PureLink MX-1800 / MX-3600 Multi-Format Modular Digital Matrix Router
PureLink MX-1800 Modular Digital Matrix Router
PureLink MX-1800 Modular Digital Matrix Router - backPureLink MX-1800 Modular Digital Matrix Router - back
PureLink has been known for manufacturing and providing the most reliable and top performing Integrated DVI and HDMI Matrix Routers since 2004. Recently PureLink’s new Modular Digital Matrix Router has been garnering a significant amount of attention due to multi-format to any multi-format with a switching time of under 20 milliseconds.
The new MX-1800 Modular Digital Matrix Router comes in 18×18, 36×36, 80×80 and 144×144. This large scale matrix router can be customized to fit each clients preferences by connecting any multi-format to any other multi-format including DVI, HDMI, CAT5, HD-SDI, FIBER and whatever format that comes out in the future. It’s an amazing breakthrough amongst matrix routers because it is the only one on the market capable of such features.
All a client would need to purchase is the chassis for the MX model and then buy modular slot cards separately. The modular slot cards come in 3, 6, 8, and 12 ports in order of the MX model size. This gives you the flexibility to customize the configuration of the matrix router to fit a clients needs. The modular slot cards also have two different formats for DVI and HDMI for HDCP Compliance which also makes it cost effective since it may not be necessary in certain configurations. There is a limited amount of matrix routers in existence that can support HDCP with such a large scale matrix router.
The matrix router supports 1080p HD resolution and also provides the most advanced EDID management available right now. This unit also has a touch screen which enables the user to operate and control it by a single touch. This unit can also be controlled by RS-232, LAN or externally with other controllers such as Barco Encore and Vista Spyder.
Once again PureLink outperforms all other competitors by delivering the most advanced technology. When it comes to the critical needs of our clients, PureLink products will not fail nor falter when it comes to reliability and performance.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
