Q Acoustics Launches Concept 30, 50 and 90 Loudspeakers
Q Acoustics have expanded their Concept range with 3 new models for two-channel and home theater systems.
Q Acoustics Concept 50 Floorstander and 90 Center Channel Home Cinema Loudspeaker System White Lifestyle
We sound like a broken record sometimes when we pound on the “affordability” thing but it’s encouraging to see that some manufacturers really get it or are trying to bring their prices down while raising the bar on performance. Q Acoustics’ 3000 Series loudspeakers are near the top of our list when it comes to performance/value and at least 3 of us own multiple pairs of their loudspeakers.
They keep prices down by manufacturing everything in China but the build quality is excellent and we’re not in any hurry to replace our 3030i bookshelf speakers or the 3050i floor standing loudspeakers ($949/pr).
Where things get slightly more interesting with Q Acoustics is with their Concept Series that has now been expanded to include the Concept 30, Concept 50, and Concept 90 models.
Taking cutting-edge acoustic technology and design cues pioneered in the flagship Concept 300 ($3,499/pr) and Concept 500 ($6,499/pr), while also introducing new state-of-the art audio innovations, these new models are designed to deliver better sound quality than the 3000 Series but for far less than the two Concept models at the very top of the range.
Concept range audio innovations include:
  • Gelcore™ cabinet construction reduces higher frequency cabinet noise.
  • Point-2-Point™ (P2P) internal bracing stiffens the cabinet to minimise lower frequency vibrations (not Concept 90)
  • Helmholtz Pressure Equalisers (HPE™) reduces internal pressure and standing waves (Concept 50 and 500 only).
  • Isolation suspension base eradicates unwanted external and internal vibrations.
New audio innovations on the Concept 30, 50 and 90 include:
  • The driver assembly is mounted to the front aluminium baffle by pretensioned studs to give the correct acoustic seal, while dampen vibrations and minimise structural coupling of the assembly in main cabinet.
  • Ground-up mid/bass and tweeter driver design for increased power handling.
  • High-frequency driver is fully hermetically sealed and mechanically isolated (floating) from the front baffle to protect from internal resonances from the mid/bass driver.
  • Crossover design is mounted on the isolation base, to minimise any microphonic pick up and away from electro-magnetic fields radiated by the drive units.
Q Acoustics Concept 30 Stand-mount Loudspeaker Black
No Artificial Color
Introduced in the original Concept speaker, the Gelcore™ cabinet construction is designed to minimise high-frequency noise. A unique design comprised of a non-setting gel sandwiched between two individual layers, this specially developed adhesive dissipates high-frequency vibrations, generated by the moving drivers, into heat to maintain a focused audio performance.
To keep the cabinet as rigid as possible, Point-2-Point™ (P2P) internal bracing is employed. First introduced in the Concept 500, reinforcement is fitted to interior areas of the cabinet susceptible to low-end frequency reverberations.
A variation on the hugely effective ‘isolation base’ principle first seen on Concept 300 means all three of the new Concept models have a suspension system in the form of a sprung baseplate. Two plates are separated by suspension ‘spheres’ that effectively isolates the cabinet from interference from external vibrations, providing tighter stereo imaging, while also bringing greater depth.
Tall floorstanding speakers are prone to internal build-up of pressure that cause unwanted standing waves and reverberations. To prevent this occurring, specially designed Helmholtz Pressure Equalisers (HPE™) tubes are fitted inside the Concept 50’s cabinet to improve frequency response.
All these anti-resonance innovations allow the state-of-the-art complement of drivers free to get on with the job of delivering the most realistic, most involving sound ever heard at this price-point.
Q Acoustics Concept 50 Home Cinema Loudspeaker Black
Controlled Power
Designed as an integral part of the mechanical structure of the cabinet, both the 5-inch mid/bass and 0.9-inch tweeter drivers are new, ground-up designs specifically for the Concept 30, 50 and 90 loudspeakers. The drive units are fixed to a remarkably stiff 3mm aluminium baffle plate before it is fitted to the cabinet – this gives the correct acoustic seal, dampening vibrations and minimising structural coupling.
