RBH Announces SFTR and SFTR/AX Loudspeakers
Passive or active? The RBH SFTR and Unrivaled SFTR/AX tower loudspeakers have arrived whichever way you like.
RBH Sound Unrivaled SFTR/AX Loudspeakers
Following the release of their 21-inch Unrivaled 21-SF/R Subwoofer, RBH Sound has also announced their new SFTR modular loudspeaker system. SFTR stands for Signature Freestanding Tower Reference, and it arrives in two configurations. The passive model is called the SFTR, while the active is labeled as the Unrivaled SFTR/AX.
Built on the experience achieved through the monolithic RBH SVTRS flagship tower, the SFTR series comes with a smaller footprint and price point. The modular towers are designed to provide elevated performance in the reference SF line of in-room speakers.
SFTR
Music enthusiasts will appreciate the D’appolito design of the top module and the sealed enclosure of the subwoofer module that is designed to provide, accurate and deep bass complemented by DSP-controlled amplifiers.
Tip: The standard SFTR provides a passive upper module with 2,400-watt active subwoofers. The subwoofers can be powered internally by ordering them with 2,400 watt preprogrammed DSP amplifiers built into each subwoofer module or your can order them without the built-in amps and use an external 2-channel DA-2602DSP amplifier which can provide 2,200 watts per channel (4 ohms) for the subwoofer modules.
Unrivaled SFTR/AX
The fully active UNRIVALED SFTR/AX loudspeaker takes things a step further by incorporating all-new patent-pending G.A.D.S. (granular acoustic damping system) technology built into the speaker cabinet, a rack-mountable RBH Linear Phase Loudspeaker Processor unit (by Marani) and a rack mountable six channel RBH UNRIVALED alpha amplifier, providing speaker processing and tri-amplified power to each stereo pair of SFTR towers.
Each system contains two modules per channel, one 821-SF/R on top and one 1212-MS/R subwoofer at its base.
RBH 821-SF/R Speaker
The slender floorstanding design supports more precise stereo imaging while visually complementing any living space. The upper section of the tower uses two newly developed, 8-inch, proprietary aluminum cone woofers and an acclaimed Aurum Cantus AMT tweeter.
Each 1212-MS/R subwoofer uses dual proprietary side-firing 12-inch long-throw aluminum cone subwoofers. The two modules are secured to one another with steel plates.
RBH Sound 1212N-MS-R Passive Subwoofer
The passive version of the SFTR is engineered for elevated performance and smooth integration with its sealed powered subwoofer module.
Either option provides the subwoofer modules with enough output to create an in-room frequency response (in most environments) down to 12 Hz.
Customers who choose the UNRIVALED upgrade path are treated to an even higher level of sonic refinement. The UNRIVALED option offers upgraded performance for both passive and active options. It contains internal wiring provided by Kimber Kable, additional wall damping, and the inclusion of the newly developed G.A.D.S. (granular acoustic damping system) technology, which further increases the performance of the speaker by making the enclosure more resonance-free, inert, and well-damped.
According to RBH, the fully active, time-aligned, UNRIVALED SFTR/AX option provides the highest performance available. Its RBH Linear Phase Loudspeaker Processor unit (by Marani) provides a tri-amplified digital crossover for each speaker channel.
The processor’s granular control with slopes of up to 48dB/octave and finite impulse response (FIR) filters correct time and phase alignment problems inherent in almost all speaker designs.
