REL Paints the Town Bass: Colorful Subwoofers Crash High End Munich 2025
REL’s T/9X SE Subwoofers in French Racing Blue and Green With Envy™ debut at High End Munich 2025—because why should audiophiles settle for boring bass?
REL T/9x SE subwoofers in French Racing Blue and Green With Envy
REL Acoustics, long known for rattling floorboards and making neighbors question their life choices, is headed to High End Munich 2025 with two eye-catching new finishes for its T/9x SE subwoofer: French Racing Blue and the audaciously trademarked Green With Envy. At this point, it’s a toss-up who’s more color blind—REL or Tivoli Audio—but at least your low end will be dressed to impress.
Each T/9x SE packs REL’s high-level input—the secret sauce for tight integration with your main speakers—along with a fast, punchy 300-watt Class A/B amp that doesn’t sound like a cheap digital buzzbox. Up front, you’ve got a long-throw 10-inch driver doing the heavy lifting, backed by a down-firing 10-inch passive radiator that adds low-end weight without muddying the room. It’s built to hit hard, move fast, and stay musical—whether you’re spinning records or blowing up buildings on screen.
The new subwoofer finishes mark REL’s 35th anniversary—a nod to three and a half decades of doing bass better than most. It’s not just a birthday flex; it’s a reminder that REL’s been mixing precision engineering with real-world musicality long before DSP shortcuts and plastic cabinets took over. This milestone isn’t about looking back—it’s about doubling down on what matters: building subwoofers that don’t just rumble, but transform your music and movie nights into something visceral. It’s about precision, power, and making sure you feel every note and explosion right down to your spine.
Engineered for Eyes and Ears
French Racing Blue isn’t just a fancy paint job—it’s a nod to motorsport history, channeling that unmistakable electric blue once worn by Bugatti as it tore across the European racing scene. It’s a color that screams speed, precision, and a little bit of ego—all fitting for a subwoofer that’s tuned to move fast and hit hard without losing control.
rel-t9x-se-blue
Green With Envy™ doesn’t whisper—it struts. It’s bold, punchy, and just the right amount of unbothered, like a British racing green Jaguar E-Type parked in front of a pub full of Ferraris. There’s a spark of rebellion in this shade—kinetic, cheeky, and totally unapologetic—fitting for a subwoofer that refuses to blend into the background.
rel-t9x-se-green
These new finishes roll into REL’s increasingly flamboyant pit crew of high-performance subwoofers, joining the likes of Italian Racing Red, Tangerine Dream, and the slyly trademarked Le Mon™ Yellow. At this point, it’s less a product lineup and more a Formula 1 paddock with better bass.
rel-t9x-red-orange-yellow
But it’s not all flash—under the hood, the T/9x SE gets a performance bump thanks to new carbon fiber center caps that shave 10 grams off the moving mass. That might not sound like much, but it translates to faster transients, tighter bass, and up to 1.2 dB more output than the stock T/9x. In audiophile terms: that’s measurable gains you can actually hear—and feel.
These new models aren’t just for folks chasing numbers—they’re for those who want their system to make a statement before the first note drops. It’s audio as identity, gear that reflects taste, intent, and just the right amount of swagger.
From John Hunter, REL’s Chief Designer: “This whole line is about shock and awe–about catching someone’s eye and having them say, that’s me,…”The SEs are for people who are expressive, passionate, and unapologetically bold in their love of sound. It’s not just performance–it’s personality.”
