Q Acoustics Introduces First Powered Loudspeakers: Q Active 200 Bookshelf Speakers
Powered stand-mount speakers for audiophiles looking for true wireless connectivity in a modern design.
Q Acoustics Q Active 200 stand-mount loudspeakers in white
Stylish Power
The market for high-end active loudspeakers is heating up with a new entrant from Q Acoustics. At $2,000/pair the new, modern looking Q Active 200 powered speakers are the first-ever to include internal amplification from the fast-rising British audiophile brand. It appears they’re looking to steal market share from KEF, which recently introduced the LS 50 Wireless II powered speakers that costs a $500 more. Other than the obvious color choices KEF offers, the biggest differences arise from each company’s proprietary driver technology.
q-active-200-inside
Design
The Q Active 200 stand-mount speakers feature two 2.25-inch Balanced Mode Radiator (BMR) drive units and a rear-firing 4.5-inch long throw subwoofer with a waveguide for enhanced low-frequency bass performance. There are six discrete amplifiers powering the Q Active 200, resulting in a total power output of 280 watts. Interestingly, that’s the same power as the KEF’s so one might wonder if internal amplifiers are the same?
Q Acoustics claims their BMR architecture delivers a wide sound field across an entire listening area, rather than restricting it to the ‘sweet spot’ of more traditional driver arrangements. In addition, the company boasts seamless midrange performance that operates all the way down to 150Hz, before handing off low frequencies to the rear subwoofer driver.
q-active-200-rear-switches
Flexibility
The Q Active speakers are tuned to perform their best no matter where they are placed in your listening room. By offsetting the drivers, customers can swap left and right speakers for an added degree of fine-tuning. A switch at the back of the Q Active speakers lets you designate left or right channels, while another tells the speakers where they are positioned in a room – close to a wall, in a corner or out in free space. This information allows the Q Actives to fine-tune its low-frequency response to deliver the best possible sound for its environment.
Q Acoustics Q Active Control Hub
Control Hub
The Q Active 200 speakers use an external Control Hub configured either for Google “Chromecast built-in” or Amazon “Works with Alexa” that is supplied with each pair of speakers. The Hub connects to your home network using ethernet or wi-fi and links together a variety of wired and wireless sources including Bluetooth®, Apple AirPlay 2, Roon and Spotify Connect.
For wired sources, the Control Hub offers an HDMI ARC input, an optical digital input, an analogue line level input and a subwoofer output. You can also plug your turntable into the Hub – it features a built-in moving magnet phono stage.
Q Acoustics Q Active 200 Bookshelf Speakers in white
No Speaker Wiring
Once everything is connected to the Hub, there’s no wiring to the speakers! Only the power cords from each speaker need to be plugged into a wall outlet. The Control Hub links to the Q Active speakers via a wireless connection where all incoming audio (Max Source Resolution 32bit/192kHZ) is converted to 24-bit/96kHz hi-res audio, making for a beautifully simple system free from the tangle of speaker cables. The wireless design means the Control Hub can be placed out of sight if desired: behind a TV, in a cupboard or on a rack. A remote control is also included with each Hub.
Streaming
All popular music streaming services are supported such as Amazon Music, Apple Music, Deezer, Qobuz, Spotify and Tidal – and users can play and control their music directly from each platform’s native app, keeping the Q Active experience reliable and fuss-free without the need to download any additional apps. The speakers can also operate as a UPnP media player capable of streaming your digital audio library from a computer or NAS drive.
Q Active supports voice control via Apple Siri, Google Assistant and Amazon Alexa, and can form part of a multi-room speaker group using AirPlay 2, Roon, Google “Chromecast built-in” or Amazon “Works with Alexa”.
Q Acoustics Q Active 200 Speakers in white with FS75 Stands
Optional Stands
The Active 200 can be equipped with optional Q FS75 floor stands ($499/€419/£349 per pair). Inspired by the Concept 300’s Tensegrity stands’ principles of the 1951 Festival of Britain’s Skylon structure, this stylish four-legged stand eliminates unwanted vibrations to result in a purer sound.
The Q Active range is a true active design, with class D amplification eliminating the need for a bulky external amp or receiver. The Q Active 200 speakers feature twin Balanced Mode Radiator (BMR) drive units in an offset configuration that deliver a widescreen sound dispersal and a huge sweet spot: so no matter where you’re sitting in the room, you’ll hear the same rich, detailed and expressive sound from the Q Active speakers.
Q Acoustics
Q Acoustics Q Active 200 stand-mount loudspeakers in black
Specifications
Peak Power280W
Max Source Resolution32bit/192kHz
Sample Frequency96kHz
Bit Depth96kHz
Continuous Power100W
Crossover Frequency150Hz
DimensionsPer Speaker: H x W x D:
284 x 170 x 290mm
(11.2 x 6.7 x 11.4in)
Speaker on Stand: H x W x D
922 x 286 x 338mm
(36.3 x 11.3 x 13.3in)
Enclosure TypeReflex (ported)
Frequency Response46Hz to 20kHz (-6dB)
Mid Bass / Driver2 x BMR 58mm (2.25in)
Subwoofer1 x 114mm (4.5in)
WeightUn-boxed weight (per speaker) 7.5kg
Future
Coming in 2021, Q Active 400 Floor Standing Loudspeakers! Same front BMR drivers in a bigger cabinet that houses an extra bass radiator in the rear. Pricing not yet announced. See them in the video below.
Intro Video
Price & Availability
Available in matte white or matte black. Learn more at: https://www.qacoustics.co.uk/activerange
Q Active 200 with Google Cast “Chromecast” Control Hub (October 2020)
  • $1,999 at Amazon.com
  • £1,499 at Amazon.co.uk
  • €1,999 at Amazon.de
Q Active 200 with Amazon “Works with Alexa” Control Hub (Early 2021)
  • Pricing expected to be the same.
Q FS75 floor stands
  • $499 at Amazon.com
  • £349 at Amazon.co.uk
  • €419 at Amazon.de
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Fluance has expanded its powered loudspeaker options with the Ri91 and Ri71 reference models. Both feature AMT tweeters and enhanced connectivity.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Daily Deals
Our favorite portable Bluetooth speakers on sale for Cyber Monday 2024 that we would actually buy for ourselves or recommend to family and friends.
Bose just expanded its Bluetooth speaker lineup with one for home and another to take wherever your path leads you.
Sony just released a new and improved version of their neckband speaker but is this another clever gadget in search of a market?
