REL Unveils Reference Series No.31 and No.32 Subwoofers
The ultimate subwoofers for movies and music? The new REL Reference Series No.31 and No.32 Subwoofers are monsters.
REL Reference Series No.32 and No.31 Subwoofers
REL is a well-regarded brand name in the world of subwoofers. Its T/x-series product line is very well received, but they haven’t stopped there. Following the recent debut of its HT/1510 Predator II subwoofer, REL has announced its new Reference Series subwoofer line, which initially consists of the No.31 (12-inch, $7,000) and No. 32 (15-inch, $10,000).
REL’s subwoofers have always been more popular for their performance with music as part of any 2.1 system, but the current generation are proving to be monsters of the Midway by offering state-of-the-art performance in home theater systems as well.
REL Reference Series No.31 Subwoofer Lifestyle with grille
No.31
The new REL Reference Series Subwoofers are not meant to be left in the corner; REL has a very comprehensive setup video that is well worth viewing to get the most out of your subwoofer and you might be surprised where you end up setting it up.
One benefit from our experience with REL’s subwoofers over the years is that they do a remarkable job of vanishing once properly installed and improving both the dynamic range, clarity, and soundstage of your existing loudspeakers — a benefit of taking some of the load off their shoulders.
Shared Features
  • Amplifier Type: Class D
  • Driver Material: Long throw carbon fiber cone with inverted carbon fiber center cap.
  • Enclosure: Closed box with a front-firing driver.
  • Dual Parametric Filters: Yes
  • Gain Control Rage: 80 dB
  • Crossover Control: Variable from 20 to 90 Hz.
  • Phase Control: 0 or 180 degrees switchable (used to match the in/out motion of the subwoofer driver to the rest of the speakers in your system).
REL Reference Series No.31 Subwoofer Back
No.31 and No.32 have the same rear panel
Remote Control
REL Subwoofer Remote
To make using the No.31 and 32 easier REL provides a wireless remote control. What distinguishes this remote is that it is circular and fits in the palm of your hand.
The control setting options are as follows:
  • Top: Crossover Control (20 to 90Hz)
  • Left Side: .1/LFE Level Control. Also used to adjust Parametric EQ Frequencies.
  • Right Side: Hi/Low-Level Volume control. Also used to adjust Parametric EQ Level.
  • Toggle Switches
    • Parametric: Used to select Parametric EQ settings (Dual A and B options)
    • Phase: 0 or 180 degrees.
    • Security: You can use this toggle to lock your subwoofer settings.
Having a wireless remote control for the No.31 and No.32 subwoofers is a lot more convenient than having to get up and fumble around with rear-mounted controls as is the case with most subwoofers.
Included Accessories
  • Mains Lead
  • Neutrik Speakon Interconnection (10 meters)
  • Remote Control and Batteries
  • Allen Key (2.5 mm)
  • User Manual
REL Reference Series No.31 Subwoofer Front Angle No Grille
No.31
REL Reference Series No.32 Subwoofer Front Angle No Grille
No.32
Comparison
No.31No.32
MSRP$7,000$10,000
Power Output:900 Watts RMS1,000 Watts RMS
Driver Size:12-inches (300mm)15-inches (380mm)
Low-Frequency Extension:Down to 17Hz (-6dB)Down to 15Hz (-6dB)
Dimensions (WHD):25 1/8 x 17 x 21 1/2 inches
(638x435x724mm)
29 1/4 x 21 x 32 1/8 inches
(743x540x816mm)
Weight:114.5 lbs
(52 kg)
187 lbs
(85 kg)
Finish:High Gloss BlackPiano Black Lacquer
Need More Bass?
REL Reference Series Triple Stack Subwoofer Line Array
If one No.31 or No.32 isn’t enough for your room (or taste), they are stackable in a line array.
You can stack up to three subs using REL Couplers™ (Line Array Connectors) that connect lower units to upper units. The couplers are solid, milled aluminum units that bolt to each sub and along with the substantial rails on the underside of each cabinet create an extremely heavy, sturdy bass tower.
For those that have the budget and desire (not to mention spousal approval) to dive into this type of setup, they will shake down more than the house. Neighbor Alert!
Pricing & Availability
The REL No.32 Reference Subwoofer ($10,000), and No.31 Reference Subwoofer ($7,000) are available direct through REL or authorized REL dealers
More on REL
2 Comments
2 Comments
  1. Albert Baskerville
    August 21, 2022 at 12:36 am
    That’s nice ☺️
  2. Mesonto
    August 22, 2022 at 12:34 pm
    Hey they’ve copied the sonic frontiers hockey puck a bit, albeit not as nice, it brings back memories.
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
At $43,600, Grimani Systems' Psi v3 is four subwoofer system that goes in each corner of a home theater for generating up to 115...
Daily Deals
Our favorite subwoofers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Customers in Australia can now purchase direct from RSL Speakers and get free shipping, faster delivery and a 30-day in-home trial.
At $35,000, the new McIntosh PS1K subwoofer combines 1,000-watts of Class D power with dual 13-inch drivers.
At $699, the Acoustic Energy AE Sub is 12-inch subwoofer packing 250-watts of power with low bass extension down to 26Hz.
