Rega’s Nd3 Might Be The New Moving Magnet Cartridge To Consider Below $200
Rega’s Nd3 MM phono cartridge is the first to use ultra-high powered Neodymium N55 magnets with a brand new generator geometry.
Rega Nd3 Moving Magnet Phono Cartridge Connected
Rega must have had a rather successful High End Munich 2024, because we understand the folks at Ortofon, Sumiko, Grado Labs, and Audio-Technica were slightly surprised by this announcement from the British high-end manufacturer of turntables, amplifiers, CD players, loudspeakers, phono pre-amplifiers, and phono cartridges. The entry level phono cartridge market is definitely competitive, but there is no question that the market needed something new to shake it up. Enter the Rega Nd3. For only UK SSP £175.
Ortofon, Audio-Technica, Grado Labs, Nagaoka, Goldring, and Sumiko have owned this space for well over a decade but has there really been that much innovation? The Golding E3 and E4 consistently land on our “Editor’s Choice” list and who doesn’t love the Ortofon 2M Blue, Grado Prestige Series Blue3 or Sumiko Rainier?
But they have all started to feel somewhat dated.
Planar 2 and Planar 3 owners now have a new option and it will become the standard cartridge to ship with both turntables.
Rega Nd3
According to Rega, the Nd3 will offer between 5 and 6mV of output (which feels somewhat ambiguous) and requires 1.75 grams of tracking force. The headshell uses 3 points for attachment making it ideal for Rega’s own tonearms.
Each Nd3 is hand-made by Rega’s skilled technicians in the UK factory. The design uses brand new generator geometry with perfect symmetry to achieve highly accurate channel balance. The Nd3 also has an optimized pole gap for superior linearity and cross talk characteristics.
This new cartridge is created with miniaturized parallel coils which are wound in house utilising 38-micron wire with just 1275 turns.
This produces a low inductance, low impedance generator giving vastly improved high frequency response.
Rega Nd3 Moving Magnet Phono Cartridge Side
Nd Magnet technology
Often used in Moving Coil designs (including their own), Rega believe that the Nd3 is the first moving magnet to utilize a Neodymium (Nd) N55 magnet. This is the world’s most powerful commercially available magnet and is a crucial component that makes this unique design possible by delivering extra power than standard bar magnet designs.
Glass filled PPS body
The complete assembly is housed in a zero tolerance Injection moulded glass filled polyphenylene sulphide body (PPS) which is a lightweight and highly rigid material. A low mass body reduces stress on the tonearm bearings and aids free movement which is critical in accurate vinyl replay. This new body design was inspired by Rega’s existing range of MC cartridges.
Cantilever & stylus profile
The Nd3 aluminium cantilever is fitted with a precision elliptical stylus. This profile provides exceptional tracking accuracy and extracts great levels of detail from the vinyl surface.
Rega Nd3 Moving Magnet Phono Cartridge mounted on Planar 3 Turntable
Price & Availability
The Rega Nd3 will be available for £175 or factory-fitted to the Planar 2 (£599) & Planar 3 (£799) turntables.
1 Comment
1 Comment
  1. David W Pumphrey
    May 19, 2024 at 12:05 am
    There’s no such thing as adjusting the stylus pressure on a cartridge because it is impossible to measure the pressure in a record groove. You adjust the tracking force which tells you the amount of weight or force that is being placed on the record. It’s a common thing to see people talking about stylus pressure when they should be saying tracking force.
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
HDTV 4K & 8K TV
HDTV 4K & 8K TV
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Chord's new Suzi Pre preamplifier and Suzi power amplifier are scheduled for release Fall 2024.
Netflix expands its viewing flexibility by embracing HDR10+, but there are a couple of catches.
HDTV 4K & 8K TV
DTS support has disappeared from 2025 LG TVs. Is there something else afoot to replace it that might be better?
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
Over-Ear Headphones
Find out if the HiFiMAN HE1000 Unveiled open-back audiophile headphones sound good enough to appease those worried about its exposed drivers?