rel-t9x-rear
Specifications
REL Model REL T/9x SE
Product TypePowered Subwoofer
Price$1,650
Driver10 in. (250mm) long-throw, FibreCarbon™ cone, inverted Carbon Fibre centre cap, steel chassis
Passive Radiator10 in. (250mm) long-throw, down-facing FibreAlloy™ cone, inverted alloy centre cap, steel chassis
Low Frequency Extension-6 dB at 27Hz Low Frequency
Input ConnectorsHigh Level Neutrik Speakon,
(1) Low Level RCA,
(1) LFE RCA
Output ConnectorsN/A
Amplifier TypeClass A/B
Power Output300 watts (RMS)
Wireless CapabilityREL Arrow system [required]. Sold separately ($239.00)
Dual Parametric FilterNo
Fully Electronic Set SafeYes
D.C. FaultYes
Output ShortYes
Main Input Voltage220-240 volts, 110-120 volts for certain markets
Fuses3.15 Amp semi-delay 220 volts operation. 7 Amp semi delay 120 volts operation
Supplied AccessoriesMains Lead
Neutrik Speakon Interconnect 10 Meters (33’6”) Nominal
User Manual
Available FinishesFrench Racing Blue (New)
Green with Envy (New)
Italian Racing Red
Tangerine Dream
Le Mon Yellow
The REL T/9X SE Subwoofers in French Racing Blue and Green With Envy™ will make their debut at High End Munich 2025, running from May 15th through 18th. If you’re lucky enough to be there, it’s not just a chance to ogle the new colors—it’s your shot at experiencing REL’s full range of high-performance subs in action. Expect exclusive demos that’ll let you hear what those snazzy finishes really bring to the table. (Check out our related reading section for a sneak peek at some other REL models that might make an appearance at the show.)
The Bottom Line
Subwoofers are a must-have for both music and home theater setups, but let’s be real—most people know REL’s lineup is built for music, even if they’re not afraid to shake the walls during movie night. While the original REL T/9X dropped in 2021, the T/9X SE—whether in its fresh color schemes or not—takes everything that made the original great and kicks it up a notch.
For those making the pilgrimage to High End Munich 2025, a visit to REL’s booth is a no-brainer. Not only will you get an earful of some serious bass, but you’ll also witness how REL continues to leave the competition eating their dust.
Price & Availability
The new REL T/9x SE colors (French Racing Blue or Green with Envy) are available for $1,650 via REL’s website. Or get the regular REL T/9x in black, white or gray for $1,500 at Amazon
Tip: You can also choose from  previously released colors that include Italian Racing Red, Tangerine Dream, and Le Mon™ Yellow
The REL Arrow Wireless Adapter is available for $239.00 from REL and Authorized Dealers
PMC prophecy9 Speakers Lifestyle
Discover PMC's latest Prophecy speakers at High End Munich 2025, showcasing cutting-edge technology, powered by the new PMC cor Integrated Amplifier.
NAD M33 V2 BluOS Streaming Amplifier and M23 V2 Stereo Power Amplifier NAD M33 V2 BluOS Streaming Amplifier and M23 V2 Stereo Power Amplifier
NAD’s M33 V2 and M23 V2: No bling, no hype, just solid sound and engineering that actually matters with support for MQA FOQUS and...
WiiM Amp Ultra Integrated Amplifier WiiM Amp Ultra Integrated Amplifier
WiiM Amp Ultra merges the brains of the Ultra and the brawn of the Amp Pro—now with a touchscreen and HDMI ARC for your...
WiiM Sound, WiiM Sub Pro and WiiM Ultra Lifestyle WiiM Sound, WiiM Sub Pro and WiiM Ultra Lifestyle
The WiiM Sound smart speaker and WiiM Sub Pro deliver budget-priced multi-room wireless music streaming. Should Sonos be worried?
Focal Diva Utopia Wireless Loudspeakers High Gloss off white, dune and black Focal Diva Utopia Wireless Loudspeakers High Gloss off white, dune and black
Focal's Diva Utopia wireless speakers now come in Black, Dune, and Off White High Gloss finishes. At $49,499, these beauties are the audio equivalent...
Dan Clark Audio Noire XO Open-back Headphones on stand lifestyle Dan Clark Audio Noire XO Open-back Headphones on stand lifestyle
At $1,299, the Dan Clark Audio NOIRE XO open-back planar magnetic headphones puts more expensive audiophile headphones on notice.
Mother's Day Gift Guide 2025 for Audio Video TV Lifestyle Projectors and Gadgets
Upgrade Mom's home audio and video experiences this Mother's Day with 10 gift ideas she'll absolutely love -- and you might too.
SVS brings Ultra Evolution speakers and new 5000 & 17-Ultra R|Evolution subwoofers to HIGH END Munich 2025. Full demos, gear reveals, and more.
Discover Amphion's new Argon3X, Argon3LX, and Argon7LX loudspeakers—Scandinavian-designed HiFi speakers built with pro-level precision. Now available in the U.S. through Playback Distribution.
The CANVAS HiFi Soundbar has already gotten good reviews, but it may get even better with the implementation of Organic Master Tuning
