Rega’s Naia is the Turntable Roy Gandy Always Wanted to Create
After extensive development, the ultimate Rega audiophile turntable can be yours for only £12,000.
Rega Naia turntable lifestyle
Rega turned fifty this year and the British manufacturer has been busy celebrating its birthday with a number of new products like the recently introduced AYA loudspeaker and the 50th Anniversary version of the Planar 3 turnable.
Both of those products, however, take a backseat to the realization of Rega’s most ambitious product since its inception in 1973 — the Rega Naia Turntable.
The turntable took much longer than expected to get to market and that was probably fortuitous for Rega which had to contend with the pandemic, supply chain issues that forced some its customers in North America to wait 8 to 10 months for their turntables, and inflationary pressures on consumers.
Rega limited production of the flagship and experimental Naiad turntable to only 50 units at £30,000 (38 have already been sold and shipped) and with so much competition from VPI, Linn, Clearaudio, Brinkmann, Thorens, Kuzma, and SME in that price range for a reference caliber turntable — it was going to have to think outside the box in a way to make the Naia more palatable to Rega’s customer base that is not accustomed to spending that kind of money on a turntable.
£9200 gets you the table but no cartridge; users can add Rega’s statement Aphelion 2 moving coil (MC) cartridge for an additional £3465 on its own.
Once the screaming subsides, Rega has decided to shave £655 off the price of the cartridge if you order the turntable with it pre-installed. The total damage on that comes to a rather humbling £12,000.
Rega Naia Turntable Lifestyle Angle
Rega Naia Turntable
Innovation
The Rega RB Titanium Tonearm which features a titanium vertical bearing housing and spindle, tungsten balance weight shaft and weight, is a new design. The tonearm also features Rega’s single-piece aluminum arm tube.
The trickle down technology from the Naiad includes a central bearing made from ZTA zirconium-toughened alumina (ceramic) for maximum performance and rigidity.
A triple drive belt is used for improved stability and speed performance and users benefit from Rega’s latest ceramic platter that offers improved resonance control.
Rega Naia Turntable with Power Supply
The Naia features the same AC Power Supply Unit used by the Rega Planar 10.
The Rega Naia turntable is the result of years of painstaking development which was used to create the now famous Naiad test bed turntable.
The Naia takes the best of this development and technology and transfers it into a production ready version without compromise. The Naia is packed with ground-breaking features, materials and technology developed by Rega over many years to reach new levels of vinyl replay.
Rega Naia Turntable with lid closed
The Naia takes their pioneering low mass, high rigidity plinth technology to the next level by using a Graphene impregnated, carbon fibre skeletal plinth with Tancast 8 foam core.
Rega Naia Turntable without cover
This ultra rigid structure is then strengthened further using two ceramic aluminium oxide braces, the same material used to create the redesigned, resonance controlled ceramic platter with improved flywheel effect and complex profile.
Rega Naia Turntable Craftsmanship
Key Features
  • Graphene impregnated Carbon Fibre skeletal plinth with Tancast 8 foam core
  • ZTA Zirconium toughened alumina (ceramic) central bearing
  • RB titanium tonearm: One piece titanium vertical bearing and Titanium vertical spindle assembly
  • Tungsten balance weight shaft and weight
  • Ceramic top and bottom braces
  • Reference advanced fully adjustable power supply
  • Resonance controlled ceramic platter with improved flywheel effect and complex profile
  • Low mass skeletal aluminium feet
  • Triple Reference drive belts for improved stability and drive characteristics.
  • Rega Aphelion 2 MC factory fitted (optional)
  • Lifetime warranty against manufacture defects
For more information: rega.co.uk/products/naia
Related reading: Discover more turntable news and reviews
2 Comments
2 Comments
  1. Steve
    October 6, 2023 at 9:29 pm
    Will it make a bad pressing sound better?
    • Ian White
      October 7, 2023 at 2:16 pm
      Steve,
      Depends on the rest of the system.
      IW
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Explore Craft Recordings' Record Store Day 2025 preview featuring exclusive releases from Carla Thomas, Thelonious Monk with Gerry Mulligan, and the Jazz Dispensary Night...