Elsewhere, the tweeter is hermetically sealed and mechanically isolated (floating) from the baffle, which means lower distortion and a lower crossover point for seamless integration through the crossover region. At 30.5mm, the larger mid/bass driver voice coil increases motor strength resulting in a 50% increase in power handling over a comparable driver with 25.4 mm voice coil.
Lastly, the crossover itself is mounted to the isolation base, keeping it free of sound-effecting vibrations and away from the electro-magnetic influence of the drivers themselves.
Updated Design
Boasting the same sophisticated design lines and stunning, premium high gloss finish of the top-of-the-range 300 and 500 models, the new range retains the signature aluminium front baffle plate that made the original Concept speakers so iconic. All models arrive in three striking lacquers: black, silver and white.
Q Acoustics Concept 90 Home Cinema Loudspeaker Group White
Q Acoustics Concept 30 bookshelf, 50 floorstander, 90 center and Q B12 subwoofer
Home Theater Packages
The Concept 50 5.1 speaker package delivers exquisite and absorbing home cinema sound. This set-up is comprised of a pair of Concept 50 floorstanders at the front, a pair of Concept 30 standmounts positioned at the rear, with a Concept 90 centre channel focused on dialogue.
Finally, Q Acoustics’ most powerful subwoofer, the Q B12, provides the low-end sonics. The Concept series is designed to work in any 2.1 or 5.1 configuration should you decide to add the Concept 90 centre channel and Q B12 subwoofer to any of the range’s floorstanding or standmount models (choose from the 30, 50, 300 or 500)
Price & Availability
Q Acoustics Concept 30 (bookshelf speaker) is priced £899/€1,199/$1,299 and is available from qacoustics.co.uk (UK), qacoustics.com (UK) and local independent dealers from the end of October.
Q Acoustics Concept 50 (floorstanding speaker) is priced £1,999/€2,599/$2,999 and is available from qacoustics.co.uk (UK), qacoustics.com (UK) and local independent dealers from the end of October.
Q Acoustics Concept 90 (center speaker) is priced £649/€849/$999 and is available from qacoustics.co.uk (UK), qacoustics.com (UK) and local independent dealers from the end of October.
For more information: qacoustics.com/collections/concept-range
Specifications
Concept 30Concept 50Concept 90
Bass unit1 x 125 mm (5.0 in)2 x 125 mm (5.0 in)2 x 125 mm (5.0 in)
Treble unit1 x 25 mm (0.9 in)1 x 25 mm (0.9 in)1 x 25 mm (0.9 in)
Frequency response (-6dB)54 Hz – 30 kHz  42 Hz – 30 kHz67 Hz – 30 kHz
Nominal impedance6 Ω6 Ω6 Ω
Minimum impedance3.9 Ω3.6 Ω3.7 Ω
Sensitivity (2.83V @ 1kHz)87 dB/w/m90.5 dB/w/m90 dB/w/m
Recommended amplifier power25-100 W25-150 W25-150 W
Crossover frequency2.4 kHz2.1 kHz2.1 kHz
Distortion (120Hz – 20kHz, @2.83Vrms)<0.2%<0.2%<0.2%
Effective volume7.0 L28.8 L11 L
Dimensions (per loudspeaker) HxWxD284 x 180 x 319 mm
(11.2 x 7.1 x 12.6 in)
Inc spikes and stabiliser:
1025 x 418 x 319 mm
(40.4 x 16.5 x 12.6 in)
Cabinet width: 180 mm (7.1 in)
184 x 550 x 259 mm
(7.2 x 21.7 x 10.2 in)
Weight (per loudspeaker)7.9 kg
(17.4 lbs)
22.9 kg
(50.5 lbs)
12.3 kg
(27.1 lbs)
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
All under $1200, three new Q SUB subwoofers get the most out of Q Acoustics stereo and surround sound speaker systems.
The best speakers from Arendal Sound have arrived, but their new flagship towers will set you back $9,500/pair USD.
Our favorite wireless speakers to buy in 2024 include models from Audioengine, Q Acoustics, KEF, JBL and Dynaudio.
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
Looking for the best bookshelf or stand-mounted speakers below $1,000? We've awarded 10 loudspeakers that have impressed us enormously.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
