In-Wall Speakers
PSB Imagine W1 and W3 On-Wall Speakers
PSB Imagine W1
PSB Speakers introduced the Imagine W1 and Imagine W3 on-wall speakers, designed to be mounted around a flat panel TV. Both speakers measure only 3” deep, are engineered specifically for ease of installation, and finished in high gloss black.
The Imagine W1 ($599) is a single-channel speaker that can be mounted vertically or horizontally and further utilized individually as a front left, center, or surround-sound speaker. W1 can also be used as a stereo pair for high-performance audio.
PSB Imagine W3
The Imagine W3 ($1199) is really a sound bar, which combines left, center and right channels in one easy-to-install enclosure that can be wall-mounted or placed on a surface. The custom-designed drivers for each channel are sealed internally in individual chambers so they function as three discrete speakers for superior imaging and soundstage. Engineered as a ‘front of room’ solution, W3 clearly takes the conventional sound bar concept to a much higher level of performance.
Like all PSB Speakers, final voicing is performed by Paul Barton, Founder and Chief Designer of PSB Speakers, at Canada’s famed National Research Council.
Paul says, “Properly designing a wall-hugging speaker like the Imagine W1 requires a thorough understanding of acoustics to get sound that is true-to-nature.  PSB has perfected the tools required to get the optimal result for every loudspeaker application. The Imagine On-Wall speakers are voiced to perfectly integrate with other PSB models of In-Room, In-Wall, In-Ceiling speakers and subwoofers.”
PSB Imagine W1 with grille
Key Features of the PSB Imagine W1 and W3:
  • W1 can be mounted vertically or horizontally for flexible configuration. Can be used individually, as stereo pairs or as part of surround-sound system.
  • W3 combines sub-divided, discrete chambers for left, center and right channels in one easy-to-install enclosure for a complete front-of-room solution.
  • Custom-designed drivers for each channel are mounted in individual chamber for superior imaging and soundstage.
  • Designed sonically to integrate with other Imagine Series speakers
  • Easy to install, comes complete. Each speaker comes with a custom wall mount bracket, pre-construction template and a tabletop stand for horizontal placement.
  • Elegant industrial design, low-profile form factor and superb fit and finish complement the finest flat panel displays.
PSB Imagine W1 with grilles around TV
PSB Imagine W3 with grille below TV
Price and Availability (November 2012)
PSB Imagine W1 ($599)
PSB Imagine W3 ($1,199)
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
Escape into sonic bliss while traveling with some great ways to create the soundtrack for your summer of 2024.
Looking for the ultimate tech or hi-fi gift for Father's Day 2024? Upgrade Dad's lifestyle with gifts he'll enjoy all year and beyond.
Podcasts
On this episode Editor in-Chief, Ian White discusses his picks for the best wireless speakers of 2024 (so far) under $4,000.
Whether enjoying music at home or on-the-go, you don't have to spend a lot to experience high fidelity sound.
For $199, the PSB T4U TWM wireless earbuds calibrate their sound to match the listening capabilities of each ear.
Precision-engineered with dual 8” drivers and nCore amplification to deliver power and accuracy with minimal distortion.
PSB Alpha AM3 and AM5 are the powered and wireless versions of the Alpha P3 and P5, respectively.
