Mouse
Razer Naga Epic MMO Gaming Mouse
Razer today announced the launch of an elite wireless MMO gaming mouse that's an upgrade from the original Get Imba mouse — the Razer Naga Epic. Designed by Razer R&D labs, the Razer Naga Epic epitomizes that fine balance between keyboard and mouse with 17 MMO-optimized buttons, and takes it to a whole new level with three ergonomic interchangeable side panels for optimal fit, the choice to customize the backglow from over 16 million colors, and a dual mode wired/wireless functionality.
The Razer Naga Epic MMO gaming mouse allows gamers to easily organize their character abilities for any game by enabling them to fully remap and assign programmed macros to all 17 buttons. With three interchangeable side panels for optimal fit designed for various hand sizes and grip styles, the Razer Naga Epic allows gamers to quest, raid, or PVP in comfort for hours on end. The true gaming-grade wireless connection on the epic mouse also allows gamers a greater variety of movement without any sacrifice of mouse control or accuracy, with zero downtime as the mouse charges while in wired mode.
The end result is a mouse that not only provides a personalized level of comfort, but with its dual wired/wireless functionality and unique MMO-optimized multi-button thumb grid also lets gamers fully immerse in their favourite MMO games knowing they have the full range of character abilities at their fingertips.
The final design of the Razer Naga Epic, from optimal button configuration to its form factor, was achieved through the scientific testing and screening of more than 80 different model iterations by Razer's ergonomics team.
Product Features:
  • 17 Fully-programmable MMO-optimized buttons (including 12 button thumb grid)
  • Wired/Wireless dual mode capability
  • Three interchangeable ergonomic side panels
  • Charging dock (also functions as a wireless receiver unit)
  • Unlimited character profiles with AddOns
  • Optional MMO-specific software AddOns
  • 16 million color backlight illumination
  • 5600dpi Razer Precision 3.5G Laser Sensor
  • 1000Hz Ultrapolling / 1ms response time
  • Approximate size: 116L x 77W x 41H (in mm)
  • Battery Life: 12hrs (continuous use); 72 hours (normal gaming usage)
Price and Availability
Price: $129.99 / €129.99 (Available November 2010)
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
