PSB Imagine T3 Tower Speaker
PSB Speakers announced their top-of-the-line floorstanding loudspeaker for stereo or home theater use. The new Imagine T3 Tower represents the latest and most advanced thinking from the company. Always aware that the room has a large effect on the sound of any loudspeaker, PSB made sure that the T3 interfaces smoothly and predictably with the listening room, giving clean well integrated bass response and pinpoint imaging. The perfect proportion of sound power, combined with extremely even frequency response and uniform off-axis response, creates a massive, dynamic and precisely detailed sound field.
Advanced Driver Technology
All new drivers combine proven engineering with advanced technology to reduce distortion and respond more faithfully to musical transients. This is accomplished in two ways. Firstly, a copper cap over the pole piece of the motor structure affects a dramatic reduction of 3rd harmonic distortion, and secondly a symmetrical drive design creates a more uniform magnetic field in the motor (driver) coil which makes the cone motion more linear by reducing 2nd harmonic distortion, especially at high volume levels where the cone motion is greatest. The woofers and midrange utilize polymer coated felted fiberglass cones mated to a high temperature fiberglass voice coil. Rubber surrounds and a highly rigid non-resonant die cast aluminum alloy chassis provide precision alignment of all speaker components for high performance and excellent reliability. Combined with amplitude-perfect acoustic Linkwitz-Riley 4th order crossovers, these advanced drivers provide the lowest distortion and highest power handling of any PSB speaker ever.
Three woofers
Three 7-inch woofers are arranged in PSB’s five-way transitional array, where all three woofers combine to produce the longest wavelengths of sound in the lowest frequencies. At higher musical frequencies woofers are strategically attenuated until only the woofer adjacent to the midrange is active, creating a perfect transition with uniform off-axis response. The position of each woofer, and the exact crossover slope, has been carefully optimized to reduce first acoustic reflections, also known as ‘floor bounce’. These early reflections are responsible for response irregularities and exist for all speakers unless compensated for as in the Imagine T3. Other advantages to using multiple woofers include a more efficient transfer of energy into the air compared to a single larger woofer, and the varying positions also tend to excite a broader spectrum of room resonances preventing the ‘one note bass boom’ that often occurs with powerful full range speakers. Smaller cones with large motors also result in higher sensitivity and more accurate piston motion of the cone for faster transient response and lower distortion.
PSB Imagine T3 Tower Speaker Inside
Individual Bass Chambers
Tall slender enclosures like the Imagine T3 look great and place the more directional tweeter right at ear level for best imaging. However tall narrow enclosures when used as bass chambers tend to have a serious ‘pipe resonance’ that can ruin bass transients and performance. PSB addresses this issue by using individually tuned chambers for each woofer. The dividers for these chambers also add significant structural rigidity to the cabinet, suppressing resonances still further. Since each chamber has its own rear firing tuning port, the user can further fine-tune the in-room response with the supplied port plugs. These work by reducing overall acoustic output in the lowest frequencies which can be beneficial in smaller rooms or when the speaker must be placed close to the wall behind. Additionally, the bottom woofer can be disconnected from the amp and shorted using the provided shorting link, thus creating a ‘bass trap’ or damper to further suppress room resonances.
Midrange
The Imagine T3 uses a specially developed 5-1/4″ midrange driver and tunes and isolates it in its own sealed chamber. The result is a lifelike presence that is palpable. The 5-1/4″ size has a nearly perfect combination of low distortion, high output capability and ideal dispersion over the desired frequency range, allowing it to integrate smoothly with the woofers and tweeter.
Tweeter
The Imagine T3 is using a hand-selected version of PSB’s famous titanium dome tweeter. This 1” dome features a neodymium magnet, high temperature voice coil and Ferrofluid cooling, allowing it to keep pace with the high power handling of the rest of the speaker. Several years spent perfecting the manufacturing process has resulted in a tweeter with extremely smooth response and amazingly low distortion compared with other well-known tweeter designs. An integrated ‘phase plug’ is ingeniously designed to extend high frequency response while also creating an ‘air spring’ that effectively damps the metal dome’s ‘oil can’ resonance. Although this resonance is beyond the audible range, if not well suppressed it can have knock on effects in the audible range. Excellent power handling allows PSB to ideally place the crossover point at 1,800Hz that enhances the dispersion and integration with the midrange driver.
PSB Imagine T3 Tower Speaker BackFinishing Touches
The PSB Imagine T3 includes a one-piece aluminum plinth with adjustable spikes, ideal for use on carpeted floors to gain stability and give a clean mechanical interface with the floor structure; even with uneven floors. Isolation pucks with carefully engineered rubber dampers are also included for hardwood floors to prevent damage and create a perfect interface. Five-way, gold binding posts provide multiple input terminals that allow for bi-amping and tri-amping if desired, along with the unique ability to use one woofer as a bass trap to tame room resonances and adjust the bass to perform perfectly in a wider range of room sizes and shapes. Like all PSB Speakers, final voicing is performed by Founder and Chief Designer, Paul Barton, at Canada’s famed National Research Council.
Features
  • Advanced driver technology reduces distortion
  • All new drivers and crossover designed
  • Tweeters are Titanium dome with Ferrofluid and Neodymium magnet structure
  • Three 7” Woofers, in individual bass chambers, configured in a transitional array
  • Newly-designed midrange drivers in their own sealed chambers
  • Gold-plated, five-way, binding posts that are also bi/tri-wireable and bi/tri-ampable
  • Final voicing performed by Paul Barton at Canada’s famed NRC
Price and Availability
The PSB Imagine T3 Tower speakers will be available in late November 2014 for $3,749 each in either premium High Gloss Black or High Gloss Cherry finishes.
1 Comment
1 Comment
  1. Steven Mitchem
    October 29, 2014 at 3:56 am
    Looks like PSB has done it again. These look great! If they are anything like all the other speakers they have come out with then you cant go wrong buying them. i would buy these without even listening to them! Thats how confident i am with any PSB product! Bravo again Paul Barton and PSB. Forever a fan!
2026 Steinway & Sons Model O Loudspeaker near wall lifestyle
What is Josh.ai VoiceCast, and how will it let existing Bluesound, NAD, PSB and other BluOS systems become part of a smarter home?
PSB’s iQ Series powered speakers bring BluOS, HDMI eARC, phono, USB C, and subwoofer control to compact stereo systems from $999.
Podcasts
On this episode Editor in-Chief, Ian White discusses his picks for the best wireless speakers of 2024 (so far) under $4,000.
2025 Black Friday tech deals you won't want to miss on premium hi-fi, headphones, and home theater gear this Holiday Season.
At $1,099 per pair, the PSB PWM Sat on-wall speaker is designed for flexible installation with two-channel or home theater setups.
At $1,199, the PSB SubSeries BP7 is a compact powered subwoofer offering precise, deep bass with dual 6-inch drivers.
For $199, the PSB T4U TWM wireless earbuds calibrate their sound to match the listening capabilities of each ear.
