RBH Sound QM-615 In-Ceiling Speaker
RBH Sound QM-615 In-Ceiling Speaker with Grille
RBH Sound has introduced what it claims is the fastest installing in-ceiling speaker in the world. Designed for jobs and installations requiring large quantities of in-ceiling speakers, RBH's new QM-615 boasts an installation time of less than four seconds.
RBH basically took the “guts” of their ultra popular A-615 in-ceiling speaker and placed them into a new, modern frame and baffle design employing the company's quick-cam technology. The four quick-cam mechanisms on the speaker come pre-loaded or “cocked”, ready for installation. Included with each QM-615 is a pocket-sized, dual-purpose installation tool which eliminates the need for typical bulky and heavy drill-drivers or similar installation tools. Using the rounded end of the tool, installation is as quick and easy as pushing four recessed triggers located around the speaker's baffle. Each trigger releases one quick-cam mechanism, quickly and securely locking the QM-615 in place. Since the QM-615 can be installed so quickly, the time savings can really add up, allowing RBH dealers to make more money on each job. Removing the QM-615 is as simple as inserting the hex key end of the installation tool in each trigger location and rotating the wrench less than a full turn counter-clockwise, thereby resetting the quick-cam. In the event the installation tool is ever lost, a standard hex key (Allen Wrench) can be used to easily remove the speaker.
The QM-615 features a 6.5-inch diameter PolyGraphite cone woofer for strong bass and smooth midrange, and a 1-inch nano-silk dome swivel tweeter for crystal clarity. High frequency information from the QM-615's tweeter can be directed towards the listening position, and an integrated sound contour switch, conveniently located on the face of the speaker, allows the output level of the tweeter to be adjusted to one of three settings: -3dB/0dB/+3dB for optimal performance regardless of position or decor.
RBH Sound QM-615 In-Ceiling Speaker - Back
Perhaps the most attractive in-ceiling speaker in RBH's lineup, the QM-615 features a modern design enhanced by a paintable, micro-perforated grille which covers all but the last 5mm of the speaker's paintable frame. This thin-edge design allows the speaker to be practically hidden in the ceiling.
The QM-615 has a frequency response of 55Hz – 20kHz ±3dB, can handle up to 80 Watts of power and has a suggested retail price of $249/pair (available now).
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
