REL HT/1003 MKII and HT/1205 MKII Subwoofers Are Designed To Hammer Your Listening Room
The REL HT/1003 MKII and HT/1205 MKII Subwoofers are designed to deliver reference quality bass at a price you can afford.
REL HT/1205 MKII and HT/1003 MKII Subwoofers
Most consumers only think about “bass” when they hear the term “subwoofer” and that’s a huge failure on the part of the hi-fi press for not doing a better job of educating potential customers about their other benefits. SVS and REL Acoustics are two of the leading brands in the category and it’s clear from their websites and educational videos that they understand it is their job as well to do some of the heavy lifting. It’s not enough to just introduce new products like the REL HT/1003 MKII “The Hammer” ($699) and the HT/1205 MKII “The Cannon” ($849) subwoofers for home theater.
You have to explain to people why they need them. How many consumers even understand the rationale for using a stereo pair of subwoofers and why that might work better for them in their room than one larger one?
REL HT/1510 Predator II Home Theater Subwoofer Front and Rear
REL has been manufacturing high performance subwoofers for decades and done remarkably well with its best-selling T/x series product line, HT/1510 Predator II and No.31 and No.32 reference subwoofers which are designed to augment the world’s best hi-fi and home theater systems. The T/x models have always been rather affordable but the vast majority of consumers who purchase them are thinking about 2.1 stereo systems or 2.1 home theater rigs; home theater fans often turn to brands like SVS or Klipsch when it comes to 5.1 or 5.2.4 Dolby Atmos systems.
REL has announced new entries into its HT subwoofer line, which seem to offer rather affordable alternatives to the competition.
One thing we often neglect to consider with subwoofers is that their purpose is not only to provide impactful bass, but they should also add balance to your home theater setup by sonically integrating smoothly with the other speakers in your system. You should not perceive any gap between the subwoofer and the rest of your speakers.
One benefit from our experience with REL’s subwoofers is that they do sonically vanish once properly installed, improving both the dynamic range, clarity, and soundstage of your existing loudspeakers.
REL’s subwoofers are a particularly great complement for 2.1 music systems, but they are also a great addition to a home theater setup.
REL HT/1205 MKII Subwoofer Front Angle Grille On
REL HT/1205 MKII Subwoofer with Grille
HT/1003 and HT/1205 MKII Overview
The HT/1003 MKII and HT/1205 MKII subwoofers are updated versions of REL’s previous HT/1003 and HT/1205 subwoofers. In general, some of the improvements include:
  • New Class D amplifiers that provide greater headroom. REL claims that the HT/1003 MKII can play twice as loud as its predecessor while the HT/1205 MKII can play 50% louder.
  • Tweaks to the components used in the construction of the CarbonGlass driver of each sub including upgraded suspension.
  • Additional tweaks to supporting circuitry that limits distortion and improves frequency response clarity.
  • Tweaks to the exterior cabinet design including a new black lacquer finish for better integration with room decor.
REL HT/1003 MKII Subwoofer Front and Rear
REL HT/1205 MKII Subwoofer Front and Rear
HT/1003 MKII and HT/1205 MKII Shared Features
Amplifier Type: Class D (Next Gen 5)
Driver Material: Long throw carbon fiber cone with inverted carbon fiber center cap.
Enclosure: Closed box with a front-firing driver.
REL HT/1205 MKII rear panel
Rear panels are the same on both subwoofers
Level Control: Variable
Crossover Control: Variable from 30 to 200 Hz.
Phase Control: 0 or 180 degrees switchable (used to match the in/out motion of the subwoofer driver to the rest of the speakers in your system).
Inputs: Low-Level stereo RCA or LFE RCA
Outputs: Low-Level stereo RCA or LFE RCA
Signal Turn On: Selectable always on or Standby (aka Auto Detect).
Auto Turn Off Time: 30 minutes
Voltage Selector: 110/120V or 220/240V
Wireless Capable: REL HT-Air system sold separately ($119 at Amazon)
REL HT-Air
REL HT-Air Wireless Transmitter/Receiver
HT/1003 MKII and HT/1205 MKII Subwoofer Differences
ModelHT/1003 MKIIHT/1205 MKII
MSRP$699.00$849.00
Power Output (RMS)300 Watts500 Watts
Driver Size10-inches (250mm)12-inches (300mm)
Low-Frequency Extension (-6B)Down to 24HzDown to 22Hz
Dimensions (WHD)14.25 x 13.25 x15.25-inches (362 x 343 x 387 mm)16.25 x 15.25 x 17.25-inches (413 x 387 x 438mm)
Weight34.2 lbs. (15.5kg)43.2 lbs. (19.6kg)
Pricing & Availability
All are available direct through REL or authorized REL dealers at the following prices:
More on REL
2 Comments
2 Comments
  1. ORT
    September 26, 2022 at 10:36 am
    Hail and well met, sir!
    I do not know why, but every front-firing subwoofer I have bought has vibrated itself stoopid. Most of them were (*GASP*) Klipsch but a couple were from other manufacturers whose name(s) escape me right now.
    I now only use down-firing subs, with my favourite being a 10″ Martin-Logan (it came to me after I walked over and looked at it!). Yes, ’tis the plebe model! 😉 It is most likely just bad luck or the god (small “g”) of Bass (Hz not the fish) despises me. Any thoughts on this (MMS term ALERT!!!!) Cambiata (for me) of a “crisis”. That, I must admit, was a stretch.
    ORT
  2. Aaron
    September 29, 2022 at 12:41 am
    PSA and Rythmik Audio are heads ant tail a better value than REL and SVS. FYI.
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
With both Bluetooth and wired connectivity, Onkyo's Creator Series GX10DB and GX30ARC Powered Speaker Monitors are a versatile and affordable compact audio solution.
With updated styling and connectivity, the $349 Andover SpinBase 2 is a compact wireless speaker designed to sit under any turntable.
At $43,600, Grimani Systems' Psi v3 is four subwoofer system that goes in each corner of a home theater for generating up to 115...
Daily Deals
Our favorite subwoofers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
Customers in Australia can now purchase direct from RSL Speakers and get free shipping, faster delivery and a 30-day in-home trial.
At $35,000, the new McIntosh PS1K subwoofer combines 1,000-watts of Class D power with dual 13-inch drivers.
Digital Music Systems
At $649, the REVO SuperCD includes digital music streaming, Bluetooth 5.1, global radio, podcasts with dedicated app, and remote.
