features a control button layout that enables simple one-hand operation.
  • Expanded creative functionality: The GR II provides a total of 17 effect modes with six new modes added including: Clarity, Brilliance, Bright, Portrait, Vibrant and HDR Tone. The new GR II also includes a full range of shooting functions including an in-camera RAW data development function, full HD movie recording for high-quality, extended videos; and, wireless control of PENTAX AF360FGZII & AF540FGZII external flashes.
Pricing and Availability
The Ricoh GR II will be available July 2015 for $799.95.
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
