The 600RM Pro provides a space-saving form factor, while the Extender Pro adds extra outlets to RGPC or other power delivery systems. Both feature the added benefits of 12-volt triggers for convenient powering on and off of connected gear.
New Orleans, LA — October 30, 2007 – Richard Gray’s Power Company, LLC (RGPC) announces the release of the RGPC 600RM Pro and Extender Pro, now with 12-volt triggers for conveniently turning switched outlets on and off.
The RGPC 600RM Pro is designed for situations where space is at a premium. Containing a specially-designed 6,000-Watt parallel choke engineered to fit into a 2U rack space, the 600 RM Pro features six commercial-grade Hubbell outlets on its back panel and a convenience outlet on the front, making it large enough to power most midsized home theater systems.
The RGPC Extender Pro answers the call for customers who need to add additional outlets to an existing RGPC Patented Parallel Delivery unit. The one rack-space Extender Pro delivers high current on demand to connected components with minimal loss. Utilizing heavy 12-gauge wiring, each of the Extender Pro’s six commercial-grade Hubbell Outlets are hand-wired independently to the power source with no filtering, so all outlets receive the same amount of unrestricted current at all times.
Easy-to-use 12-volt triggers have been added to both the RGPC 600RM Pro and Extender Pro, bringing a new level of convenience. Apply 12 volts at either trigger input, and the units will sequence on the connected equipment. Remove the 12 volts, and they will turn off the connected equipment. 12-volt triggers are commonly found on surround processors, receivers, automation equipment and some preamplifiers.
Designed specifically to be used with an RGPC 400, 600 or 1200 Parallel Delivery system, the RGPC Extender Pro can also provide automation capabilities to any existing Power Line Conditioner (PLC). Simply plug the Extender Pro directly into an RGPC Parallel Delivery System or other PLC to provide non-sacrificial surge protection and noise removal. Utilizing only 1U of additional rack space, and capable of being mounted on rear equipment rack rails, the Extender Pro can provide the additional outlets needed for the most demanding users, while maintaining the benefits of RGPC’s patented High-Current-On-Demand.
The RGPC 600RM Pro and Extender Pro ship with detachable rack mount ears for quick installation. The 600RM Pro is available in a powder coat black or silver finish while the Extender Pro is available in matte black.
The RGPC 600RM Pro and Extender Pro with Triggers are shipping now. For more information, please visit www.richardgrayspowercompany.com.
RGPC’s parallel technology captures and restores instantaneously high-current-on-demand, working cycle-to-cycle to satisfy power-hungry equipment while rejecting power spikes and smaller surges that lead to premature failure of sensitive electronics. RGPC products are proudly manufactured in the U.S.A. and are sold solely through its network of professional audio/video dealers and installers.
Press Contact: Caster Communications, Inc. at 401.792.7080
Nicholas Brown: nbrown@castercomm.com
Joe Paone: jpaone@castercomm.com
For digital images: www.castercomm.com
