Accessories
Pyle PBTR70 BlueReach 30-pin Bluetooth Adapter
Pyle Audio BlueReach PBTR70
Pyle introduced the BlueReach (model PBTR70), a 30-pin Bluetooth Adapter that plugs into any iPod speaker dock, making it wireless capable for streaming from any Bluetooth-enabled smartphone or tablet, which include Android devices and newer Apple products that use a lightning connector. The BlueReach breathes new life into existing iPod speaker docks, that became almost worthless when Apple changed its dock connector with the latest generation iPhone, iPod and iPad products.
Pyle Audio BlueReach PBTR70 in dock
Able to function at a range of up to 33 feet, the BlueReach adds wireless functionality while also freeing the user to maintain mobile device functionality such as emails, texting and internet use. The innovative plug-and-play interface allows the user to simply plug in the 3-inch receiver and play music wirelessly throughout the home or while on the go. Additionally, the user is able to plug in any device that uses a 3.5mm plug to stream music via Bluetooth. With its three level LED illumination, setting up your BlueReach device is simple and convenient. Of particular importance is the BlueReach’s ability to also operate outside of the Apple platform, which makes it the ideal choice for Android and Blackberry users who can easily connect using their Bluetooth.
Pyle Audio BlueReach PBTR70 PackagingFeatures:
  • Easily connect the adapter to change a common 30-pin docking station into a wireless Bluetooth audio device and control the system from your portable device
  • 33-foot wireless range to play your favorite songs on your device through a Bluetooth connection
  • Supports Bluetooth-enabled mobile devices, such as iPad, iPod touch, iPhone, Android, Blackberry, Bluetooth PC, PSP and many more
  • Complies with Bluetooth 2.0, Plug and Play. Support A2DP V1.2, compatible with all devices enabled with A2DP stereo Bluetooth
  • 3.5mm input allows for direct audio input into an Apple only 30-pin docking source
  • 3 Level LED illumination to confirm visual Bluetooth Interface (Red/Blue/Flashing Blue)
  • Dimensions: 2.15″H x 2.15″W x 0.45″D
Price and Availability
The Pyle Audio PBTR70 BlueReach Adapter is available for $66.99.
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