Comparison
SFTRUnrivaled SFTR/AX
MSRP$14,500/pair (ext. amp)
$16,500/pair (int. amp)
$30,000/pair
TypePassive
(amp is for subwoofer only)
Active
System3-way modular tower with powered sealed subwoofer and sealed 2-way passive speakers2-Channel Active Time-Aligned System; speakers sealed, subwoofers ported
Woofers(2) 12″ (305mm) cast aluminum basket, aluminum cone subwoofers (silver or black-anodized)(2) 12″ (305mm) cast aluminum basket, aluminum cone subwoofer (silver or black-anodized)
Mid-Woofers(2) 8” (203mm) Reference Aluminum Cone Mid-Woofers(2) 8” (203mm) Reference Aluminum Cone Mid-Woofers
Tweeters(1) 4.72” X 1” (120mm x 25mm) AMT Tweeter(1) 4.72” X 1” (120mm x 25mm) AMT Tweeter
Frequency Response20Hz-35kHz (±3dB)20Hz-35kHz (±3dB)
Sensitivity92dB92dB
Recommended Power100-350 Watts 821-SF/R (top speaker module)Internal
Impedance821-SF/R 6Ω – 1212-MS/R 4Ω821-SF/R 6Ω – 1212-MS/R 4Ω
Crossover Frequency2000Hz, 40Hz-180Hz (variable in software)80 Hz, 2000 Hz
Crossover Slope24dB/Octave, 6dB/Octave-48dB/Octave (variable in software)75dB/Octave
Cabinet ConstructionHigh-Density Fiberboard (HD)High-Density Fiberboard (HDF)
Finish OptionsBlack or White Satin PaintBlack or White Satin Paint
Grill OptionsMagnetic Grille (black or white fabric)Magnetic Grille (black or white fabric)
Dimensions13 1/4 x 57 3/4 x 17 inches  (337 x 1467 x 432 mm)13 1/4 x 57 3/4 x 17-inches (337 x 1467 x 432 mm)
Weight137 lbs (62.15 kg)160 lbs (72.57 kg)
WarrantySpeakers – 10 years
Amp – 3 years limited
Speakers – 10 years
RBH Alpha Amplifier IncludedNoYes
FIR DSP IncludedNoYes
Internal Kimber Wire NoYes
Wool Damping UpgradeNoYes
G.A.D.S. Built-inNoYes
Anti-resonance Internal PanelsNoYes
Setup
The SFTR speakers come with the RBH 2602DSP 2-channel external subwoofer amp to power the subwoofers OR you can opt to order the SFTR with the built-in 2,400-watt DSP-controlled subwoofer amplifiers, one in each cabinet.
The top section, the 821-SF/R will need amplification that is not included. Whether the end user wants to use their own amps, receiver, or buy a 2-channel RBH Alpha Amp for an additional cost, the choice is theirs.
On the other hand, the Unrivaled SFTR/AX includes everything users to get them running. This includes the built-in RBH Alpha 6-channel amplifier that feeds the tweeters, midrange, and subs separately. The Amp is fed by the DSP. All one needs to listen to is a source connected to the DSP. It can be fed a digital source via AES or analog via XLR connection.
Pricing and Availability
There are two ordering options for the SFTR System:
  • The SFTR speaker/RBH 2602DSP 2ch external subwoofer amp (one channel feeding each cabinet) package is $14,500.
  • The SFTR speaker package with the subwoofer amps built-in (one in each cabinet) is $16,500.
Tip: Yes, it is more expensive to get the speakers with the amps built-in but the main reason is that you have one external amp vs two internal amps.
The Unrivaled SFTR/AX system is priced at $30,000, with all amplification needed built-in.
The SFTR and Unrivaled SFTR/AX are available through the RBH authorized dealer and distributor network.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our favorite projectors of 2025 offer the best picture quality and value at their price across UST, lifestyle and standard throw models.
Looking for an affordable way to get into hi-res digital music streaming? Our favorite streamers are from WiiM and Cambridge Audio.
Our top floorstanding loudspeakers for 2025 come from Magnepan, Q Acoustics, KLH, Audiovector, and ATC—five brands delivering standout engineering, scale, and true high-end performance.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
At $229, the 3rd generation iFi ZEN DAC adds a USB-C digital input and improves hi-res audio decoding up to 32-bit/768kHz PCM.
Focal quietly drops the $699–$2,299 Omada speakers between Vestia and Theva, packing TAM tweeters and Slatefiber cones in a non-typical rollout but with good...
