Rapoo A600 Bluetooth NFC Speaker
Rapoo A600 Portable Speaker
The Rapoo A600 is a Bluetooth 4.0 portable speaker with Radiation Airflow Invert Technology and Near Field Communication (NFC), which simplifies the pairing process. Just hold a Bluetooth-enabled device like a smartphone or tablet to the speaker so it automatically connects.
The clear, powerful sound is attributed to the cutting-edge Radiation Airflow Invert Technology because it uses the backward pressure energy of the active speaker and runs it through passive speakers. That means it enhances the lower frequencies for richer and more powerful bass.
The Bluetooth 4.0 ensures reliable audio, and you can make or receive voices calls through the A600. It has a working wireless range of up to 10 meters with 360 degree range, and you can even connect two devices simultaneously.
Portable and compact with a brilliant design, the A600 earned the iF Product Design Award this year. The high-grade brushed-aluminum casing houses the speaker which comes in five sleek colors. The minimalist design is elegant with a slightly retro touch. It comes with a rechargeable lithium battery for 10 hours of continuous playtime.
Price and Availability
The Rapoo A600 wireless speaker is available now for $99.99 at walmart.com and other retailers.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Bose just expanded its Bluetooth speaker lineup with one for home and another to take wherever your path leads you.
Sony just released a new and improved version of their neckband speaker but is this another clever gadget in search of a market?
