Q Acoustics M2 Soundbase Does 180-degree Sound
Q Acoustics M2 Soundbase under TV
Q Acoustics recently released the affordable M2 soundbase for $350. It delivers 180-degree room-filling sound thanks to a built-in down-firing dual voice-coil subwoofer for punchy low-end bass. To add even more depth and weight a MoviEQ function can be activated to emphasise the bass further and enhance movie soundtracks and video game action. To eliminate any unwanted vibrations caused by the full bass sounds the sturdy wooden cabinet provides robust damping and bracing.
The M2 utilizes Balance Mode Radiator speaker technology to deliver a 180-degree wide dispersing audio. Resulting in a bigger sweet spot, no matter where a person sits in the room, they will hear the same detailed, rich and dynamic sound.
Whether discreetly under a TV (maximum weight of 25kg) or inside a cabinet, a three-mode equalizer switch at the rear will adapt the bass levels to suit the M2’s surroundings and produce the most effective sound.
The M2 Soundbase can also be used as a music system thanks to Bluetooth aptX built-in, while support for NFC allows easy one touch pairing of devices.
For TV setup just connect the M2 via the HDMI ARC input on the TV to conveniently control volume via the TV’s remote control.
Price and Availability
The Q Acoustics M2 soundbase was released September 2017 for £299 (inc. VAT) / $349.99 USD.
Specifications
Amplifier
  • Power output: 80W (2 x 20W + 40W)
  • THD (at rated power): <0.9%
  • Frequency response :+/-0.5dB 20Hz to 20kHz
  • S/N ratio (A-Wtd): -85dB
  • Inputs
  • HDMI: Yes, ARC
  • Optical: Yes
  • Line in 1 (RCA phono) min. input sensitivity – 1.0Vrms
  • Line in 1 (RCA phono) input overload – 2.2 Vrms
  • Line in 2 (3.5mm jack) min. input sensitivity – 450 mVrms
  • Line in 2 (3.5mm jack) input overload – 1.2 Vrms
Acoustics
  • L&R drivers mid-high BMR drivers: 58mm x 58mm
  • Subwoofer Dual voice coil: 100mm x 150mm
  • Crossover (Typical): 340Hz
  • Power consumption
  • Deep Standby: <0.5 Watts
  • Idle: 11 Watts
  • Power Rating: 100~240V – 50~60Hz 100W
Bluetooth®
  • Specification: V4.0 class 2 device
  • Latency: 40ms
  • Internal stereo: CODEC 16-bit
  • Stereo audio sample rate: Up to 48kHz
  • Music enhancements: aptX®, SBC, MP3, AAC
  • Support for: AVRCP 1.4, A2DP, 802.11 co-existence
Weight and dimensions
  • Product (W x H x D): 550mm x 93mm x 338mm
  • Packaging (W x H x D): 615mm x 178mm x 428mm
  • Net weight/Gross Weight: 5.8 kg, 7.9 kg
  • Maximum weight of placing a TV on top should be 25kg
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
The SVS Prime Wireless Pro SoundBase combines wireless media streaming with a two-channel integrated amplifier. Find out how this might fit in your home...
At CES 2014 VIZIO just announced their flagship 54″ (S5451w-C2) 5.1 Home Theater Sound Bar, 38″ (S3851w-C2) 5.1 Home Theater Sound Bar and 21″...
Under-the-TV Speaker Does Double Duty as Sound Bar or Wireless Loudspeaker Sonos announced their latest speaker for the home called PLAYBASE. This $700 versatile...
Exclusive Review: $250 SoundBase Compared With $250 Sound Bar As HDTVs become paper thin with nearly invisible edges, there is very little room for...
Fluance just introduced the AB40 High Performance Soundbase. The $250 under-the-TV-speaker is deeper than a standard soundbar, because it includes a downward firing subwoofer. The company says...
