Revival Audio Unveils Its SPRINT 3 and 4 Loudspeakers
Designed in France, Revival Audio’s SPRINT bookshelf and floorstanding speakers feature expert craftsmanship, a reasonable price and a 10 year warranty.
Revival Audio Sprint 3 and 4 Loudspeakers
Following the previous release of their ATALANTE speakers, France-based Revival Audio have unveiled a new bookshelf (SPRINT 3) and floor standing (SPRINT 4) loudspeaker that are aimed at a very different price point. Those looking to spend between $3,000 and $5,000 on a complete system might want to take a closer look at both of these loudspeakers.
Shared Features
SPRINT 3 and SPRINT 4 incorporate an innovative ELYTRON baffle design (based on the carapace of a beetle) and construction to provide precise and balanced sound.
The ELYTRON serves as the front baffle of SPRINT, with fabric grills attached from behind. The baffle is secured magnetically and can be attached or removed from the cabinet as desired.
The asymmetric shape of the baffle, specifically designed with curved angles enhances high-frequency directivity as a waveguide.
The baffle also optimizes the mid to low-frequency performance by reducing the diffraction impact from the core MDF (Medium Density Fiberboard) cabinet.
From Daniel Emonts, Revival Audio Co-Founder & CTO:  “I’ve been intrigued by the unique structure of ELYTRON and the acoustic benefits it could bring to loudspeakers for some time…I’m immensely proud of what we’ve been able to achieve with the ELYTRON baffle on SPRINT 3 and 4. Having personally attached the final design to these speakers, following many hundreds of hours of testing, I’m excited for others to now hear the crisp, flawless sound these speakers are able to deliver.”
SPRINT 3
Revival Audio SPRINT 3 Bookshelf Speakers On Stands
SPRINT 3
The SPRINT 3 is a bookshelf-sized speaker that is designed to deliver quality sound when a compact-sized speaker is more practical or preferable than a floor-standing speaker.
Revival Audio SPRINT 3 Loudspeakers Lifestyle
STAND 3: The stands (Revival Audio Stand 3) shown in the image are optional (more on that later).
Specifications
  • Speaker Type: 2-way bookshelf loudspeaker with single rear port (bass reflex)
  • Tweeter Driver: 1 1/8 inches (28mm) soft-dome tweeter equipped with Revival Audio’s ARID (Anti-Reflection Inner Dome) and RASC technologies for more efficiency and clearer highs. ARID reduces unwanted resonance by 95%.
  •  Woofer Driver: 7 inches (18cm) with BSC (Basalt Sandwich Construction). This provides a better balance between rigid construction and lightweight for fast and smooth bass response.
  • Frequency Response (+/-3db): 55Hz – 22kHz
  • Sensitivity: 87dB/2.83V/1metre
  • Nominal Impedance: 6 ohms
  • Minimum Impedance: 4.5 ohms at 175Hz
  • Crossover Frequency: 1.8kHz
  • Recommended Amplifier Power: 30 to 150 watts
  • Recommended Room Size: 15 to 35 m2 (meters squared)/161.5 to 376.7 (sq ft).
  • Dimensions (HWD): 380 x 213 x 207 mm (15 x 8.4 x 8.2 inches)
  • Weight: 9.1 kg (20 lbs.)
SPRINT 4
Revival Audio SPRINT 3 Floorstanding Speakers
SPRINT 3
The SPRINT 4 is a 2.5-way floorstanding loudspeaker featuring a 28mm RASC soft-dome tweeter with built-in ARID (Anti-Reflection Inner Dome) patented technology along with a specialized back-chamber design able to absorb 95% resonances. ​
The two 7-inch woofers employ the BSC (Basalt Sandwich Construction). This supports a balanced rigid and lightweight design, offering a great damping construction that provides a fast and smooth response with tight bass dynamics.
The 2.5-way crossover optimizes the performance of woofers, resulting in a more accurate phase and extended low frequency.
The provided foot spikes provide stability, absorbing vibration and enhancing sound imaging.
Revival Audio SPRINT 4 Loudspeakers Lifestyle
SPRINT 4
Specifications
  • Speaker Type: 2.5-way floor-standing loudspeaker with dual rear ports (bass reflex).
  • Tweeter Driver: 1 1/8 inches (28mm) soft-dome tweeter equipped with Revival Audio’s ARID (Anti-Reflection Inner Dome) and RASC technologies.
  • Midrange/Woofer Driver: 7 inches (18cm) with BSC (Basalt Sandwich Construction).
  • Woofer/Bass Driver: Same BSC construction as the midrange/woofer driver.
  • Frequency Response (+/-3db): 45Hz – 22kHz
  • Sensitivity: 89dB/2.83V/1metre
  • Nominal Impedance: 4 ohms
  • Minimum Impedance: 3.8 ohms at 200Hz
  • Crossover Frequency: 1.6kHz and 2.2kHz
  • Recommended Amplifier Power: 30 to 180 watts
  • Recommended Room Size: 30 to 60 m2 (meters squared)/323 to 646 (sq ft).
  • Dimensions (HWD): 1060 x 213 x 307 mm (41.7 x 8.4 x 12.1  inches)
  • Weight: 20.6 kg (45.5 lbs)
Price and Availability
The Revival Audio SPRINT 3, 4, and Stand 3 will be available from March 2023 from Authorized Revival Audio Dealers
  • The SPRINT 3 Loudspeakers (pair) are priced at £895 / €990 / $1,195
  • The SPRINT 4 Loudspeakers (pair) are priced at £1,650 / €1,790 / $1,990
  • Optional Revival Audio Stand 3 is £339 / €399 / $399. a pair.
Tip: Sprint speakers come with a Blonde Oak, Walnut, or Black Finish.
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
At $18,000 per pair, the TAD ME1TX feature an upgraded CST Driver and other refinements.
Zu Audio hints of new products to debut at Capital Audio Fest from November 8-10, 2024, but photos and details are scarce.
The 300 series implements some of the technologies used in the flagship Corinium speakers at a more affordable price point
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
The definitive buying guide to the best bookshelf speakers from $300 to $1,400. Our picks from the best high-end brands.
Just add in-ceiling speakers to Q Acoustics 300A Ceiling Amplifier to bring streaming music and Amazon Alexa into any room.
