Revival Audio Unveils ATALANTE Loudspeakers: The Return to Vintage Continues
Another modern vintage audio loudspeaker? Revival Audio’s ATALANTE Speakers feature expert craftsmanship and a more modern sound for a significant chunk of change.
Revival Audio Atalante A5 Loudspeaker Pair Lifestyle
Our coverage of vintage audio continues to draw a lot of readers, and there is no question that the demand for vintage audio gear is going through a renaissance. Manufacturers are not oblivious to this reality and we have seen more than a few brands like Wharfedale, KLH, Klipsch, JBL, and Mission create something “new” to meet that demand.
One company that is embracing this trend is Revival Audio (definitely a fitting name), which has announced a new speaker series, the ATALANTE.
Revival Audio Atalante A5 and A3 Loudspeakers on stands front
Revival Audio Atalante A5 (left) and A3 (right)
The ATALANTE line comprises two stand-mount models, the ATALANTE 3 and the ATALANTE 5
The speakers are handmade in France, crafted by sound experts with four decades of audio brand experience that have worked with high-end speaker brands in France, Denmark, and the US. As a result of collaboration, several proprietary technologies have been implemented in Atalante speakers, which will are highlighted in the feature/specifications sections of this article. Both speakers come with a Walnut finish.
Let’s take a look at the ATALANTE speaker line and see if one or both models would be a good addition to your audio setup.
Revival Audio Atalante A3 Loudspeaker Pair Lifestyle
ATALANTE 3
The ATALANTE 3 is a compact, bookshelf-size speaker. The intent of its design is to deliver quality sound in setups where a compact size speaker is more practical than a traditional floor-stander.
Tip: The stands shown in the image are optional.
Revival Audio Atalante A3 Loudspeaker closeup
Specifications
  • Speaker Type: 2-way bookshelf loudspeaker
  • Tweeter Driver: 1 1/8-inches (28mm) soft-dome tweeter equipped with Revival Audio ARID (Anti Reflection Inner Dome) and RASC technologies for more efficient performance and clearer highs. ARID reduces 95% of unwanted resonance.
  • Woofer Driver: 7-inches (18cm) with BSC (Basalt Sandwich Construction). This provides a better balance between rigid construction and lightweight for fast and smooth bass response.
  • Frequency Response (+/-3db): 44Hz – 26kHz
  • Sensitivity: 87dB/2.83V/1metre
  • Nominal Impedance: 6 ohms
  • Minimum Impedance: 4.4 ohms at 175Hz
  • Crossover Frequency: 2.8kHz
  • Recommended Amplifier Power: 30 to 150 watts
  • Recommended Room Size: 15 to 35 m2 (meters squared)/161.5 to 376.7 (sq ft).
  • Dimensions (HWD): 390 x 240 x 270 mm (15.4 x 9.4 x 10.6 inches)
  • Weight: 11 kg (24.2 lbs.)
Revival Audio Atalante A3 Stand-mount Loudspeaker
Price & Availability
The ATALANTE 3 Loudspeakers (pair) are priced at €2,390 ($2,433.67 US) and are available direct from Revival Audio or authorized dealers
Optional ATALANTE 3 Stands are €399 ($405.78 US) a pair.
Revival Audio Atalante A5 Loudspeaker Lifestyle
ATALANTE 5
The ATALANTE 5 has a larger cabinet design that looks in-between the size of a compact and floorstanding speaker. The 5 is designed to produce full-range audio with clear highs, present midrange, and deep, tight bass, but still, be placed on a stand so that the speaker drivers are directed at ear-level height.
Revival Audio Atalante A5 Loudspeaker Tilt Floor Stand
Tip: The ATALANTE 5 does come with a small tilt stand if you want to place it on the floor. The stands shown in the image are optional.
Revival Audio Atalante A5 Loudspeaker Closeup
Specifications
  • Speaker Type: 3-way bookshelf loudspeaker
  • Midrange Driver: 3-inches (75mm) soft-dome mid-range equipped with RASC technology
  • Woofer Driver: 12-inches (30cm) with BSC (Basalt Sandwich Construction). This provides a better balance between rigid construction and lightweight for fast and smooth bass response.
  • Frequency Response (+/-3db): 28Hz – 26kHz
  • Sensitivity:  89dB/2.83V/1 metre
  • Nominal Impedance: 4 ohms
  • Minimum Impedance: 3.2 ohms at 110Hz
  • Crossover Frequency: 450Hz and 3.5kHz
  • Recommended Amplifier Power Power: 30 to 200 watts.
  • Recommended Room Size: 30 to 60 m2 (meters squared)/323 to 646 (sq ft)
  • Dimensions (HWD): 710 x 420 x 355 mm (28 x 16.5 x 14 inches)
  • Weight: 33 kg. (72.75 lbs.)
Revival Audio Logo on side of loudspeaker
The ATALANTE 5 Loudspeakers (pair) are priced at €4,490 ($4,572.00 US) and are available direct from Revival Audio or authorized dealers
Optional ATALANTE 5 Stands are €399 ($405.78 US) a pair.
Tip: Ven Den Hul cables are used in the wiring of the ATLATANTE 3 AND 5 speakers.
More Vintage Audio Stories:
4 Comments
4 Comments
  1. david
    August 4, 2022 at 3:48 pm
    review that 3-way. current speakers with dome midranges (esp those priced <10k) are rare. 75 mm domes can sound fantastic…
  2. Robb
    October 21, 2022 at 10:39 pm
    I’m very intrigued by this, have been contemplating a large driver setup. Auditioned a few Klipsch heritage speakers recently. I was quoted a bit over $5k from France with shipping, tough one when you can’t audition. I’ll keep thinking about it, they look great.
  3. Zoni Michel
    April 30, 2023 at 9:43 am
    Ecoutées les 3 et les 5! Quelle belle surprise.
    Son très envoutant et nat. Beaucoup de plaisir…
    T bon rapport q./p.
    • Ian White
      April 30, 2023 at 1:05 pm
      Michel,
      Nous écouterons les haut-parleurs cet été.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Loudspeakers
KLH Audio and Victrola now exist under the same umbrella keeping two legacy American Hi-Fi brands alive.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
At $18,000 per pair, the TAD ME1TX feature an upgraded CST Driver and other refinements.
Zu Audio hints of new products to debut at Capital Audio Fest from November 8-10, 2024, but photos and details are scarce.
