In-Wall Speakers
Revel Announces Flagship PerformaBe In-Wall Speakers with Beryllium Tweeters
Revel introduces its flagship PerformaBe in-wall speaker line priced from $1,500 to $3,500 each.
Revel PerformaBe In-wall and In-ceiling Speakers for Q4 2023
The CI market has become extremely lucrative for high-end brands with the expertise to create high performance in-wall, on-wall and in-ceiling solutions for consumers who desire better sound quality when listening to music and watching movies but don’t want it taking up space in their homes. Consumers are willing to invest in multi-room systems which include the backyard, pool, and four season rooms aside from the traditional spaces in the home.
Loudspeaker brands that are just entering this market are going to find that it is far more competitive in 2023 than ever before and that they better come with strong brand recognition and a dealer network if they plan on succeeding.
The HARMAN Luxury Audio Group has both and we’re not surprised to see Revel making a huge splash in 2023. The high-end brand has proven that it can design traditional loudspeakers that compete with anything on the market which certainly makes it an easier sell for custom integrators.
Revel is now taking that ingenuity to the custom install market with new line of PerformaBe architectural loudspeakers. These high-end in-wall speakers utilize the same beryllium dome tweeters and advanced Acoustic Lens waveguides from Revel’s acclaimed PerformaBe traditional box loudspeaker line.
“For two-channel hi-fi, home theaters, and whole-home audio distribution, our new Revel flagship architectural loudspeaker series is designed to deliver the renowned PerformaBe sound in a custom installation solution,” said Jim Garrett, Senior Director, Product Strategy and Planning, HARMAN Luxury Audio Group. “And since all PerformaBe speakers utilize the same patented technology, architectural, floorstanding, and bookshelf loudspeakers can be mixed and matched in a single system without sacrificing audio quality.”
Tip: Our podcast with Jim Garrett takes a deep dive into Harman Luxury Audio.
PerformaBe Architectural Series
The PerformaBe Architectural Series consists of four models:
  • W126Be (2-way 6.5-inch in-wall) $1,750 each
  • W226Be (2-way dual 6.5-inch in-wall) $2,250 each
  • W228Be (3-way dual 8-inch in-wall) $3,500 each
  • C128Be (2-way 8-inch in-ceiling) $1,500 each
At the heart of the speakers’ detailed sound lies a 1-inch beryllium tweeter driven by a ferrite motor assembly. The tweeter and ceramic-coated, cast-aluminum Acoustic Lens waveguide seamlessly integrate with the directivity of the speakers’ Deep Ceramic Composite (DCC) aluminum woofer and mid-frequency driver cones for greater bandwidth, less compression, improved dynamic range, reduced distortion, and increased power handling. A high-order crossover design allows the smallest nuances and details from music to be heard and includes a high-frequency attenuation switch to further tailor the sound to the room.
W126Be
Revel PerformaBe W126Be In-wall speaker
The W126Be is an in-wall version of the M126Be bookshelf loudspeaker and shares the same 6.5-inch 2-way design as its in-room counterpart. With a compact footprint, the W126Be works equally as well as a two-channel hi-fi music loudspeaker or as a surround channel loudspeaker in a system with its larger siblings.
W226Be
Revel PerformaBe W226Be In-wall speaker
Stepping up in the range, the W226Be is a dual 6.5-inch 2-way LCR version of the smaller W126Be, making it the ideal solution for front channel usage in a custom-installed home theater system, or as an in-wall center channel companion to the F226Be or M126Be in-room loudspeakers.
W228Be
Revel PerformaBe W228Be In-wall speaker
The largest model in the range — the W228Be — shares an identical dual 8-inch 3-way driver configuration with the award-winning F228Be floorstanding loudspeaker, but with the tweeter and midrange drivers mounted on a rotatable module located in the center of the baffle between the two woofers.
This allows the W228Be to be used either vertically as a main channel loudspeaker, or horizontally as a center channel when the tweeter/midrange module is positioned for such use. This flexibility makes the W228Be ideal for use as an in-wall LCR system, or as a perfectly matched in-wall center channel when paired with either the F228Be or F328Be floorstanding loudspeakers
C128Be
Revel PerformaBe C128Be In-ceiling speaker
The C128Be 8-inch 2-way in-ceiling model offers a solution for impeccable high-resolution sound in a whole-home distributed audio system, or it can be deployed as an in-ceiling surround or height channel in a custom installed home theater system.
Optional Back Box
The W126Be, W226Be, W228Be, and C12Be are each available with an optional integrated back box enclosure for consistent performance and reduced noise ingress into adjacent spaces. The loudspeakers feature a patented Cat Claw mounting system that makes installation far easier than traditional dog leg designs, and mounting depths that fit within standard 4-inch wall and 6-inch ceiling stud bays. Preconstruction brackets are available for all models as well.
Price & Availability
The Revel PerformaBe Architectural Series will be available in the Q4 2023 at the following prices.
  • W126Be: $1,750 each; back box enclosure: $550 each
  • W226Be: $2,250 each; back box enclosure: $800 each
  • W228Be: $3,500 each; back box enclosure: $1,000 each
  • C128Be: $1,500 each; back box enclosure: $500 each
Find more Revel in-wall and in-ceiling speakers available now at Crutchfield.com.
2 Comments
2 Comments
  1. John Casler
    November 8, 2023 at 8:53 pm
    Says available Q4 2024?????
    More than a year from now?
    • Ian White
      November 8, 2023 at 10:28 pm
      John,
      I checked and it’s now supposed to be Q4 by EOY. They made a mistake in their press release. It is not yet available online from any retailers.
      Best,
      Ian White
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
Over-Ear Headphones
Can the Meze Audio POET combine the sound quality of the ELITE series with the compact design of the LIRIC series, thanks to its...
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
