Dongle DACs
Questyle’s 2nd Gen M12i and M15i Dongle DACs are Apple MFi Certified
2nd generation Questyle M12i and M15i dongle DACs quietly drop support for MQA, while improving compatibility with Apple devices.
Questyle M12i and M15i Dongle DACs
The original Questyle M12 and M15 were two of our favorite dongle DACs of 2023. However, we just learned they’re being replaced by new Apple MFi Certified “i” models. Priced at $199 and $299 respectively, the M12i and M15i ensure support for iPhone/iPad and seamless integration into the Apple ecosystem.
Although the first generation models worked with iPhones, the new models should offer greater performance and potentially last longer since they meet Apple’s stringent requirements for external devices in terms of power consumption and compatibility.
In addition, Android versions 5.1 and above, Windows 10 version 18.3 and above (driver-free), HarmonyOS and Mac OS have all passed rigorous testing.
Ultimately, they’ll improve the sound quality from your phone with wired headphones. Each model does so with varying levels of power and performance depending on the headphone and IEMS on the other end.
Tip: Instead of the term “Dongle DAC”, Questyle calls them “Mobile Headphone Amplifiers with DAC” to more accurately describe their function.
Questyle M12i
Questyle M12i Dongle DAC
Questyle M12i
At $199, the M12i is smaller and simpler to use. It features Questyle’s unique Current Mode Amplification paired with the ESS flagship USB DAC chip. In addition, it features automatic impedance detection which reconfigures itself each time a new headphone is connected.
Upon detecting the insertion of headphones, the M12i instantly activates working mode, recognizing and configuring the corresponding gain for the connected headphones. When the gain light is illuminated, a single indicator represents low gain, suitable for low-impedance headphones, avoiding overdriving. Dual red indicators represent high gain, providing sufficient drive for high-impedance headphones.
If M12i is connected as a mobile DAC to Hi-Fi systems, active speakers, etc., it will automatically switch to high-level output, providing sufficient support for Hi-Fi audio systems.
Where to buy: $199 $149 at Questyle
Questyle M15i
Questyle M15i Dongle DAC
Questyle M15i
At $299, the Questyle M15i offers an additional fully balanced 4.4mm input and greater power output, but opts for manual gain control instead of automatic. That sounds like a negative, but we believe advanced users will appreciate the M15i’s manual gain option.
More importantly, the M15i should sound the better of the two. It contains two groundbreaking “current mode” patent amplification SiP modules developed by Questyle Technology.
Overall, it utilizes four current mode amplification engines for generating powerful and clear sound. Given that it operates in the current domain, the low impedance characteristics of the current-mode circuit result in a bandwidth of up to 1MHz and distortion as low as 0.0003%. The company says this development makes it possible to discern even the tiniest details when listening to music.
Where to buy: $299 $249 at Questyle
Questyle M15i Dongle DAC front and back
Questyle M15i
Should You Upgrade?
If you’re already a happy Questyle M12 and M15 owner, there are a few differences to consider. Both M12i and M15i drop support for MQA, but double D/A decoding up to 32-bit/768kHz PCM and DSD512 (from 32-bit/384kHz and DSD256). Of minor note, the status indicator lights are different on the new models.
Interestingly, all four models use the same ESS ES9281AC DAC.
Tip: Prior iPhone/iPad owners may require a Lightning to USB-C adapter (sold separately, e.g. Questyle LTC02 Lightning to Type-C adapter). All models include USB-C cables and USB-C to USB-A cables in the box.
M12i vs. M15i
M12iM15i
MSRP$199$299
Outputs3.5mm3.5mm
4.4mm fully balanced
Gain ControlAutomaticManual
CMA SiP ModuleSingleDual
CMA Engines24
DACESS ES9281ACESS ES9281AC
DecodingPCM768 / DSD512PCM768 / DSD512
THD + N0.0003%0.0003%
Dimensions (HxWxD)56.9 × 20.2 × 9.5 mm61.91 × 27.9 × 12 mm
Which one should you buy?
Until we get the new models in for review, it’s too soon to say how they compare sonically to the previous generation. If you care about MQA, then get one of the older models, which are on sale at Headphones.com while supplies last.
Related reading: Find out about the latest Dongle DACs.
1 Comment
1 Comment
  1. ORT
    February 11, 2024 at 4:52 pm
    Thank you, Brian!
    I just bought my self a new iPad yesterday to replace a Windows laptop. I keep dropping stuff as I am getting worse and worser, LOL! Do you or any of the folk there think either of these would be a good pairing with a fAapple iPad?
    I am curiouser and curiouser…
    ORT
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
